Swith ON the TV (Red led always on)
Hi there!!
Everything was normal until today. I can't switch ON the tv and keeps the red led on like if it is on stanby mode. I checked the main connections and cables, remote control batteries... nothing seems to work!
Are you able to help me? Many thanks! Luisa
  • lmatosdeoliv Apr 16, 2009
    I'm sorry but even with 5, 10min is stil the same! I tried with remote control and pressing the ON/OFF button but not working. =(
  • 10,865 Answers
Hi there. Un plug your TV, wait two minutes and plug it back in.
Posted on Apr 16, 2009
Have grundig gu22dvd tv and can not get volume on the sky remote have tried the normal things and have code but still doesn't work
Try an auto search with the remote, you might have already tried it :
1. press tv
2. press select and the red button simultaneously untill the LED light flashes twice
3. Then keep pressing the TV and Standby buttons one after the other (not at same time) until the tv swithches off, then press select to store the code, the LED should flash twice to confirm this.
Once you have the remote working the TV, you can get the remote blink back the TV code so you can write it down for future reference.
  • Press the TV button on the Sky remote
  • Hold down Select and the Red buttons together for approximately two seconds until the LED blinks twice
  • Key in 9, 9, 0
  • Key in 1 on the numeric keypad and count the number of times the Red LED blinks. This is the 1st digit.
  • Repeat for 2 and 3
  • Note: no Blink = 0 (zero)
Sep 09, 2014 | Grundig GU22DVDPX 22 in. LCD TV
Sharp LC40LE600E wont turn on
Had exact same symptoms as Keran. Turned out to be my daughter had turned the TV off with the other power switch which is a button on the right hand side of the set - we always use the rocker switch on the left hand side and had forgotten about the button. Turned the rocker switch on, then the button and it was back to normal.
Jul 19, 2012 | Sharp Televison & Video
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Optoma RD50 TV which shuts down on #1 fan failure
This could be a variant of, or a newer (or older) version of the "DMD fan failure" message.
Symptoms I had are, I stop hearing a fan when the message is displayed.
Then the temp LED keeps flashing RED until I either try to turn the TV on again,
Or turn MAIN power off/on again. BUT it repeats when I try to turn the TV on.
The picture appears normal until this happens ( about 15 sec.)
The solution is to FORCE a normal shutdown by hitting the TV off button
before the message appears.
You should see the power LED flashing RED/GREEN (cool down) and then RED (standby).
Apr 20, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
SKY REMOTE
Press TV
Press and hold Select & Red until the LED blinks twice
Press TV
Type in code 0 0 6 0
press the Power button on the remote, if the TV turns off press the select button and everything should work, if the TV stays on press the TV button on the remote then the Power button again, keep doing this until the tv turns off, when it does press the Select button and all should be ok.
Feb 01, 2009 | Toshiba MR120 Remote Control
Dell 1110 Laser Printer Solid red warning light
Hi in this case the paper jam made some sensor through the paper road they are not in normal position or still tigger on by piece of something or error stander. you may try:
1) check paper input sensor near paper tray roller\
2) check margin sensor inside paper way before drum unit
3) check fuser sensor near fuser unit
4) check paper output sensor near output tray roller
sometime need sensor adjustment back to normal position
Dec 22, 2008 | Dell 1110 Laser Printer
Trouble Turning On
is this a lcd projection or just tube projection
Nov 15, 2007 | Sony KP-46WT500 46" Rear Projection...
Philips TV 32PW9763/05
This is is due to a faulty resistor probably the B+(R950)..On the power supply control circuit..If you know how to use a multimeter you can easily find the faulty one...And replace it.However if you are not good at electronics i advice that you give it for service coz its not gonna cost you too much..Dont delay the repair as it can damage the more expensive components in the Tv.
Eagle.
Oct 16, 2007 | Televison & Video
Not switching on
My NEC PlasmaSync did the same thing.  It's caused by not using a power filter on your AC input.  To reset your TV, turn off the power button on the bottom until no lights are flashing.  Then hold down the "Input Select" button while holding down the "power" button.  The tv should then reset.
Sep 04, 2007 | NEC PlasmaSync PX-61XM1A 61 in. Television
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
