Question about Acer Aspire 3000 Notebook
It turns on then restarts when windows in loading...
After it restarts I get the message that saya "We apologize for the inconvenience, but windows did not start successfully... etc etc" The choices are safe mode, safe mode with networking, safe mode with command prompt, last know good config, or start windows normally. I'm not too savvy in this area, but nothing seems to start windows. HELP... please???
  • 3 more comments
  • mnsg2 Apr 16, 2009
    When i do, it simply restarts again. It begins to load window xp and just reboots.
    LOL, How do I go about scanning for errors and bad sectors lol???
  • efs_perpends
    efs_perpends May 11, 2010
    Do you know what changes to your system led to this error? Have you made changes to your hardware or software?
    Do you have the recovery console installed on your system? It would appear as an option in a flashed screen that also lists your XP operating system during boot up. If you have it installed, we can use it to run the chkdsk utility to scan your system drive.
    If not, you will need the setup disks for xp for your system?
  • efs_perpends
    Choose last known good configuration, and see if it will start up ok.
    What causes the initial restart? Is it simply restarting itself at boot up?
    What is your OS, XP or Vista?
  • pontelemon
    pontelemon May 11, 2010
    Can you scan your hard drive for errors and bad sectors?
  • 531 Answers
There are lots of free HDD test software online.
Also, if you go to your BIOS, there may be an HDD test option.
Posted on Apr 16, 2009
  • pontelemon
    pontelemon Apr 16, 2009
    Basically you put CD with the software in to CD drive and boot from that CD and use SCAN HDD option.
    You don't have to use Windows for that.
    Commonly used software: PC Doctor, PC Check, SpinRite, ....etc.
    I suspect your HDD needs replacement, but it needs to be confirmed by test results.
    President:
  • 1,996 Answers
Here are a few options;
If you decide to do a repair installation, make sure you have backups of your data incase something goes wrong..
http://www.microsoft.com/windowsxp/using/setup/support/nostart.mspx
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/doug92.mspx
http://pcsupport.about.com/od/operatingsystems/ss/instxprepair1.htm
or you could try to rebild the boot config:
http://support.microsoft.com/kb/330184
http://support.microsoft.com/kb/291980/
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Treasure Madness wont load since Facebook update
Zynga tolong kembalikan chip saya saya berjanji tidak akan melanggar lagi
Jul 14, 2013 | zSlide Treasure Madness
It wont start up kind of
Try start, run, then type MSCONFIG go to start tab and UNcheck everything, then go to services and at the lower left of the window it says hide microsoft services and check the box then disable all then restart and see if that helps.
Sep 02, 2009 | ASUS Eee PC 1000H Laptop
It will boot up to the windows screen and freezes.
If your computer was able to boot up but unable to load the Windows, the most common cause would be the recently intstalled software or Windows update.
To remove this, follow these steps. Skip Step 1 if it is not relevant.
Step 1: Removing recently added hardware
Use the steps in this section to disconnect any recently added hardware and test for the error.
NOTE: If a new internal device (sound card, hard drive, or other) was added to the computer before the error message started to occur, you have to remove it before continuing.
  1. Turn off the PC and unplug the power cord.
  2. Disconnect the mouse, and any other peripherals attached (Printer, scanner, webcam, zip drive, phone cord, network cable and other devices). Leave only the keyboard and monitor cable attached.
  3. Press and hold the power button on the front of the PC. Release after 10 seconds.
  4. Plug the power cord back in.
  5. Turn on the computer.
  6. The computer displays the We apologize for the inconvenience... message. Allow the timer to count down from 30 to 0.
  7. If the computer successfully starts to the Windows desktop and does not restart to the error message, connect one device and wait until Windows recognizes it.
  8. To find if a device is causing the error, continue connecting the devices, one at a time, restarting the computer each time, until the device that is causing the error is found.
NOTE: If this does not solve the issue try to do a system restore BUT it will delete all your files and programs you install by yourself after the system. You will be able to use the pc as a new pc.
Jan 25, 2009 | HP Compaq Presario SR2011WM PC Desktop
Sony vaio not loading windows
reinstall the OS ! Just overrite it over the previouse xp so u won;t lose data ...
..most probably u are missing some files ... .. or u have virusez issues. Ofecourse there is the posibility of hardware mallfunction, but considering microsofts reputation ... probably thats not the issue ...
Dec 10, 2008 | Sony VAIO PCV-V210P PC Desktop
200 ARC
Try and use it in 'safe mode' by pressing F8 in advanced startup options.
Then do the system restore.
Sorry if it dosen't help but i can't really reply in fully on a forum.
Jun 29, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
