Question about Uniden Lands Phones
No dial tone on handset; cannot make or receive calls
One of my Uniden handset, CID 100, suddenly stopped giving a dial tone, and I cannot use it. The battery is new, and I had it checked. When I turn it on it shows ''out of range.'' Can you help me correct this problem?
    Brigadier General:
  • 3,614 Answers
better do registering again the phone to the base station. you ma consult your user manual on how to register again the handset.
hope this initial info helps.
Posted on Apr 16, 2009
  • micromaster
    micromaster Apr 16, 2009
    On page 3 under "Step 4 - Register 2nd Handset to Base:
    After fully charging both handsets, remove the second handset from the
    extra charging cradle and place in the main base unit. The main base
    LED light will flash indicating registration is occuring.
    Wait for at least 5 seconds before removing handset. One registration is complete, the cordless phone is ready for use.
    I hope this helps.
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Can receive calls but cannot dial out on Verizon landline phone
Try punching in the number to call first THEN hit talk.. It should dial and call at that point..
Just like when making a call from your cell phn - dial the # first..
good luck ;o)
Sep 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Dialtone, but no dialing
Uniden offered a replacement, stating that the base phone was probable beyond repair.
Jun 04, 2009 | Uniden DECT 6.0 Cordless Telephone...
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
Hello, While I cannot locate that model in any Uniden database (you might want to find the literature), It sounds as if the handset may be communicating with its base, but you have lost the dial tone. Did any storms pass through recently? Here is what you do. Go to your base and push the locator button on your base station to call the handset via the page/locator function. If it rings the handset and you can answer it okay then you know your handset is working well and communicating with your base (the radio portion is working correctly). If it does not ring your handset then your Uniden is definately bad (radio wise). But, I am going to guess that it is okay but you still cannot communicate with the outside world and dial out to get dial tone or get an incoming call. Okay, so we have a dial tone problem. The next step is to see if dial tone is getting to your base. So you will need to take another good telephone, preferably a handy "line powered" telephone (no batteries or ac adapter needed) you can use in a power failure emergency. Take that good phone and plug it into the phone cord you unplug from your Uniden base. If you get dial tone, then your uniden does need repair. If it does not get dial tone, then you have a bad cord, jack or something in your phone wiring. If thats the case, change cords, look for corrosion, dirt or bent pins in the jack on the wall. My guess is that your Uniden has gone bad, likely from a slight surge on the phone line. If you do need your Uniden repaired you can contact Uniden they are at http://www.uniden.com/repair/service.cfm , however I don't believe they offer repair, but offer to sell you a replacement. Or you can go to www.cordlessrepair.com where you can get your Uniden Cordless unit repaired, not exchanged. Good Luck, CG
Feb 18, 2008 | Uniden Cordless Phone
Lands Phones Logo
217 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
