Question about Acer Aspire 4930-6862 Laptop
Bluetooth device not found
Please varify that your Bluetooth device is properly connected and turned on.
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
I click 'turn adapter off' on bluetooth icon in task bar and now i cant transfer using bluetooth anymore. when i try to send file using bluetooth, message appear like this "bluetooth device not found....
you was torn off your bluetooth, go to control panel> bluetooth device and you can enabled your bluetooth device tthere
or use shortcut key Fn+F3 to turn on or turn off your bluetooth device
i hope this helpful
thank you for using fixya
Feb 08, 2011 | Acer Aspire One PC Notebook
I am having audio drivers for my pc but i am not able to get the sound from my pc so what might be tje problem..........
The first place to begin would be to varify that all cables and external connections to speakers or headphones are properly pluged in. Try a diffrent set of speakers or headphones. If that dosnt solve the problem check the volume control and varify that the device volum is turned up atleast halfway. Make sure that the volume is not muted. Generaly there will be a check box under each volume type that must be unchecked for the volume to be controled.
If the above dosnt solve the problem you will need to determine whether the device is functioning by finding the device within the "Device manager", the device manager can be found within the control pannel under hardware.
You want to varify that the device is indeed in the list, and that there are no exclamation points or circles with a line through it. These icons would indicate an error, and are generally yellow or red to catch your eye.
You will want to expand the catagory that is listed as "Sound, Video and game controllers", find the audio device and right click on it. After you right click select Properties from the drop down menu and varify that the device status indicates that the device is working properly.
If the device is not working you will want to obtain the latest drivers, and uninstall the device. When reinstalling the device be sure to specify the location of the driver you have obtained from the manufacturer.
If these steps do not work, or you discover an error that you can not correct, you will need to consider the possibility that the device has maulfunctioned.
If you have access to another audio device you may want to try that device to rule out a failure caused by something else such as a shorted wire or a bad plug jack.
Jul 15, 2010 | Computers & Internet
Presario r3000 when i click on bluetooth icon it just says no devices found what can i check
If you are not able to connect or configure the Bluetooth then please check the steps and the link below which will help you to connect it properly.
  1. Click Start , click Control Panel .
  2. Click Switch to Classic View and click Bluetooth Configuration .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00583172&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN#c00583172_M4
If any issue persist, please get back with product no. which is at the bottom sticker.
May 31, 2010 | Compaq Presario R3000 Notebook
How to use bluetooth in acer aspire 4710?
if you have in on your laptop you have to get the software for the bluetooth then you must install it on your laptop then it will be done , if you don't have that CD you can downloaded from the technical support for ACER.pan am
Jul 01, 2009 | Computers & Internet
IBM T43 Bluetooth not working
Press Fn+F5 then push "Turn On. Now your bluetooth device is turned on, connected and working. :P
Jan 06, 2009 | IBM ThinkPad T43 Notebook
Open Questions:
See all Acer Aspire 4930-6862 Laptop Questions
Acer Aspire 4930-6862 Laptop Logo
189 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
