Question about SanDisk Sansa e250 MP3 Player
How do you get in USB mode?
Hi, My Sansa was stuck in the SANDISK screen and would fade a white screen so i tried this 6 and 7 step thing but now its telling me to, Please connect your e200 series MP# player in MSC mode. To go to "MSC" mode, in your device, goto "Settings"> "USB mode"> "MSC". but how can i do that if it wont let me =[, please help!
  • 626 Answers
If you cannot change the "modes", you will have to put it into recovery mode to fix it. You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Download and run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe Best of Luck.
Posted on Sep 16, 2007
SOURCE:
My sansa is spazzing out
Go to settings - USB Mode -- msd; and make sure the port on your computer is a USB 2.0 port.
Jul 05, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 4gb Restarts over and over
press the recording key and the middle key of the mp3 for 6 seconds
Jan 30, 2008 | SanDisk Sansa e260 MP3 Player
My sansa wont boot up
Re - Format Your sansa drive
Dec 13, 2007 | SanDisk Sansa e260 MP3 Player
The best results that I have had were to hold the power button for about 15 seconds. ( if you only hold it for 3 seconds it goes into sleep mode). This shuts the device off. Then restart it.
Dec 12, 2007 | SanDisk Sansa e250 MP3 Player
Evry time i turn on it comes up with sandisk then...slowly fades out white and does this again...untill i reset
Mine does the same thing. Every time I turn it slowly fades it to white..and than it does it again. I don't know how this happened. I was listening to it right before this happened. I Need help.
Nov 17, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e280 8gb white screen with black spot
It sounds like some data corruption.
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 28, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk sansa c140
You need to Have Windows XP / SP2, Wndows Media Player 10 or higher in order for the device to be recognized. If you have these components, try changing the mode on the device to MSC Mode. Settings>Mode>MSC. Best of Luck.
Sep 11, 2007 | SanDisk Sansa c140 MP3 Player
For God's sake help me!!
MAKE SURE YOUR SANDISK IS PROPERLY CONNECTED TO YOUR COMPUTER THEN-GO TO YOUR START MENU-CLICK ON CONTROL PANEL-THEN CLICK ON SOUND SPEECH AND AUDIO DEVICES ON THE BOTTOM CLICK ON PORTABLE MEDIA DEVICES AND FOLLOW THE STEPS YOU COMPUTER GIVES YOU. GOOD LUCK AND I HOPE I WAS ANY HELP TO YOU.
Jun 30, 2007 | SanDisk Sansa m250 MP3 Player
Gray Screen
I had a very similar problem where my Sansa would turn on show the initial logo then fade to a white/grey screen and restart. To fix it started in recovery mode (Start in hold mode with rec button held down) then used the firmware updater to update the software and it seems to had fixed the problem hope this also works for you
Jun 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
