Question about Epson Stylus C86 InkJet Printer
Bought a used c86 epson off e-bay and it wont
Bought a used c86 epson off e-bay and it wont print. it goes thru the motions like its printing and i can see faint print , ive cleaned the heads several times but with no help.
  • Epson Master
  • 19,396 Answers
That means that the heads must be replaced or the ink pump is faulty. It is not even worth the repair.
Call the Ebay seller and have your money refunded.
Posted on Apr 16, 2009
Ive changed all the ink cartridges in the sylus dx7400, but it will not print the black ink, and the colour sheets have lines all the way through the page.ive rechecked the cartridges, but the black still...
Did you Change to Genuine Print Cartridges.????
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 21, 2010 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 - prints faint magenta even though ink levels are in a normal printing range - does not print anything or a barely seen magenta line during nozzle check and heading cleaning
You probably have a slowly worsening clog building up in the Magenta nozzles. It's also possible that your ink is reaching its end of life which, given the age of the C86 is entirely possible, especially if you are refilling or using a CIS sytem with your printer.
If it's a clog issue you can try soaking the parking pad with a mildly ammoniated cleaning solution (original Ammonia windex is good for this) or even distilled water. Leaving this with the printhead parked above it allows the solution to wick up into the nozzles and break down any clogs in the printhead.
If the problem is ink age though you will probably want to carry out the solution above AND replace your ink with a fresh solution. A CIS will need a thorough flush to remove any algae and cloggation residues before you use it again or you will just reintroduce the problem.
Hope that helps.
Martin
May 27, 2009 | Epson Stylus C86 InkJet Printer
I just bought new ink and nothing prints clearly
If it hasn't printed anything for a couple of years then the print heads will be severely clogged with dried ink. Epson recommends printing a page or two every month to keep the heads clear. You need to try cleaning the print heads, its unlikely that one or two head cleans will clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink, have some new ones ready.
If you need to know how to do head cleans & nozzle checks, the user guide can be downloaded from Epson here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=wsMoc1iChVFHuU002FlmukU002FlwLFmittYG0bE9gMlZoUifYkU003D
Hope this helps.
Please take a moment to rate this solution, thanks.
Apr 01, 2009 | Epson Stylus C86 InkJet Printer
C86 Goes through printing process but nothing prints.
Have you carried out 2 or 3 head cleaning cycles? If not, do it. Is there ink on paper now after this cleaning? If so, but it is streaky, leave the printer for 24 hours and repeat the head cleaning. If not, you must soak the heads for at least 24 hours - use print head cleaning fluid or distilled water NOT TAP WATER. Proceed as follows:
Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move by hand. Move it out of the way to the left. On the right you should see the print head parking area. There is a rubber cup that is designed to fit under the print head to keep the ink from drying out. Using a syringe or dropper, fill this cup with print head cleaning fluid. Then gently move the print head as far as it will go to the right. The print nozzles are now bathed in print head cleaner. Leave it for at least 24 hours, then repeat the cleaning cycle process.
Jan 28, 2009 | Epson Stylus C86 InkJet Printer
Epson printing not printing
If you have already tried 3 consecutive head cleanings and nozzle check from the computer, tried reseating the inks and tried replacing the ink and it still acts like its printing but just provides a blank page chance are your printer already has hardware issue. The ink delivery system is already clogged. If your printer is still within the 1-year warranty period I suggest that you call Epson Tech support for more options otherwise, you would need to get the product repaired by an Epson certified service center. To locate a servicer in your area click on the link http://www.epson.com/cgi-bin/Store/support/SuppProductSearch.jsp?BV_UseBVCookie=yes
Jun 03, 2008 | Epson Stylus C86 InkJet Printer
Epson stylus c66
Take the cartridge out and put it back in then try to print, if it is still the same
try cleaning the print heads>control panel>right click on c66 and go to printing
preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Nov 24, 2007 | Epson Stylus C66 Inkjet Printer
Epson C84 inkjet
This typically is not an issue with re-fill cartridges, but it could be. At this point, if you have replaced the cartridges, ran cleaning cycles AND called Epson, that's all you can do. I would advise just replacing the unit as it's too expensive to fix.
Sep 12, 2007 | Epson Stylus C84 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
129 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
