Question about Garmin Nuvi 660 GPS Receiver
Won't charge while driving
Recently updated Garmin Nuvi 650 online.
Will charge OK in house, but will not hold charge in car while driving- it drains off home charge, then will keep shutting itself off in the car after the in- home charge is low enough. Tried it in another car and it still did not work, so it seems like it is the plug in for the car that is not taking in power?? Or is it in the part that clips into the back of the unit with it's connectors?? We need this for a trip in the near future. Please advise!
Thanks!!!
  • 3 more comments
  • Marsha Hartmann Apr 17, 2009
    Yes, tried same adapter in 2 different cars. I don't see anything on the tip of the adapter that unscrews to chk fuse. It's all one piece. will try suggestion of chking side USB port, and let you know. Thanks !!!
  • Marsha Hartmann Apr 18, 2009
    I looked again at the car adapter-the end that goes into the lighter is all one piece so I can't take it apart to check a fuse. There is no USB port on the side of the unit itself (screen)-only a little round plug in for the inside-the-house-power cord, and a slot that looks like maybe there is a card of some kind in there.
    I am at a loss, unless it has something to do with the metal clips on the piece that hooks the unit to a suction stand . Am I going to have to bit the bullet and buy those pieces?
  • Marsha Hartmann Apr 19, 2009
    Ok, I see what you are talking about on the side of the unit- and we are talking about the same thing-it's a small squarish hole between the head phone jack and the SD card slot----- the squarish hole is where the AC adapter goes to plug into house power......that cord/connecters are fine, and I can charge the unit off house power.
    By the way, my unit is a Garmin Nuvi 6-5!-0 NA, not a 660 ora 350...don't know if that makes a difference in what we're talking about or not...
    In the back center of the unit/screen is a slot-maybe an inch long with little prongs -that is where the clip to hold the unit to a suction stand sits. On the back of THAT clip is a little plug in like connector with the cord to that goes into the lighter supplying power from the car. As explained earlier, the end into the lighter is all one piece, so if there is a fuse in that male end, I cannot see how one would get to it. Hope I clarified this a little better. Thanks!!
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    If you have a Nuvi 660, you definitely have a mini-usb port on the side of the unit between the headphone jack and SD card slot.
    Unfortunately, the plug on a 660 cradle is different than the one on a Nuvi 350. Don't you have the AC adapter? If so, plug it into the mini-USB connector and see if the unit will charge.
    - Jim
    SHARCNET-USA
  • SHARCNET-USA
    When you said you tried it in another car.... do you mean you used the same car adapter? If so, this is an indication that the car adapter is not working or it could be the rear cradle connection. To rule out the rear cradle, pull the plug from the cradle and plug it into the side USB port. If the unit works, then your cradle port in the back of the Nuvi isn't working and the pins may be bent inside.
    If it still doesn't work, then the adapter is bad. There is a fuse in the tip. Also, please see this link:
    http://www.sharc.net/gps_charger_repair....
    If you cant resolve the issue, I can help you with this:
    - Jim
marcelbakker
  • 174 Answers
SOURCE: Garmin c550 GPS-Won't turn on at all.
push and Hold the power button down while you push reset, keep power button pressed til it boots again. If it does not, and it's in warranty ship it to garmin. If it's out of warranty, have someone open it up and remove the battery for a couple of minutes.
Posted on Jul 23, 2008
  • 2920 Answers
SOURCE: Garmin Nuvi 360 Won't Load Maps
go buy a tom tom you dont havve to do any downloads to keep it up to date.garmin has to many issues
Posted on Aug 25, 2008
SOURCE: Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Posted on Nov 17, 2008
SOURCE: My Garmin Nuvi 200 wont turn back on
Our Garmin didn't turn on. We unplugged it, pushed the reset button on the bottom and then plugged it in again and it WORKED
Posted on Dec 01, 2008
ikechinedu
  • 184 Answers
SOURCE: garmin nuvi 650 is froze up. how do i fix it
If you can access your memory space, check to be sure its not low on memory. otherwise, you may have to reset it to facory setting or upgrade the firmware.
Posted on Jun 09, 2009
Disassembly
Refer your inquiry direcrtly to Garmin
Jun 01, 2013 | Garmin nuvi 650 GPS Receiver
My Nuvi 650 screen reads "The following map data is more than a year oldand should be updated. When I touch the "OK" on the screen, nothing happens, it seems the screen has become unresponsive.
I would suggest some caution here. I have noticed a trend in anything that can be updated by the consumer---they just blindly do it and I have also seen as the result of this dozens of units crash and burn---if you have not issues and the unit functions why risk losing it?
Turn this unit off and see later if turned on it functions or not, failing that the only way out of the mess would be a call to the maker.
Don't just blindly say ok, kind of like getting a email with a virus and saying OK.
Dec 20, 2012 | Garmin nuvi 650 GPS Receiver
I have a Garmin nuvi 1300. Recently i update the firmware, the routing direction keep on showing some path that passing housing area and very difficult to drive though. At the setting is usual like last...
Updating your firmware will not correct that problem. I think your maps may be out of date and does not know what to do. I don't know how long you have had your unit but if its under a year old Im pretty sure your entitled to free updates for your maps. If it over a year old then you need to go to www.garmin.com and purchase new updated maps.
I hope this helps you out if it does please click YES on the web page that you are receiving this response on. Thank you
Apr 10, 2011 | Garmin nuvi 1300 Car GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
My garmin nuvi 650 will not go to next screen it
have you tried the master reset?
plug it in to the usb port on your computer for a few hours.if that fails,then try the master reset.
note: that the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update.
download the updater HERE
(actually i would do this either way)
bill
Sep 27, 2009 | Garmin nuvi 650 GPS Receiver
Garmin 650 won't hold charge in car -- same problem
Check power at the 12volt outlet to insure that you power is on at the connection. Try using a 12 volt convertor in the house to check the cord used in the vehicle.
Jul 23, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 650 powers off when connected with car
I had this problem. The problem turned out to be my car charger. Hooking the GPS up to my computer allowed it to charge and operate normally. A new car adapter might fix you right up.
Jul 06, 2009 | Garmin nuvi 650 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
252 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
