Question about Hitachi 53FDX01B 53" Rear Projection Television
Hitachi 50FX18B 1996 double image red,green, then after awhile by shutting off and back on it works fine all day. It just does it on start up after being off. Any hope for a repair? Rob
  • herbavondale Apr 16, 2009
    Thanks for the time
  • 10,594 Answers
Since its an old TV so it has weak capacitors in power supply and deflection section and those weak capacitors would be replaced.
If you have electronics knowledge and can do good solder work in part replacement then you can save money by repairing this TV by yourself.
You can download free service manual copy from HERE. Download all Ten Files and unzip it with WinRaR software to get one PDF file of service manual.
Hit "add a comment" button for further help/ assistance.
Thanks.
Posted on Apr 16, 2009
Why does my hitachi rear projection tv has double image?
Are the double images different colors, such as red or blue or green? If so, the projection unit is "out of convergence, meaning the images are not superimposed on one another. That requires a convergence generator, also known as a video alignment generator.
Apr 28, 2017 | Hitachi Televison & Video
Have a 46f500 hitachi projection television. Started out with a blue reversed arc hanging down on upper right. Now images are not focused, and red, blue and green are layered. Double images. I looked...
It is a convergence problem and set uses two of the STK-392-150 CHIPS. Both will have to be replaced and the set adjusted.
for more information let me know if you can solder and your skill levels.
SD TECH
Jan 11, 2011 | Hitachi 46F500 46" Rear Projection...
I have a 50fx18b and it wont power up i took the back of the set off it has a red light on but nothing happens when i turn power on
the red light = shutdown led
all the green ones indicate the voltage lines that came up
there is a diagram inside that shows all the leds plus fuse locations. you need to check the fuses with an ohm meter to figure out which one is blow or which voltage doesn't come up. with that info, i can direct you.
Jun 04, 2010 | Hitachi 50FX18B/19K 50" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
I have a hitachi 50FX18B and the convergence lines are not aligne
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
Feb 24, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
1996 Hitachi 50FX18B 50"
  • Screen looks 3D
Jul 24, 2008 | Hitachi 50FX18B/19K 50" Rear Projection...
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Hitachi 50FX18B
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 13, 2007 | Hitachi 50FX18B/19K 50" Rear Projection...
Hitachi 53FDX01B 53" Rear Projection Television Logo
32 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
