Question about HP Pavilion dv6000z Notebook
Startup Repair when i start my laptop it says a window appears and says "Startup Repair. Windows cannot repair this computer automatically. Then it says if theres a device to remove it and restart the computer" There is no device hooked up and when i restart it I get the same message. It also says if I continue to see this message contact your system administrator or computer manufacturer. I am running Vista on a Hp laptop
  • 32 Answers
Ok then you can try removing the harddrive and reseating it. that might clear up the problem but the odds are your going to have to use your recovery disks to restore your machine. but before you do that. if you have information that you need off the computer. you need to get someone to retrieve the info off of it.
Posted on Apr 16, 2009
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
https://www.easeus.com/resource/fix-preparing-automatic-repair-loop.html
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1https://neosmart.net/wiki/startup-repair-infinite-loop/Search for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Supporthttps://support.hp.com/bg-en/document/c03439317Search for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
Nov 28, 2017 | Computers & Internet
After format completes cp gets restart and occur file:\boot\bcd status:0xc000000e
All credit to J W Stuart
"How to repair and reboot to Windows 7:
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the display.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
Note: Please perform step j as detailed, startup repair must be run multiple times.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'. This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer."
Nov 22, 2012 | Dell Inspiron 15r n5110 Laptop
Toshiba laptop restarting
The loop on your Toshiba Satellite laptop refers to the computer not booting properly.
During the loop, the computer will try to boot the Windows operating system and keep restarting over and over again.
This is not a hardware issue with your Toshiba Satellite A106.
The issue resides in the startup files on your computer's hard drive.
You can fix this by running a repair tool that comes with your Windows operating system.
This repair tool will fix your startup disk and allow you to get your computer back up and running.
Insert your Windows 7 installation disc into your computer's optical drive.
Start your computer and wait for it to boot from the install disc.
Choose your language from the menu and then click the "Next" button.
Click "Repair your computer" from the menu.
Choose the operating system you are using and then click the "Next" button.
Click on the "Disable Automatic Restart On System Failure" button to disable the startup loop.
Click the "Startup Repair" tool from the menu and wait for the computer to fix your startup disk.
Wait for the computer to finish repairing your startup disk and then allow it to restart automatically.
Wait for the computer to boot correctly to your login screen.
Hope this helps
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
Oct 23, 2012 | Toshiba Satellite M35X-S311 Notebook
Kenapa pada saat penginstalan laptop muncul tulisan BOOTMGR is compressed..?
google translate
why at the time of installation the laptop it says BOOTMGR is compressed
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
bootrec.exe /fixmbr
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
hope this helps
Aug 09, 2012 | Computers & Internet
Startup repair cannot repair computer automatically
insert the windows installer on the disk drive then repair the windows.
Apr 10, 2010 | Compaq Presario 700 470024-192 Notebook
A Windows Update seemed to have crashed my laptop
I"d go back and reboot and when it asks you that question again press start windows normally.
Jan 09, 2010 | Computers & Internet
I have accer 5570 Laptop when ever i start it up it gives me this message on and off and wont let me start the window here what it says" windwos Erro Recovery-windows failed to start. A recent Hardware or...
Tried starting normally & go int contol panel on the start menu,system tools & system restor to last good setting!
Hope that helps but if not get back to me!
Sep 22, 2009 | Acer Aspire One AOA150-1784 Netbook
Boot mgr Is missing on a tobisha laptop
Method 1:
Use the following procedure to repair the file system on the hard drive:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter.
  4. Select a keyboard layout that matches your country/region and click Next.
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field and then click OK.
  7. A System Recovery Options window opens.
  8. Click Startup Repair.
A Startup Repair window opens and automatically scans for startup problems.
  1. Perform the actions suggested by Startup Repair: system restore, correct damaged or missing files, or other action.
  2. After Startup Repair has been used, try to open Windows.
    • If Windows Vista opens, you are done.
    • If Windows Vista does not open, perform the first portion of this section again to open the Startup Recovery Options window and continue.
  3. From the Starup Recovery Options window, click Command Prompt.
  1. Enter the following at the command prompt:
bootrec /fixboot
bootrec /fixmbr
  1. After the bootrec tool has been used, close all open Windows to restart the computer and open Windows.
    • If Windows Vista does not open, continue using these steps.
  2. Perform a full system recovery using recovery discs. For more information refer to the HP support document Performing an HP System Recovery in Windows Vista .
If the recovery cannot be completed from recovery discs, replace the hard drive.
Sep 13, 2009 | IBM ThinkPad T43 Notebook
Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
when you restart try to press F11 while booting..check
Jan 05, 2009 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
