Question about Whirlpool 24 in. DU800CWD Built-in Dishwasher
How do I drain off the water that has collected at the bottom of the dishwasher after a wash?
I dont know how to get rid of the water that has collected at the bottom of the dishwasher after a wash! HOw should I drain it off? It is a whirlpool dishwasher, model DU800CWDB4
SOURCE: whirlpool dishwasher
I had the exact same problem with my Whirlpool Quiet Partner IV. I removed the lower arm, and a couple of components below that, and got to the filter/grinder (that thing that chops up and filters the recirculated water before it goes to the pump that feeds the arms). The filter was completely clogged. I used a knife to scrap away the foodstuffs, put everything back together and all worked excellent. Just goes to show you that you should rinse your plates before to place them in the dishwasher.
Posted on May 13, 2007
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
  • 351 Answers
SOURCE: Whirlpool dishwasher not draining
blockage in the drain hose somewhere
Posted on Mar 20, 2008
elhomspam
  • 58 Answers
SOURCE: Whirlpool Dishwasher DU850DWGX1 won't completely drain
Commonly this is result of low water pressure or hose height/length
As long as the water is below the heating element and the dishes are getting clean its actually normal. Sometimes the pressure or hose length/height meets specs but will not always drain all water.
But as long as it is below the heating element this is normal
I am sure.
Posted on May 02, 2008
rickzilla
  • 706 Answers
SOURCE: Dishwasher will not drain
Hello Tom_Simmers,
Here is a link with exploded views and parts lists for your dishwasher for reference however based on your description, have you made sure you don't a blockage in the check valve? That's part of the pump drain assembly. http://www.pcappliancerepair.com/model-display.php
You may also have a problem with the pump itself so the documentation on the website will help you evaluate that.
In many instances, its just a blockage of food byproducts inline with the drain system so chances are thats what you will find.. Good Luck on that.
Regards,
Rick
Posted on Dec 02, 2008
I have an older bosche dishwasher and the I know the water is flowing into the unit and collecting at the bottom of the drain but it is not getting into the spray arms in the middle and top to work at all....
there is a chacne that the main wash motor is not drawing enough water into the pump to spray through the arms.you can try and add some more water to the dishwasher and see if there is any change.
if there is no change then you migh need to replace either the contol board or the main wash motor
Sep 08, 2010 | Dishwashers
Have a rental property with F&P two draw dishwasher aprox five years old. Apparently bottom draw is holding water - what do you think?
Could be many reasons for the bottom drawer to hold water.
It could be leaky top drawer causing water to collect in the bottom drawer. Check if water collects when top drawer is running.
It could be blockage in the bottom drawer drainage which can be fixed by cleaning the filter plate and the drain sump. If the drain pump is not running during drain cycle then you will have to replace the drain pump motor.
Aug 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water collected in bottom of dishwasher
This could be due to several reasons. The most logical is that the pump filter is getting clogged.
follow the instructions in the owner's manual to clean up the filter. Also the impeller arm will need cleaning if the dishes are not clean.
If the above does not fix it then more likely the drain outlet under the sink is getting clogged. Try and clean the drains.
Regards
Sam
Dec 15, 2009 | Miele Dishwashers
Our Siemens dishwasher retains water and smells
I would check the bottom of the dishwasher to see if there are any bones, old food built up as some of these collection systems have a small disposer built into them.
If you find any food, it's probably that.
Also, you can make sure that the drain line is the proper length and high enough as this is a common problem. Do a good search on proper drain height for dishwasher.
You may run an empty load of dishes with a cup of bleach added to eliminate the odor as well. Bleach will kill any bacteria causing the smell. More than likely the drain hose wasn't installed correctly.
Sep 10, 2009 | Siemens 24 in. SE64A630GB Built-In...
Dishwasher stopped draining after cycle
Some water always remains in the bottom of the DW (al least with most DW) but here is some help....
GE dishwashers will have a sump entrance screen ( #4 ) that should be removed and checked for any gookus, see 1 or 2 screws on the cover top, which is behind the lower spray arm. Almost all ( some newer GE dishwashers have a separate drain pump and motor - but for our purpose, we will talk about the most common GE dishwashers ) GE dishwashers have a drain solenoid ( #1 ) that can fail and stop the draining. If the solenoid cannot pull in the silver plunger, the drain port will not open to allow the motor and pump assembly to drain the water out. The solenoid can be ohmed with an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GE dishwashers have a self clean filter ( #3 ) inside at the back. The draining water must pass through a plunger in the self clean filter body. This can get clogged up, or the plunger may twist and distort and not allow the draining water to get past. The filter can be removed from the inside and the plunger will twist out of the self cleaning body for testing/checking. Next obstacle for the draining water in the back flush valve ( #2 ). This valve can twist or distort and block the water flow as well. The drain port will need to be accessed to check this flapper valve, the drain port will untwist from the self clean filter body. All hoses in-between the items mentioned above and the drain hose itself all the way to the house plumbing should be checked for restrictions.
Some extra filter, draining tips and pictures....
During the wash and rinse modes of the cycle, soiled water falls down the back of the tub and into the filter area. The water comes through the filter and back into the tub. During the wash and rinse periods all ( we hope! ) the water will pass through the filter. The soil will settle into the collection chamber and is held there. When the dishwasher goes into the pump out mode the water in the sump is pumped through the collection chamber. This closes the piston valve to the inside of the tub. The pump flushes the collection chamber of all the food soil and pumps it down the drain. A check valve is located in the drain line port. This valve allows the water to flow in the drain direction only and prevents the water from coming back into the tub. The drain line check valve must close in the back flow direction or the piston valve in the collection chamber may not reopen into the tub after the pump out is complete. Water should "fall" through the filter and go back into the tub....the heavier food particles go down into the chamber and are collected.
Here is a link for you to check out...I have all this info in my data base but since it is in PDF format it does not translate well to this format...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...good luck and ggod day...please rate my effort......thanks....The Fang.
Mar 14, 2009 | GE Nautilus 24" Built-in Dishwasher
Water in the bottom of dishwasher
try running it empty there is usually a drain hole in the bottom check if anything is in it or try a dish washer wash solution I bet the drain or drain line is cloged let me know if this dont work. Hows your sink draining
Feb 15, 2009 | Kenmore 17459 Free-standing Dishwasher
Drain
try adjusting your drain tube under the sink,so you dont have back flow from garbage disposal
Dec 31, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher Asko D 1776
you may need to reset the inlet time on the board do you have the instuction book,turn the power on then press the fifth button five times within 15 sec then press third button normal wash this should fix your problem
Apr 06, 2008 | Asko D1776 Stainless Steel Built-in...
Won't drain
The drian could be plugged or the pump could have an obstruction. Did you just install a garbage disposer? If you did you may need to knock out the plug in the disposer. Hope this helps
Jan 12, 2008 | Westinghouse 24 in. MDB421 RF Built-in...
Standing water in the bottom
try starting any program - all start with drain. if it doesnt drain, suspect a foreign object in the drain pump
Mar 29, 2007 | Kenmore 24 in. 15074 Built-in Dishwasher
Dishwashers Logo
105 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
