Question about Microsoft Windows XP Professional for PC
Vitual memory low
I get message saying my vitual memory is low
  • drsgprasadi May 11, 2010
    I rquest you for better solution.
    I tried that to improve memory status, but increasing size for virtual memory did not help and also removing files from the hard disc where windows is loaded did not help. I still get message, virtual memory low....
  • 24 Answers
Adding more RAM (memory) may also be a good idea as this will reduce the need for virtual memory to be used in the first place.
Posted on Sep 18, 2007
  • Zothan Sanga
    Zothan Sanga Sep 18, 2007
    You may increase the size of the paging file. To do so, follow these steps if you are using Windows XP.
    1.Click Start, right-click My Computer, and then click Properties.
    2.In the System Properties dialog box, click the Advanced tab.
    3.In the Performance pane, click Settings.
    4.In the Performance Options dialog box, click the Advanced tab.
    5.In the Virtual memory pane, click Change.
    6.Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK.
    7.Click OK to close the Performance Options dialog box, and then click OK to close the System Properties dialog box.
    Sergeant:
    Champion:
  • 293 Answers
Free up more disk space. delete unescessary files on your windows drive.
Posted on Sep 16, 2007
How to recover a 4GB Memory Stick vitual memory?
Files gone? What might suit you is 4Card Recovery. It can recover movies, music, pictures and other files very quickly.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
Jul 28, 2012 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Insufficient memory File: zedgec.c Line Number: 91
Probably it's vitrual memory problem Check memory assigned for vitual memory.
Check your RAM, might have a bad memory stich
Oct 13, 2011 | Computers & Internet
Vitual memory low. idwnloaded your FREE program that turned out to cost me $29.99. i called and left my ph3 AND NO RETURN CALL. Still hav the same problem. Vitual memory low. i do not know how to fix. Will...
using your keyboard hold down the windows key and then press R. Once the Run box comes up type in sysdm.cpl
-Click on the Advanced tab
-Under Performance Click Settings
-On the Performance options click the Advanced tab again
-Under Virtual Memory click Change
-if it's on System managed size click on Custom Size
-Type in the recommended size for the Initial and Maximum size
-Click Set
-Click OK and Ok again
-You would need to restart the computer for the changes to take effect
Hope this helps, Happy troubleshooting!
Apr 15, 2011 | Computers & Internet
Phone memory is running low. it says i have 14MB in the Messages folder. I erased all my messages but still the memory is so low. how can i solve this?
The messages that you have deleted were in our sim card memory.. You need to delete data from your phone memory.. Go to gallary and delete some data from there (phone memory).
Jul 11, 2009 | Nokia N72 Cellular Phone
Vitual memory
install and run CCleaner, it's free and cleans your drive and releases space for virtual memory
http://www.filehippo.com/download_ccleaner/
Aug 15, 2008 | Microsoft Windows XP Professional With...
Low Memory Status
hello abcfactor2003 i agree that you have lot of space in memory card but have you checked the phone memory?When you recieve any blueetooth message it is recieved in message box have you checked that in message box you are using phone or a card with you problem i probably think that you are using phone memory in message so what you do is open message goto option than setting than others than select memory in use select memory card now you can recieve songs videos as much as memory card is free (Regards Paljor Lama)
Jul 26, 2008 | Nokia N72 Cellular Phone
Running low i vitual memory
go to control panel, then system. Click the performance tab at top of screen, you will see virtual memory at the bottom, increase the amount to solve you problem. Good Luck
Sep 15, 2007 | Microsoft Windows XP Professional for PC
My vitual memory
it means the amount of hard drive free space is either low or it means you must increase the limit of this space. first remove any un-necessary files by doing the following: 1.) open explorer and click c drive. 2.) right click and select properties 3.) select "disk cleanup" now select the Tools tab above and select "check now" now select "Defragment now" next, right click "my computer" on desktop then select Advanced tab and select "settings" then select next Advanced tab and select "change" in the virtual memory area. type in the maximum under custom size and select "set" and ok out.
Microsoft Windows XP Professional for PC Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
