Question about Toshiba 20HLV85 20 in. LCD TV/DVD Combo
Hooking up a PS3 through HDMI
I have my PS3 hooked up to the tv through HDMI, but the tv wont recognize the hook up, i know i have to load the PS3 HDMI set up in the menu but its still not recognizing it when i try to set up, it only works through the yellow red and white cables when the tv is in game mode. When the PS3 tries looking for the active HDMI connection it goes back to default saying the connection was not available.
  • 3 more comments
  • amoroso Dec 18, 2007
    same problem but with a LG37 LC51.
    it only recognizes the standard Scart connection, but not the HDMI.
    I´ve reset the PS3 several times (as per manual), but no luck. Also played around with the configuration but still nothing.
  • trevor born Dec 29, 2007
    I have the toshiba 56hm195 and the same problem! I'm on the phone with Toshiba as I write this.
  • Anonymous Feb 07, 2008
    my ps3 is connected to a 1080 tv but when i play most of my games they come out in a 740 resolution a want to know was the problem.
  • logiebear19j Mar 16, 2008
    i hooked up the hdmi cable in the right spot with the red and white right next to it and all that comes out of the screen is just volume and a black screen
  • metkaas Oct 19, 2008
    same problem , the defult screen detects the hdmi but when I select yes to output a/v thru hdmi cable the screen turns black but when i select no the ps3 works in normal resolution
SOURCE:
SOURCE: Hooking up a PS3 through HDMI
what you have to to is hold the start button till the TV shows 480i then you will have what you need, it will set up for your tv
Posted on May 03, 2008
SOURCE: closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Posted on Sep 28, 2008
SOURCE: Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
Posted on Jul 08, 2009
  • 541 Answers
SOURCE: HDMI cable hooked up, now CLOSED CAPTIONING is stuck on!
It has got to be the box. I would try to contact Scientific Atlanta if any way possible. The TV doesn't choose what inputs it shows CC.In other words, it would show it on all Inputs if it was the TV. Good luck and Thanks
Posted on Oct 30, 2009
  • 3 Answers
SOURCE: hooking up xbox 360 to tv
put it on hd. the big plugin that say tv or hvd
Posted on Feb 10, 2010
How to hook a ps3 to a protron tv
How are you hooking it up to your TV, through the AV color cords or HDMI, or HD AV cords?
Oct 20, 2014 | Sony Playstation 3 (PS3) Console
Would like to hook up playstation2 can you help with this
I would suggest hooking up via HDMI or via the composite cables. Then all you should have to do is turn on your ps3, change the input on your tv to whichever port shows the ps3 or new input device. If it doesn't for some reason recognize it as ps3, you can always go into more detail using the tv to rename that port as the PS3. Hope this is what you wanted to know!
Feb 07, 2012 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have a HDMI problem with my PS3. I have it
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
May 14, 2010 | Sony Playstation 3 (PS3) Console
Try entering Recovery Mode and choose "Restore Default Settings".
If that doesn't help, you may have an HDMI port failure - which will require returning the unit to Sony or sending it to a third-party PS3 repair shop.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
We're hooking up our PS3 to a new television....and it keeps telling us there is no signal...what could be the problem?
be more specific about the problem, r u using original wires or HDMI? what kind of TV is it? and have you tried hooking up a dvd player or other devise to make sure the TV is not defective? and if you switched connections(HDMI to regular cables or vise versa) u have to change the settings on the consle under DISPLAY SETTINGS using the same connection you were using on the other TV.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
I just bought a PS3 slim and hooked it up to my 65'' Toshiba DLP TV using a HDMI cable. The problem is i have picture but no sound. I have tried the settings and all seems to be fine, also tried different...
not 100% sure but check the manual for your tv it may be that you need a faster hdmi cable, as with having a larger tv it will work at a faster rate so the basic hdmi cables wont work.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
Line going up and down TV when i play ps3?
did you reset the setting in your xmb on your ps3 from hdmi to a/v cables?
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Feb 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toshiba 20HLV85 20 in. LCD TV/DVD Combo Logo
759 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
