Question about Yamaha RX-V463 Receiver
No picture on TV - Yamaha Receiver flashes HDMI
We just bought a new Sony Bravia 40" TV, Yamaha Receive, Blueray system.
We hooked up our new universal "Harmony" remote control and when we now try to turn the system on, we can hear the TV however we don't have a picture.
The Yamaha Receiver flashes HDMI under the Multi Channel button.
Do you have any ideas how to reset the Yamaha receiveer?
5 Suggested Answers
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
  • 21 Answers
SOURCE: AUDIO VIDEO MULTI CHANNEL RECEIVER VSX-818V NOT
Check fuse or power supply
Posted on Oct 27, 2009
  • 3 Answers
SOURCE: I have my xbox 360 connected via hdmi to my yamaha
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Posted on Jan 24, 2010
  • 127 Answers
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Posted on Mar 02, 2010
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Mar 31, 2015 | Yamaha HTR-5930 Receiver
I try to connect my BD player with HDMI port cable from BD player to Sony HT-DDW1600 Theater and from this receiver to TV (40? bravia). When I press BD button on the remote, picture comes out very good but...
Is your sony receiver HDMI pass through? some receivers dont allow audio just video through HDMI. Connect a digital coaxial cable from the dvd to the receiver and you should get true dolby surround.
Oct 28, 2009 | Sony MUTEKI HTDDW1600 Theater System
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Sep 04, 2009 | Yamaha RX-V363 Receiver
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
TV blanks out..."pcm" light flashes on receiver
You need to Bypass the Receivers HDMI port and use HDMI directly to the TV. Your receiver has HDMI version 1.2a and is not 100% effective. Use the optical out from your Xbox to the receiver and all will be well. 1.2a has issues in every receiver on the market. Supposedly 1.3b on the "new" receivers has fixed this issue. Hope this helps
Aug 12, 2009 | Yamaha RX-V663 Receiver
Verizon Fios connection issue with RX-V663 Receiver
I had the same problem with RXV3900, was told by verizon and yamaha it's a software issue with the box. Verizon is suppose to be working on a new update, but no time frame for now. I'm using component to receiver, and hdmi to tv with no issues.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Lots of components , need proper hook-up
I reccomend a Denon AVR-2809. It had 4 HDMI inputs, all 1.3a and higher, and one HDMI out for your TV!
Jan 07, 2009 | Audio Players & Recorders
HDMI cable between TV and Lifestyle 28
Did you set up your bravia TV to receive pictures throuh HDMI ?
Dec 28, 2008 | Bose Lifestyle 28 System
Having trouble connecting my blue ray and tv to my yamaha receive and surround system
Must be an HDMI ?
If yes use the HDMI DVD input on your receiver ( from the Blue Ray using a HDMI cable )
Then use an HDMI cable from receiver to TV.
That should work for image. Sound would only work directly from TV, to have sound on receiver:
Use either optical or coax cable to direct digital sound from blueray to receiver.
Best is optic, depends on blueray or cable availability ... Coax = RCA cables @ 75 Ohms, use of a spare RGB would work find (using only one of three color available let's say using Red only) or try with any RCA cable.
direct cable from blueray to receiver ( Digital inputs at far left looking back of receiver num 7 in owner manual, choose DVD )
If no sound from receiver check Audio select from option menu ( set to auto )
Any specific question about this procedure ?
or guess you already found out,
Enjoy :-)
Dec 17, 2008 | Yamaha RX-V363 Receiver
Sony bravia kdl-46v2500
TRY A DVD PLAYER TO VERIFY IF IT COULD BE THE SAT.BOX OR MAYBE TV COLOR ADJUSTMENTS.JOE TV
Dec 30, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Yamaha RX-V463 Receiver Logo
240 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
