Question about GE RM24911 Remote Control
Lost the manual to Kenmark tv
Trying to get sky to work on said tv and can't seem to manage it. I am sure I set up all the leads correctly but don't know which option to choose from the index menu
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 182 Answers
What model of the tv do you have .under normal conditions it would be connected to the sky box via a scart lead. If this is the case bring up the menu on the tv and select scart input . this should then work
Posted on Jun 05, 2010
The sky box is on and the tv.....tv is on correct channel but no picture or sound.....i have tryed rebooting the sky box and turning tv on and off
Check all of the cable between the tv and the box are correctly inserted by removing and refitting them. If you're using scart leads look at the pins in the plugs: if any are missing or bent replace the lead entirely. If that fails look at your dish to ensure that it still seems OK: they can get knocked off-aim by window cleaners for example and I've even known the LNB to be stolen (the box of electronics on the front of the dish).
If that doesn't work then you need to phone Sky for further troubleshooting.
Mar 04, 2011 | Televison & Video
I have a tv digisender (Nikkai) which works fine with an analogue tv on a scart lead, but not via a scart lead with a Kenmark dtv. (Error message is no signal received) Help!
you have to select scart on the kenmark tv from the source menu as your digi receiver probably does not have an av switching voltage
May 01, 2010 | Samsung WS-32M066V 32.28 inch TV
Hissing and Humming when trying to use the speakers for the tv
The sony manual tells you how to connect to a TV however most of us now watch TV connected to a SKY box. The Scart lead needs to be connected to the Sky box for the sound to work correctly. Ignore the Manual and connect the Scart lead from the DVD Unit directly into you're sky box. It works fine.
Apr 04, 2010 | Sony Audio Players & Recorders
Lost our freeview. New TV in bedroom (Sharp LCD, LC-19SH7E-BK), which has freeview and was working fine. However, we set up a magic eye so we can have SKY (which we can now use through channel...
if you have connected your sky box as per instructions, putting the aerial coax to it and a fly lead(as in a male to female coax as used on a vcr to tv) from the output to the tv's aerial input, then disconnect the aerial from the sky box and put it back to the tv. The skybox will weaken and even loose the signal.
Feb 14, 2010 | Televison & Video
When i plug my new tv into the sky box via a scart, the tv picture is distorted and a major buzzing noise is coming from the tv. sky have checked and said the box is fine. when u connect to another tv it...
Have you tried another scart lead? Also tried all of the tv scart sockets? Don't try and cure this by using an expensive upmarket scart lead, you'll just be wasting your money. The cheapest leads work just as well when the function correctly.
You could also try reversing your current lead by swapping the tv end to the Sky box and vice-versa, as there are many leads which cause feedback issues, and also a lot of "cut" leads (designed to prevent feedback looping) which must be fitted the correct way around. A "cut" lead is one where the wire to pin 19 at the tv end and to pin 20 at the video/Sky box end has been cut.
Note that scart leads MUST be fitted with the tv and Sky box switched off to avoid damage. Most people (including professional installers) regularly ignore this precaution though.
If all else fails then take the tv back and exchange it under the Sale of Goods Act; it's certainly not uncommon for new tv's to have faulty scart sockets.
If I've solved your problem then please take a moment to rate my answer. If not, then please report back with the make and model of TV and I'll try a more specific answer.
Jan 14, 2010 | Televison & Video
Sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
service,
4,
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Aug 16, 2009 | Televison & Video
Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Jan 19, 2008 | Televison & Video
Kenmark tv/dvd combi
if the magic eye is used in conjunction with an aerial cable you have to retune one of the analouge channels .
this should be in the opperating manual.
if you no longer have this try www.tvs-services.com
Dec 26, 2007 | Televison & Video
Tv is stuck on av channel
no-not the tv try buying another remote from the manufacturer and that will solve the problem
Jan 06, 2007 | Grundig GF70-600 TV
Televison & Video Logo
1,174 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
