Question about Kenmore Elite 45986 Front Load Washer
He 3 error F o4
I have had this washer for 4 years, and the paperwork has gotten ruined over the years. I have been able to solve all the other problems without the paperwork-- except this one. Can someone PLEASE tell me what the error F 04 is?
  • laundry girl Sep 17, 2007
    SORRY, MY MISTAKE, IT WAS ERROR 06, DO YOU KNOW ANYTHING THAT CAN HELP WITH THIS ERROR???
    THANKS SO MUCH FOR RESPONDING, IT WAS ACTUALLY AN F 06 PROBLEM, CAN YOU HELP ME OUT WITH THIS ONE?
    President:
  • 1,294 Answers
This indicates a pump fault; could it be blocked; clean out your outlet filter. But it is the pump......
Posted on Sep 16, 2007
  • prem mathew Sep 21, 2007
    Click on troubleshooting above, in Fixya, you will find solutions re your machine. Scroll thru them to find your solution. These displays can drive u nuts.....& the user's manual is not clear on the displays. Best of luck.
SOURCE:
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
I bought a Whirlpool Duet front load washer and dryer two years ago from Lowes. When we put soap and bleach in the washer, the bleach just runs right into the tub. You can see it thru the door window. We...
The common thing to fail is the dispenser door solenoid.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Shows E-o4 not draining water
he machine is a bit different than most washers, so here is help when you get "error 04"...Your pump is plugged. There is a round 'door' on the lower front of the washer. At the 5-O'clock position in the door there is a small hole. Put a small screwdriver blade in the hole, push in (just a little), and you can rotate the door clockwise. When the hole is in the 6-O'clock position, the door will come out and you can get to the problem.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. (We used a pile of towels to catch this). The Black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. In our case, it was a childs sock. We removed it, screwed the black connector back in, and the washer ran fine.
After a couple of loads (to make sure there was no leak) I put the door back on...and rotated it to the 5 O'clock position. And thats it!
You saved yourself about $100 service call, and probably a ton of time waiting.
Mar 01, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Need to know what 50 means --washer keeps beeping after tub fills
Please see the following Whirlpool Service Manual for their Cabrio Washer (Basically the same as the Kenmore Oasis)
50 points to an obstruction keeping the basket drum from turning freely.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Nov 08, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
E o4 displays. will not unlock. tried pouring
turn off at mains checking no water left in drum should release after that sound like faulty door lock or not draining fully, it wont let you open the door till the water has gone well below the door seal.
Oct 27, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Suds then f 35 error code then machine shuts off
try clean drain pump. be careful their lot of water in you washer. remove front bottom panel to get to drain pump. i hope i will solve your problem.
May 23, 2009 | Washing Machines
Ob error, out of balance?
may be bad basket drive ..main control detects out of balance by currect draw on motor had a basket drive cause same sympton .. after replaceing control bds and motor changed basket drive and solved problem
Jun 05, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HELP GREASE RUINING CLOTHES IN WASHER
over 5 years or cost over 250?
 throw it away, and get a Whirlpool
Oct 21, 2007 | GE Profile Prodigy WPSE4200A
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
35 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
