Question about Dryers
Electric dryer w/ no more heat
I have an older model hotpoint dryer...everything works but there is no heat! i have removed all the lint, cleaned all motor connections? any suggestions what to do next besides buy a new one or pay a service man
  • sanfranfanin Apr 17, 2009
    i dont have a meter!
  • Jerome Barbin May 11, 2010
    Do you have a meter that reads ohms?
  • 77 Answers
For safety sake there is no safe way to check it if you don't have a meter. Or you novice at fixing things? I'm trying to think safe for you.
Posted on Apr 18, 2009
  • Jerome Barbin Apr 18, 2009
    At this point, without the meter, you should probably replace the dryer, because a service call will be at least a third cost of a new one. Good luck.
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 30, 2015 | Roper REX3614KW Electric Dryer
My condo has a Hotpoint dryer. It is about 3 years old and last fall it no longer dried. I took the dryer hose off from the wall and the dryer works fine, heats the condo. The dryer vent goes into the...
Hi.
With most Hotpoint/GE dryers the blower motor is not spin by a belt. The problem is unlikely the blower motor. The problem is lint in the air ducts and in the blower housing. The lint results in overheating and the high limit switch cuts off the power to the heater (burner or element depending on the model).
As a result the dryer does not heat up.
Access the heating group and remove lint from the air ducts. Also clean the lint filter.
Hotpoint appliances are built by GE. Below service manuals for different GE-manufactured dryers:
Technical Service Guide
Service manual
ELECTRIC & GAS DRYER SERVICE MANUAL(Kenmore)
Jun 14, 2011 | Hotpoint Dryers
Hotpoint nvlr333etowb no heat.
Diode? Ain't no diodes. 3a90295.jpgIf all of theses items check good you might have a burred contact inside the timer. These dryers have a timer that is easy to take apart. Gently remove the motor and cover, look for a burr between the leaf switches. File em down smooth. Let me know.
May 08, 2010 | Hotpoint NVLR333EE Dryer
My hotpoint dryer doesnt dry well. What do i must review?
Electric dryer? Try cleaning lint from the vent & inside the dryer - unplug it, remove the back, vacuum everything including inside the exhaust vent which you may be able to access better by removing a few screws. Poor airflow caused this problem with my dryer.
Nov 19, 2009 | Washing Machines
Kenmore Elite HE3 Gas Dryer - Heat flame will not ignite
The Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jun 20, 2009 | Hotpoint NVL333EY Electric Dryer
My hotpoint tdc32 works fine for about a minute then just switches off. i try to restart but the on button just does'nt do anything. when i open the door the clean filter light comes on but ive cleaned...
My best guess is that air flow is blocked in the dryer vents or internal ductwork, allowing the dryer to overheat and trip the safety thermostat, shutting the dryer down until it cools off enough for the safety thermostat to self-reset.
Try using a long brush to clean lint accumulation through the front air flow vent, then remove the vent hose and clean from the rear. If that doesn't do the trick, you may have to pull off the front panel to get to the 'innards' of the dryer to further clean accumulated lint from the duct.
Lint build-up around one of the safety thermostats can hold enough heat to cause the thermostat to trip very quickly... Before the dryer has actually had time to heat up very much. The termostat has no way of 'knowing' that itself, and not the dryer, is overheated. BE SURE when working with any appliance that you disconnect the electrical connection before servicing.
Jun 11, 2009 | Hotpoint Dryers
Hotpoint Dryer Heat stoped working
Loook inside door an get me the model number. The heat thermistat and the high limit switch will possibly need replaced. Enter the model and part numbers in the search feature on my site below. We offer free help and assiatance also. Thanks, Sea Breeze seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Hotpoint Dryers
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
Jan 31, 2009 | Kenmore 62602 Electric Dryer
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
