Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
No color. There is sound and a picture but the color is not present
  • 87 Answers
Check all your inputs and reset cable box or satellite. I have never seen a color problem on this set. I have seen a lot of mice ( rodent ) problems on this and crt fluid leaks. If no solution the color comes from the digital board that can be replaced and I might have one.
Posted on Apr 16, 2009
    Genius:
  • 1,139 Answers
Hello strata_rocks,
This denotes a possible malfunction of the chroma (color) circuits in your TV. You will need to check and see if your chroma signal is being generated at the output of the video processor IC. In addition you want to check the video signal to make sure that the color burst signal is present once the video signal is modulated from the IF input section of the video processor.
These are start off points for your troubleshooting. If you do not have a background in electronics, you have two options, the first is to replace the video board, the second option is to have a qualified TV repair person work on your television and change the board out, after troubleshooting the problem.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
I have an RCA HDTV 52 in 2005 model that makes a humming noise picture color starts jumping in and out from color to blk and white then picture totally goes blk, then after a few minutes will come bk on....
with the symptoms id start looking in the High Voltage area for a Multiplier block failing or possible fly back transformer and i would not continue watching it ti the problem is isolated and repaired as this can further damage and destroy a video processor IC or other parts but id suspect a multiplier block or high voltage tripler is another name for it it is its accesable from the front by removing the speaker panel and be CAREFUL as there is High Voltage present there and you could get a Nasty Zap
Dec 14, 2014 | RCA Televison & Video
I have a RCA 42"
The YSUS control board has failed from the description given. This is typical of the symptoms presented. It can be removed fairly easily and sent to a repair center to be repaired.
Nov 28, 2017 | RCA P42WHD33 42 in. Plasma HDTV
Have sound but no picture
Normally when he presents esafalla screen is cuandola this fall of colors, bad, or the card of his tv needs maintenance
Jun 18, 2011 | Televison & Video
How do i get my tv back to home mode when it is in retail mode
Hello
[1] Press the green color button on your remote control to enter the Settings assistant menu.
[2] Select your Location with the cursor up/down and press the green color button.
If you choose Shop it will skip the Settings assistant. The TV parameters for Picture and Sound will then be set to predefined fixed settings.
Press the green color button again to proceed.
If you choose Home it will display the Settings assistant.
[3] Use the cursor left/right to each time select your preferred screen.
[4] Press the green color button to each time confirm your selection and to jump to the following screen.
The following items will be presented sequentially. In the header it is mentioned how many screens have been completed and how many
screens there are in total. The Settings assistant will step sequentially through the following settings: Picture and Sound.
[5] Press the green color button once to store all the settings and to return to the TV installation menu.
Note: When you skip or stop the Settings Assistant, then the Standard settings
Philips selected for you will be chosen.
[6] Press the red color button to finish the First time installation procedure and to display the first stored TV channel.
OK.
Feb 22, 2011 | Philips 42PFL5332D 42 in. LCD Television
My tv will turn on there is no picture and it
Hi.
The only two parts that can cause scratching sound are the color wheel (if present) and the cooling fans.
The TV must be taken apart and tested by a technician.
To get in touch with a qualified technician ring the number listed on the user manual or check your Mitsubishi support website.
Regards.
Ginko.
May 11, 2010 | Mitsubishi WD-65733 65" HDTV
Picture and sound problem at 21" sony waga color tv
This is not a simple question to answer without looking at it, my recommendation is to call a service center in your area. That's my professional opinion.
Feb 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture yes sound
I was told that this problem could be the power board.
Jun 17, 2008 | Televison & Video
Black and White rectangles, no picture just sound
Need a little more info on your problem. My crystal ball is not working at the present. You need to tell us more about where these rectangles are, how are they spaced, when they are there. Do they move around or change colors. Give as more to work with here.
Aug 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
This is due to problem in deflection area and power supply section malfunction. Make one general service by technical person immediately to avoid major transformer failure problem. Since this is initial stage, the cost of repair is probably less.
Aug 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
