Question about Insignia Digital-to-Analog Converter for Analog TVs
How to connect tv/vcr combination to converter box; has one antenna outlet on back and one white and one yellow outlet in front
    Problem Solver:
  • 5 Answers
Use a RG6 or a RG59 cable and connect the antenna outlet to the convert box
Posted on Apr 18, 2009
Channels not working
have to use in put connection the red white yellow some only have yellow and white red not used these connection on back of tv called line in or video in red is audio so is white some time the connection in on the front must set the tv to line one or 3 depends on set should be a in put button on set if not on remote or try to cannnel up to find input
Feb 06, 2014 | Emerson EWC1304 13 in. TV/VCR Combo
Quasar tv/vcr combo
A converter box is not needed to connect a DVD player to a TV. However, you do need a single cable with red, white, and yellow adapters orconnecterson one end and at least yellow and white on the other end. Ok if you have red; just don't worry if there isn't a hole to plug into.
Feb 11, 2012 | Quasar VV-1302 13 in. TV/VCR Combo
WHAT IS THE CORRECT WAY TO SET-UP TV, VCR, DVD, & DIGITAL CONVERTER BOX?
Connect the antenna to the converter box. Connect the output of the converter box to the vcr. Connect the output of the vcr to the tv. Connect the dvd to the component input (Red-White-Yellow) of the tv (if there is one. If not then connect the dvd to the component input of the vcr.
With this arrangement you will be able to tape programs on the vcr if you want. If the vcr is not on the signal from the converter box will pass through to the tv.
Jul 06, 2009 | Insignia Digital-to-Analog Converter for...
I have an old sanyo vwm 710 vcr. I have a new hdtv. I can play tapes on the tv if I change the input on the tv. I have selected line 1 on the vcr, but cannot get any channels to come on to record. The...
Not really a solution....RCA customer services (from India, I think), says that there is no way with that VCR because both the front and back (red, yellow,white) ports are input, and the only other jack on the tv is the one for the antenna. Since the digital converter is inside the tv, a splitter would do no good.
I would still have to get either a new VCR with the digital converter in it or get another converter box. An atmosphere of bait and switch is covering this hdtv scheme....
Feb 19, 2009 | Sanyo DVW-6100 DVD Player/VCR
Getting my VCR to record from the TV with a converter box hookup
Hook up antenna to converter box then from that out to the vcr's input (red,white, yellow connections are better than coaxial).
Jan 20, 2009 | Insignia Digital-to-Analog Converter for...
Connect to Converter Box
There are a fews ways of accomplishing this.
On the back of your converter box and TV/VCR there are two coxial connections an (OUT) and an (IN):
Step 1. Connect the coxial cable from the antenna to the (IN) connection on the back of the converter box.
Step 2. Connect one end of a spare coxial cable to the (OUT) connection on the back of the convert box.
Step 3. Connect the other end of the Coxial cable to the back of your TV.
I hope that you find this solution helpful. Please take a moment to rate tis solution.
Jan 19, 2009 | Panasonic Televison & Video
How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Jan 01, 2009 | Televison & Video
A converter box for digital tv
of course!, as long as it has some way of connecting it!, via the antenna input or video in (yellow/red/white)
Dec 12, 2008 | Coby TVDVD1350 13 in. TV/DVD Combo
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Connecting to digital converter box
If your tv just has the yellow / white, this means the audio is MONO, wich means 1 speaker, not Stereo, just connect the white onr, and leave the red one out, or... you could connect the audio to your stereo!
Sep 27, 2008 | Samsung CXJ1364 13 in. TV/VCR Combo
Insignia Digital-to-Analog Converter for Analog TVs Logo
82 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
