Question about Dishwashers
No heat in Kitchenaid dishwasher kudi01fl
Hi, I have the KUDI01FLWH0 dishwasher, stainless tub. I am trying to diagnose the lack of heating problem but have lost the tech sheet. Does anyone have the tech sheet, pictures or thoughts on which direction to start the diagnosis and continuity checks? The water going into the dishwasher is 118 degrees (just about ideal). I have measured the water temp occasionally during cycles and it stays at a constant 90 degrees in all the cycles. I don't think it's the thermister because the cycle completes every time (I don't have blinking lights). I have reset the module (keypad sequence) and now the water remains at 90 degrees (so there could be partial heat) whereas before it was cold to the touch. Please help.
2 Suggested Answers
  • 25 Answers
SOURCE: Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Posted on Jan 23, 2009
The water is not heating up
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 14, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
CHANGE COLOR OF KITCHEN AID DISHWASHER
Go to www.applianceart.com
They have many options available for changing the color of your Kitchen Aid dishwasher. They also have designs, textures and stainless steel.
Apr 10, 2011 | KitchenAid 24 in. KUDI01FL - Multiple...
Clean light flashing. dishwasher does not work
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Jan 24, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
Dishes are wet after wash. Appears drying cycle is not working.
heatman101
Asker
Jan 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a kitchenaid dishwasher modl # KUDIO01IL. Someone opened the door during a wash cycle and now the CLEAN LED is flashing. Tried pushing cancel and unplugging. No change. Any ideas/
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn't work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Nov 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whit film on everything at the end of wash. dishes not clean I took off the screen and cleand a bunch of stuff out of the sump. seems the same. it is filling with water draining soap is all...
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 07, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Dishwashers Logo
132 people viewed this question
Top Dishwashers Experts
