Question about Home
Fills with water but dose not adgitate is it belt driven?
Fills with water but dose not adgitite
  • 39 Answers
Bad belt or motor or belt came off.Take off back cover and see if the belt is on.If you cycle to drain does it empty?
Posted on Jun 29, 2009
Washer will not adgitate during wash cycle. what may i look for to try and fix ?
What is the model and model number of the unit? It could be the transmission or the coupling between the motor and transmission. On some models it can even be the lid switch
Jan 04, 2015 | Washing Machines
Why dose the water notstop filling
first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? sometimes they get busted open or a pin hole and release air causing the water switch diaphram to not open. if both check ok then next the motor coupler or belt if belt driven.check with a multi meter for continuity the door switch, and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Oct 09, 2014 | Maytag Legacy Series Top Load Washer
Washing machine dose not aditate anymore
pull up the agitator, you may need to get a belt wrap it underneath and yank it up, please be careful that it doesnt hit your eye and under the agitator is a coupler or bell that needs to be replaced, it is stripped, loosen the bolt and replace
Mar 07, 2010 | Frigidaire FEX831CS Top Load Stacked...
Water not pumping out spray arms.
clog in the arm. It should spin due to water flow.
Remove the arm. Usually a tow part arm (top and bottom). Or a central screw with cover plate.
Look for a clog and remove.
If a central arm in the middle of the machine the clog can be in the pipe supplying the water. Again take apart and look for a clog.
They are not belt or gear driven. Simple water driven parts only. If the water is flowing and not leaking under the machine you should be OK with a simple clog somewhere.
Mar 07, 2010 | Kenmore 24 in. 17283 Built-in Dishwasher
The vacumn runs but brush dose not turn belt is good. It's a dyson 110 us c 10417
Now is it air driven or belt driven? It could be the belt that's not turning the brush. Check if the belt is loose or is broken. If it's air driven, then check and see how the condition of the bearings are. If it doesn't roll smoothly then you need to replace the brush roller. If it does roll smoothly then check if there's a blockage in the line.
Jul 28, 2009 | Vacuums
GE WASHER WJSR4160GWW Won't Agitate
Sounds like tub belt failure. Check online for model layout. If unit is belt driven, remove back panel to access internal works. Look for broken belt. Depending on setup, control system stuck on water pump. Else possible control panel failure or motor (if water pump separate).
Jul 10, 2009 | Washing Machines
Washer is over filling.
AV,
Yup! I know what's going on (the tip off was when you said, "The water does stop when I push the timer off"). See? the timer, as I'm sure you know, supplies or "directs" power to each component in the washer... kinda like a conductor does an orchestra. When you push the timer knob to "Off", you shut down the symphony thereby removing power from all of the components. Make sense?
When you set the water level and pull the knob, the level switch tells the timer that the tub is empty and request water. The timer complies and sends power to the water valve. When the water level is "satisfied", the level switch tells the timer to remove power from the valve and start the "agitation" cycle.
Here's what's happening, the level switch isn't talking to the timer. I think the part number is 22002705, but I'm not sure because I don't have the full model number. Call you local appliance retailer and provide them with the full model number to be sure, OK? Since you already have the machine apart, it'll be easy to replace...
Oh yeah, here's a picture of it... see if this one matches the one on you machine. This might confirm the part number.
And another thing, now that you've experienced a washer flood (ain't it fun?), you might want to consider getting yourself one of these. They're super easy to install and it'll provide that extra bit of insurance against this happening to you again.
Don't forget to rate this solution. And thanks for using FixYa!
SG
May 30, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool top load belt driven commercial --spins while agitating
tobe a belt driven wp it would have tobe pretty old,if so its down in the cam bar area.the feet or plungers break and the cam bar dose not pull back.i would remove cam bar and file to clean up or replace if to worn along with new plunger.also use lite greese on cam bar where it slides and on bottem of blungers.also check the condition of your wig wag[control magnet.May God bless your house,tom
Jan 02, 2009 | Whirlpool GSC9455 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
