Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Lamp power supply board on Panasonic PT-50LC13 mulfunction.
I have no picture. Lamp changing light flashing.TV its not turn ON.Power button flashs ''GREEN'' for a while,and then flashing''RED'' not turning ON.Sounds OK. I changed lamp still the same.I called master. He diagnoze with ''Lamp power supply board not working''. He Quotes $382 to fix. What you think. Please advise.
    President:
  • Panasonic Master
  • 1,779 Answers
You can purchase the lamp supply thru "Encompassparts.com... The cost is $100.00, there is a $250.00 core charge on that module, so when you return the old they refund the 250. Initial investment will be 350.23 then take the 250. off that. That will be the end cost.
Part # LSEB3087A
Posted on Apr 16, 2009
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Pt-50lc13 tv...where is the ballast located, and will a bad ballast cause the power button to flash red and nothing else to happen?
Hi, if you take off the back cover of the TV. Once you take the cover off there is a metal plate in the middle that has to come off. Behind the metal plate you will see a metal box with holes in it, thats the ballast board. It can be a number of things. It can be the ballast board or the power supply board. Take the back cover off and turn the TV on. You should hear the ballast board trying to fire. It will try at least 3 times before stopping. Is your lamp light on in the front of the TV.
Thanks for using Fixya, If you have any other questions please let me know.
Jan 25, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Picture went out and red light on bottom panel saying Lamp was flashing....bought new lamp...replaced....no picture...lamp light still flashing
Hi, sorry about that. I hate that to when you buy something and it doesn't fix you problem. It is either your lamp ballast board or your power board. If you take the back cover off and turn your TV on listen to hear if you hear your ballast board fire up. The lamp looking at the back of the TV with the cover off is located to the left side. You should listen there to see if you heat anything and if not then more than likely its your power supply board that probably got zap but a surge.
Thanks for using Fixya and please rate..
Jan 21, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Tv will not power up
yellow flashing power light codes: flashes 1 every 5 secs = one of 3 fans not spinning. 2 every 5 secs.= lamp cover open.
5,6,7,8,9,or10 x per 5 secs. are power supply voltage errors.
Apr 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
The tv will run for a few minutes then it will shut down .
You probably need a replace lamp or power supply board. You can buy lamp at Advanced lamp website for $115 with shiping . Replasing lamp no problem,anybody can do it. Very easy. I am not sure about Power Sypply board,but I think you can buy for $100 not sure how replased.
Apr 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Reset Time Problem on Panasonic TV (PT-50LC13)
Power on the set, listen for afaint buzzing sound as the set tries to fire up. If you do not here it then your lamp driver, or ballast is most likely faulty. Also make sure you have the door and all covers back in place and secure. And make sure you insatlled an orginal panasonic lamp because some generic will not work.
Jan 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13
It could be the ballast that is bad. A bad ballast also shortens the Lamp life .
Jun 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
461 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
