Question about Garmin nuvi 350 GPS Receiver
Nuvi 350 Unit will show maps as I drive but when I press "Where To" screen and punch in Fuel (ie)all I get is "No matches found" This happens even if I try to manually spell in location. I can't even get it to let me enter a state-I get the same message.
  • debrakay Jan 10, 2009
    can't get map info to come on, it is real dim and will not respond
Hi, I just had the same problem today. Someone on another help site mentioned this... Check to make sure your maps are checked off. Go to settings, Map, then press Map Info at the bottom of the screen. Make sure City Navigator North America NT v8 has a check mark on it. It worked for me.
Posted on Oct 08, 2007
How do I update my Nextar x3-08 gps so the new roads will show up ?
visit Nextar.com to order your desired maps update and Check the overview description to see which SD card lists your GPS model number and serial number. Order the matching card.
Remove the existing SD card. This is usually found in a thin, rectangular slot on the side of the Nextar GPS.
Insert the SD card with the maps update into the empty SD card slot. Press until it clicks into place.
Reset the unit by pressing the "Reset" or pushing a pin into the "Reset" hole.
Click the "Navigation" button to have the maps automatically update on the GPS.
May 06, 2015 | Nextar X3-08 Car GPS Receiver
Garmin Nuvi 1450LMT, after entering a state, then attempting to "spell City" after entering city, and touching "done" unit indicates, "no matches found". For example, Minnesota, Minneapolis, unit...
Is the map turned on? At the main menu, press the system tools icon and press the map icon. Then press the map info button.
What does it say? Does a map show up and is there a checkmark in the box next to the map description? Also, if the map is for a certain area, say lower 49 states, SW, well you won't be able to find a city in the NE because the map is only showing a limited area. If you have ample memory on the unit or have a 2GB or larger SD card, installing the full US & Canada map is the way to go. Make sure the map installed on the unit covers where you are and where you may be going.
Sep 27, 2013 | Garmin Nuvi 1450LMT
The only maps on my GP is Canada and bordering states everything else is gone, I am travelling the USA and it does not recognize Arizona, even the map screen does not show any streets. When trying to put...
You need to replace the map with a full map of the US and Canada. Did you register your unit with the Garmin website? Did you create an account? If so, you can log in and see if you can download a larger map. Otherwise you will need to purchase a new map. I can also help you with this issue but it would require for me to have your unit in front of me to do it.
Aug 01, 2013 | Garmin nuvi 1450 GPS Receiver
Unit shows that No detail maps found that support routing.
Make sure you have your Map selected in your settings..... go to Tools.... Settings.... Map.....on bottom of screen press Map Info.
Is there a check mark in City Navigator North American NT..........if not you must have one in there to chose that map or whatever map you are looking for
Nov 13, 2010 | Garmin nuvi 255W GPS Receiver
When trying to program in an address the Nuvi prompts you to spell a state. When you put the first letter of the state in it immediatly says "no matches found."..So it is imposible to use the...
I would make sure that your Ciy Navigator map is selected
go to Tools...Settings....Map....on bottom of screen press Map Info....make sure a check mark is in the City Navigator North American NT
Nov 09, 2010 | Garmin Nuvi 350 Car GPS Receiver
When I try to spell states it goes right to no matches found on the 1st entry
After powering up the unit and selecting address, the unit displays, "In What State is the Address? and Spell State. When I press Spell State, it has No Matches Found. When I press Back and attempt to enter the first letter of any state, the unit displays "No Matches Found".
Sep 17, 2010 | Garmin Nuvi 350 Car GPS Receiver
No data available and no maps downloaded
it may just be that the maps are deselected. to correct this go into the tools/settings/map and then at the bottom of the screen in the middle you will see map info tap that and then at the next screen it will show you the maps which are installed if there are any without ticks just tap the box. tap ok and try again if. if there are no map choices then you will need to reinstall the maps on your unit
Apr 26, 2010 | Garmin nuvi 780 GPS
When i typre in a location etc it says no match
go to setting. then gho to maps. then to map info and tick in thge box aghainst city navigation nt 2008. found under best solution tanjeev on ur site. thanks. works like new again.
Sep 03, 2009 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
177 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
