Question about Copystar CS-1810 Copier
Won't print documents from computer! PLEASE HELP! ASAP!
This problem only happened today. I didn't change any settings. OS: Windows XP Wireless printing, using linksys Printer: Copystar CS-1810 by Kyocera I'm using IP-address for connection. I'm also using HP Photosmart C7180 on the same network with the same IP(192.168.15.103). I've noticed that when I choose the 1810 printer, the document prints out of the HP printer. I've tried to change drivers, set the printer to default but nothing works. Please help me out this is really frustrating. Thanks ahead of time!
  • cloudstrif3 Sep 17, 2007
    Then go to the copier and thorugh the user panel get into network settings and enter the COMPLETE IP number just typed in Windows. It should work.
    How do I do this??
    So the last 3 digits can be any random number?
  • 161 Answers
You cannot use an IP number for more then one device. It is an unique identification number. On the PORT section uner the Windows driver, change the last three digits for the Copystar machine, do not change the other ones (keep in mind that it should be unique!). Then go to the copier and thorugh the user panel get into network settings and enter the COMPLETE IP number just typed in Windows. It should work.
Posted on Sep 17, 2007
  • Felix Lopez
    Felix Lopez Sep 21, 2007
    Apparently, your issue requires the attention of a professional. First of all, the instructions on navigating through the menu are in the copier user's guide o network guide, depending on the manufacturer. You will waste less time reading the step-by-step procedure than waiting for someone to explain here. Second: the IP address is a distinctive number that identifies every peripheral on the network. This includes: copiers, printers, computers and others. Therefore, it cannot be any random number because you risk using one already taken causing further conflicts in your network. Any PC specialist with A+ certification can prepare a list of the IP's in use and assign a suitable one to your copier.
SOURCE:
Brother HL-2270DW printer shows offline and won't print
I had this problem today with my wireless Brother MFC-990CW using Windows 7, and when I went to see what s printing, then printer, it wasn t showing that I had checked the use printer off-line
So, on my pc I went to the start button then chose:
- Computer
- Network
- Double click your printer
- New print drivers will start to install
- Right click the icon that is a copy made of your printer setup
- Set this as your default printer
I was then able to print and my printer didn t show as being off-line anymore. This is a lot easier than having to uninstall and install the printer again using the disc.
Source(s):
https://answers.yahoo.com/question/index?qid=20140422184955AA0dJ7F
Jun 27, 2012 | Brother HL-2040 Laser Printer
Tip
Canon pixma mp560 Wireless Photo printer Drivers for Windows and MAC OS
Here I will show you where to find drivers and manuals for the Canon Pixma Mp560 Wireless photo all in one printer.
Drivers for this printer are available for Windows 98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions, windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X 10.3/10.4/10.5/10.6
A full on screen manual, quick start guide and other instructions are also available.
To download these drivers and or documentation for your printer please visit
THIS PAGE
Note that the picture shows Mp190, the actual linked page will be for mp560.
1. Click on Drivers & downloads
2. Select your OS ( Operating system, windows, mac etc )
3. All available drivers, documents etc will be available below.
For some of the documents a PDF reader may be required to open and read / print them.
To obtain a PDF reader, read this page
PDF Documents. Pdf reader(s)
Thank you for reading and I hope your printer is up and running again.
-Ekse
on Mar 11, 2010 | Office Equipment & Supplies
Sipix Pocket Printer won't print.
First check to make sure that you have the correct com port selected.
then set the com port to use these settings.
11520 Bits per second
8 data bits
no parity
2 stop bits
hardware flow control
Jul 15, 2017 | SiPix Pocket Printer Thermal
I want my monitor to work once again because it says cannot display video mode? i dont understand help me?
You didn't say which OS you're running. However, it looks like you need to restart your computer in safe mode. This URL explains how to get in safe mode. When the computer boots the video it will look a bit grainy and you won't be able to see the entire desktop without using the scroll bars.
Both XP and Vista don't allow you to perform such an operation through the regular procedure and, as a result, you will only be able to get a screen resolution of 800×600 with the consequence that some icons and programs won't be displayed correctly. This is because Safe Mode just loads only basic services and drivers which are strictly necessary for Windows to run.
Fortunately, by employing the following techniques, you can get around this restriction permitting you to get whatever screen resolution you want.
Windows XP:
  1. Right click on your desktop.
  2. Click Properties.
  3. Click the Settings tab.
  4. Under Screen Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced.
  6. On the new window click OK, without modifying anything.
  7. Done, you should have successfully changed the resolution settings.
Windows Vista:
  2. Click Personalize.
  3. Click Display Settings.
  4. Under Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced Settings.
  7. Done, you should have successfully change the resolution settings.
Aug 11, 2011 | Dell 1503FP 15" LCD Monitor
My Epson RX 620 will not print anything from the computer with Vista
Have you tried running a print test page? Have you gone to epson.com website to see if they have printer driver available for your printer...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&infoType=Downloads -
Jun 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Oficejet v40xi only prints partial documents then "disconnects"
XP the virus magnet where anything can happen bad, and DOES !
why run 15year old OS.? why not upgrade.?
The Lenovo stinkpad. (was IBM)
why not move the printer to another PC, ? to prove printers bad
is that hard?
even plugged in to any LAPTOP, say with W10
v40xi , as old as 2003, is yours that old?
was even run on old windows 98 back when.
but has HP support up to windows 8.1
try printer on win7 win 8.
is the way to do this, using the correct driver. from HP.com
Mar 29, 2017 | HP WanProbe V-Series Network Monitoring...
My canon pixma MP610 keeps printing unasked
Jane P
hi,
try this one i think it can help your problem.
at Start menu you can see printers and faxes icon or you can also see in setting drop down menu, and click it.
if theres a list of many printers, see the one you're using, and double click it. and cancel all pending document to be print.
Tip: please don't click the printer icon several times it will only multiple the printing process.
hope this can help
God Bless.
Nov 26, 2008 | Computers & Internet
Printer multiple page document
Try this only for windows user:
To resolve this, do the following :
  1. Windows 2000: Go to Start, Settings, Printers.
    Windows XP: Go to Start, Control Panels, Printers and Faxes.
  2. Right click on the printer icon and select Properties.
  3. Click the Advanced tab.
  4. Click the Print processor tab. The Print Processor screen appears.
  5. Change the Print Processor to Winprint and change the Default data type to RAW .
  6. Click OK in the Print processor screen.
  7. Click Apply, then OK.
Apr 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
Copystar CS-1810 Copier Logo
195 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
polytek
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
