Question about Nikon Coolpix L11 Digital Camera
How to replace nikon coolpix l11 battery door
I have a new battery door.
How do I install the door?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Take the 7 screws out around the edges and use a flat tip screw driver pry the case apart between the back of the battery door and the case just enough to slide the pin out with needle nose pliers, remove the old door put the new one in place, reinstall the pin, squeeze the case back together and reinstall the screws and your done!
Posted on Sep 15, 2009
    New Friend:
how to replace nikon coolpix l11 battery door - aa984572-0b17-448d-9c5d-4922b792e02b.jpg
Why replace the door when you can go down to the hardware store and buy a Socket screw, also known as Allen head are fastened with a hex Allen wrench. Find one that will fit in the camera tripot, They don't make them short, so you will have to cut off part to make it screw all the way down. The find you a metal strap, cut it long enough to fit over to the battery door. Round off any edges. and your all set. Cost is about a 50cents to fix
Posted on Sep 27, 2013
  • Steve H Sep 28, 2013
    I made this set up when I dropped the camera and broke the latch that keeps the battery door closed. I used a soft bendable strap that is used to hold pipes. Cut the metal to 1 1/8 " long and 3/4 wide. Drill a hole for the screw to pass through. Tighten down using your finger tips. This will keeps the batter door closed, but makes it easy easily remove the batterys. Saves you from having to find a battery door
    Some more pics of the fix
jackboy
  • 2985 Answers
SOURCE: Replacing the battery door on a Nikon CoolPix 4600
Tape it. Replacements not likely Check out Nikon support to be sure.
Posted on Sep 22, 2007
  • 4 Answers
SOURCE: Nikon coolpix L11
well have you got a card reader? if you have then plug the memory card into the wright socket and see what happens
Posted on Jan 12, 2008
PAPA-RAZI
  • 37 Answers
SOURCE: Nikon Coolpix L11 camera
FIND THE USB OPTION IN YOUR CAMERA MENU AND SELECT MASS STORAGE OPTION, THAT WILL ALLOW YOU TO CONNECT & VIEW THE PHOTOS LIKE A REMOVABLE HARD DRIVE OR JUMP DRIVE
Posted on Aug 11, 2008
robmcd27
  • 423 Answers
SOURCE: nikon coolpix L11
I'm sorry but you can't use the camera as a webcam. Here is why. There is no function on the camera to stream video.
Also, the camera goes into standby mode after 30 seconds (by default). And 3 minutes after that, it shuts off completely. It does that to save batteries. Again. I'm sorry. Good webcams average between $20. to $50. usd and they are made to work 24 hours a day 7 days a week.
You can use a 4GB memory card in your camera, as long as it's an SD card.
If you get that message, it means you haven't formatted the card for use in that camera. You have to format the card in the camera before you use it.
Even though the solution was not what you prpbably wanted, don't let it stop you from rating it a fixya. I would appreciate it. Let me know if I can help you with anything else, and thanks for coming to FixYa.
Rob
Posted on Feb 23, 2009
  • 102366 Answers
SOURCE: I need the drivers for my nikon coolpix l11 camera
http://support.nikontech.com/app/answers/detail/a_id/61
Posted on Dec 27, 2009
How to change battery.
Look for a battery door on the top of your thermastat. Normaly you slide the door open. watch how the old batteries are polorized, re install new alkaline batteries in the same place and close the battery door. Your low battery indicator icon in sight window should be off. Walla done now cool off.Later.
Nov 28, 2012 | Heating & Cooling
Tip
BATTERY INSTALLATION FOR CLOCK : OPEN THE BATTERY COMPARTMENT DOOR. DRIVE THE...
FOR CLOCK
OPEN THE BATTERY COMPARTMENT DOOR. DRIVE THE SCREW
OUT AND INSERT 1 NEW UM4 1.5V BATTERY INTO THE
COMPARTMENT FOLLOWING THE POLARITIES AS INDICATED.
DRIVE BACK THE SCREW TO LOCK THE BATTERY
COMPARTMENT.
FOR RADIO:
INSERT 4 NEW “SIZE D” 1.5V BATTERIES (FOR RADIO) FOLLOWING THE POLARITIES AS INDICATED.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Garage keypad not working. Installed new battery, reset code and it worked once.
You normally would not have to reset the code after replacing the battery. It remembers the code. I think you have a bad keypad or maybe the battery or battery connection is bad. Even a new battery can be faulty at times.
Jan 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
How to remove the passenger door and replace it with another door on a 1994 lincoln town car.
Removal & Installation
NOTE Two people are needed to remove and install the doors.
  1. Disconnect the negative battery cable.
  2. Detach the necessary wiring connectors.
  3. Matchmark the door hinges to the body. This will aid in alignment when installing the door.
  4. With an assistant supporting the door, remove the hinge retaining bolts and remove the door.
NOTE If you are using a jack or similar tool to support the door, be careful not to damage the paint.
  1. If the door is to be replaced, transfer the following components to the new door if in usable condition: trim panel, watershield, outside moldings, clips, window regulators and door latch components.
To install:
  1. With an assistant positioning the door, install and partially tighten the hinge bolts.
  2. Align the door and tighten the bolts to 19–25 ft. lbs. (25–35 Nm).
  3. Attach the necessary wiring connectors and connect the negative battery cable.
Feb 10, 2010 | 1994 Lincoln Town Car
How to replace key door openere battery The remote door lock device reqires a new battery. How do I replace it?
there is a little screw in back ,remove then install a coin or small screw driver in the middle and snap on unit, remove battery keep in mind which way battery sit in at, then install new one, and put back together,no programing needed should work if a battery is the problem good luck, hope this helps.
Oct 12, 2009 | 2007 Saturn Aura XR Sedan
Need to reprogram door locks for 2004 Toyota Camry
I recently replaced the battery on my 2004 Toyota Camry. When I installed new battery the door locks will not stay unlocked once opened with remote. How do I reprogram?
Feb 21, 2009 | 2005 Toyota Camry Solara
KEY WILL NOT UNLOCK DOOR AFTER INSTALLING NEW BATTERY
First dissconect the battery and try to turn door key with no voltage applied to vehicle. This will ensure it is not a damaged key. If door locks turn, reconnect battery. Hopefully during disconnect your electronic door locks de-energized. If keys don't work with battery disconnected then the fault doesn't have to do with your battery or electric locks at all. If they work with a disconnected battery and not with it connected you are have an electrical short, either in a switch it's self or the wiring to the door lock switches. In this case I recommend taking the vehicle to a shop for repairs, electrical can get in depth without proper tools and diagrams
Nov 24, 2008 | 2003 Chevrolet Silverado 1500
Battery compartment door
Only by examining the camera your self will you find out If you managed to purchase a part- perhaps an installation diagram is available from the same source.
Jul 31, 2007 | Kodak EasyShare DX4530 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
1,601 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
