Question about Dell E173FP 17" LCD Monitor
Dell E173FPc 17" LCD Monitor Problem:
Hello i have a Dell E173FPc that will not power up at all dead, does this model have a common fault.
  • 2 more comments
  • Anonymous Feb 29, 2008
    The screen remains black and the green power light continually pulses.
    I've tried the monitor on another computer with the same results.
  • adzki Feb 29, 2008
    I have the same problem,with a randomly blinking power light and no screen at all,the problem is with a Dell E173FPc,not E173FPb,is there a specific component that can be replaced?
  • ilted Aug 10, 2008
    I had the same problem with one I got free at a yard sale this afternoon, green light would only come on for a split second. Opened it up and there was C922 all bubbled over. Found a spare out of an old busted atx power supply that was the same value and same 16v rating as the original. If I was buying one I would definitely go higher but this one is working fine. Thanks AndrewWro.
  • Anonymous Nov 04, 2008
    Same thing happened to me. Is the repair an inexpensive one?
    Scholar:
  • 32 Answers
Although similar, this monitor and the associated repair is different than the "b" version. The link above is good to follow for finding out how to open your case but the actual repair is different. If you have minor soldering skills (really the de-soldering is the hard part) and can use a phillips screw driver you can make this repair.
I contacted Tom at a link I found on the "b" site and he sent me the typical components to fail for the "c" monitor. $20 and $1.35 for shipping. The site looks to be down now so I'm not sure if this is temporary or he's stopped selling parts. He is also willing to fix the board if you send it to him. Here's what you need to do:
Replace C922 and C923 with 1000uF 35V caps
Replace c924 and C925 with 470uF 25V caps
Re-solder L201 and L202 with fresh solder.
I did all of the above and the monitor works perfectly. When you take the monitor apart make sure you note where the blue and pink wires go (you'll know what I mean when you get to that stage). The connectors are identical and it would be easy to forget which way they were installed.
Posted on Aug 09, 2008
  • SassyFresh Nov 16, 2010
    I had the same issue (monitor would turn on for about two seconds, then backlight would go out) - After digging through multiple forums this was the only relevant information i could find for this specific monitor ("c" version). Being as i did not have the capacitors on hand but i did have the power supply board out of the screen i went ahead and resoldered all of the transformer connections (it was easy to spot the ones that had gotten warm). Out of curiosity i put it all back together (having replaced no components) and what do you know, IT WORKS!!!
    New Friend:
I had this same issue (screen would turn on for two seconds, then the backlight would shut off)...
This was the most relevant solution forum i could find for this specific monitor (E173FPc). There were several posts for the "B" version but it contains a completely different power supply board than does the "C" version.
After reading the solution about replacing the four capacitors and resoldering a couple components I went to work to track down the components necessary. I didn't have the caps on hand but the board was out and the soldering iron was standing by so i decided to resolder all of the transformer points (there were several that showed signs of overheating)...
Out of curiosity I put it all back together (having replaced nothing and simply resoldered what was there) and what do you know... IT WORKS PERFECT!!!
Posted on Nov 16, 2010
Friggin awsome info, I wish there were more smart folks who would post what they know... Genius!
thank al gore for inventing the interet by the way...lol ha ha ha JK
Fixed my monitor first try..........
Steven blanshan...
Posted on Sep 20, 2008
    Problem Solver:
  • 3 Answers
Http://www.electronicrepairguide.com/dell-e173fpb-lcd-monitor-repair.html
Posted on Oct 04, 2007
SOURCE:
Will not switch on, no green light totally dead?
These units are known for having issues with the internal power supply board. There are parts called capacitors that fail due to heat buildup in the monitor case. When they die the power supply stops working and you get a dead monitor just like you have. If you can solder then you should be able to repair your unit. We have a free step by step repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/dell-e172fpc-e173fpc-repair/ The repair should take less than 20 minutes to do and cost less than $15 for parts.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 15, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
My dell E173FPC monitor screen is black and doesnot show for more than 2 seconds although the green power button is on.
You have a unit with a failure in the backlight power supply. This is a common problem with LCD monitors after 2-3 years of use. Here is a link to an article we have posted that shows what needs to be done to repair the unit along with full parts list: http://www.ccl-la.com/blog/index.php/dell-e172fpc-e173fpc-repair/ If you can solder then you can do the repair yourself. If you don't care to do the repair we do offer a repair service for the unit, details can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
Where are the inverter transformers on a E173FPc circuit board?
The transformers are the 2 rectangular parts on the power board. If you go to our web site at: www.ccl-la.com we have a step by step repair guide to the Dell E173FPc monitor. If you open your monitor and look at the power board the back lights plug onto the board by the transformers ( the cables will be either pink/white or blue/white ) If you need any more information about repairing this unit just contact us through our web site.
Buddy
Corporate Computer
www.ccl-la.com
Jan 11, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FPc monitor worked fine yesterday. Today, the monitor only stays on for a split second and goes blank. The power light stays green. If we shut off the monitor using the power button and wait 10 to...
The power supply in the unit has died. This is a very common problem with this series of monitor after 2-3 years of use. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide posted on our site at: www.ccl-la.com Our guide gives parts values and location information as well as how to open the unit up. If you don't feel like doing the repair we also offer repair services, see our web site for details.
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
I have a Dell E173FPc monitor. The power flickers on and off.
The blinking power light usually indicates a blown power supply board. We have a step by step repair guide posted on our web site at: www.ccl-la.com If you don't want to do the repair yourself we do offer a repair service. If you have any questions just contact us at the address below.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Nov 23, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
No power to Dell E173FPc monitor; power light doesn't come on
It sounds like you are not getting any power. I would try another power cord to see if it makes a difference.
Jun 16, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Turn on the monitor
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FP 17" LCD Monitor Logo
4,484 people viewed this question
Ekse
Clive
Clive
Alun Cox
