Question about Canon EOS-AE-1 35mm SLR Camera
Canon ae-1 We have received a Canon ae-1 to use for a class. unable to figure out anything. Even how to open back for film! Unable to find manuel on web
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
To open the back pull on the rewind knob ( pulling up ) until back opens. Check that your 6 volt battery is ok ( ae -1 has an electronic shutter so will not work without a battery ): battery situated on the left hand side of the camera ( if it is facing you ) underneath small flip up door ( lock is at the bottom on the left of the small door ) . Check the battery by pressing the shutter release gently and seeing if your light meter needle moves. No movement ? replace battery. You have two modes for taking pictures : auto which is actually AV ( aperture priority) or full manual : both are set by moving the shutter speed dial on the top right hand side ( underneath film winding lever ).
Posted on Sep 16, 2007
SOURCE:
Hi , I have a Canon AE-1 camera and I'm haviving a problem with the film advance lever . It seems to be stuck . It will not advance. Have you ever come across this problem before? Thanks ,John.
Canon AE-1 35mm SLR is a manual focus camera EOS is Canon's designation of auto focus EOS stands for Electro-Optical System. The problem you are experiencing is caused by several little things that throws the camera, wind and cocking leaver out of synchronization or simply come to the end of the roll. There is a frame counter window just to the left of the shutter release behind the shutter speed dial. Also if you have just loaded film in the camera it may not be seated correctly check by releasing the rewind button, wind the film back but not all the way and open the camera to restart the film.
Diagram
Mar 03, 2011 | Canon EOS-AE-1 35mm SLR Camera
Where is the shutter release button on a Canon AE-1? I am trying to load film in the camera, and the shutter crank "thing" is stuck. do i need to release it with a press of a button???
Did you actually mean shutter release or shutter advance? And to load the film,you need to pull the roll winder upwards. While you pull the winder upwards, it would have a tuck voice and then the back cover would open up. Make sure you have wound the entire roll before you open the back.
Jan 23, 2011 | Canon EOS-AE-1 35mm SLR Camera
I have a Canon AE-1 SLR camera for my high school photo class and it was working fine but all of a sudden my film advance lever locked and now it wont take any pictures, does anyone know how to fix this?
This may not be the problem, but could it be that you've run out of film. The end of the film is attached to the 35mm film canister. When you run out of film it will prevent the advance level from moving.
Sep 02, 2010 | Canon EOS-AE-1 35mm SLR Camera
I can't figure out how to open the camera to load my film
For Canon AE-1, you have to lift up the film rewind knob to open the back.
May 26, 2010 | Canon EOS-AE-1 35mm SLR Camera
My Canon AE-1 Program will not rewind. I shot the whole roll, rewound a little, and then accidentally opened the back cover. The counter reset to S, and the rewind crank just unscrews when I try to...
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
May 21, 2010 | Canon EOS-AE-1 35mm SLR Camera
My Canon EAS Film Rewind Knob is rolling my new film back into the cassette instead of into the camera...please help.
That's what the rewind knob is all about: It will allow you to rewind the film back into the cassette to avoid it to be exposed to the light and therefore losing your pictures.
When loading the film you must insert the film into the receiving spool by hand while the camera back is open. Make sure to advance the start enough so that the spool will 'stick' to the film.
Dec 19, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon AE-1 SLR film Advance lever does not work
Mechanical problem that must be repaired by a technician. It may be time to retire this camera.
Oct 04, 2009 | Canon EOS-AE-1 35mm SLR Camera
I have a canon laser class 9500, i am unable take fuser
Hello sir ; The user manual you get it online, instrction to remove the fusing unit quit simple, open back door ( sometime require to remove back panel ) you may findout two blue knob release it and may be aalso need to removed two screw pull out this unit half way the unpug the connecter , whole unit coming out.
Aug 18, 2009 | Canon Office Equipment & Supplies
White streaks on photos
Light leak, definately a light leak. You need to change or add foam around the chamber to prevent any light from entering.
Jun 15, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon A1, last 3 rolls came back from the lab, no photos, clear negatives?
Send it to me with lens and I will e-mail you regarding cost and time involved....my best guess right now? 75.00 includes cleaning plus 5.00 to ship back to you, Art www.flcamerarepair.com
Mar 16, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
181 people viewed this question
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Canon Photography Expert? Answer questions, earn points and help others
