Question about Frigidaire PLMV169DC Microwave Oven
1100 dead problem
I want asolution about nokia 1100 dead problem
  • Frigidaire Master
  • 9,174 Answers
You might get more help if you post in the Nokia 1100 section instead of the Frigidaire microwave section. See http://www.fixya.com/support/p401621-nokia_1100_cellular_phones
Posted on Sep 22, 2007
6ya staff
SOURCE:
GE xl1800 I have checked both fuses and still no power to the control panel. What is the next failure?
someone needs to follow the voltage into the unit--- The voltage goes to fuse and then to inverter that drives the unit---fyi if unit is not real expensive a repair may not be practical----use some precautions if not familiar with this kind of appliance.
Jun 08, 2012 | GE XL1800 1100 Watts Microwave Oven
My countertop microwave stopped working. What was the problem? Can you help?
If it is completely dead, no light, motor or keypad, it's probally a blown line fuse. Open up the cabinet and you should be able to find a fuse near the power cord. An appliance supply house should be able to get you a replacement.
Apr 18, 2011 | GE XL1800 1100 Watts Microwave Oven
The 2 screws on the bottom of the stainless steel panel in back have a hexagon head that I can't remove. What type of screwdriver do I need? I want to try and replace the fuse because it is completely...
You need a "nut driver" -- probably either 3/16, 1/4, or 5/16 ". If you have one of those 5-in-1 screwdrivers you see at shopping counters almost everywhere these days, one of the nut drivers on it will probably fit.
Charlie
Jan 08, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Yesterday, my sharp carousel r-1460 went dead. I took apart the front keypad and replaced the 20amp fuse behind it. the microwave light and fan work.But, when I start microwave to cook something, pop! fuse...
If the 20A fuse is blowing, it is often the high voltage transformer or magnetron. If this is the case, and the microwave is not under warranty, replace it. Residential microwaves are generally considered disposable. Parts and labor are just too expensive. A magntron or transformer can cost more that half the cost of a new microwave.
Feb 24, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
MW8115SS worked perfectly and then went dead
Blown fuse , take the outer cover off and change the fuse. Iff you don't have a fuse use a piece of tin foil until you find a replacement fuse.
Hopefully this helps you out.
Aug 18, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Does not heat
is there light in it... if its completely dead..if yes, check main fuse inside and then check lamp also...
if it is getting on but not heating then u need to check the magnatron...the source that cause heating..
goodluck......
Aug 14, 2009 | GE XL1800 1100 Watts Microwave Oven
Sharp microwave is dead
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/xformer.html
You can usually find exploded views Sears parts site.
BUT Once you have the part numbers, the best place to order Sharp parts is Tritronics.
Dec 01, 2008 | GE XL1800 1100 Watts Microwave Oven
Emerson 1000 watt microwave
This appliance still under warranty, I would suggest to call the manufacturer and ask them for the nearest authorized service center.
Make sure you have the receipt where and when you bough it.
Good Luck.
Mar 12, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW 8115SS
There is a 20 amp replaceable fuse inside the cabinet next to the power cord
Aug 17, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
90 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
