My computer toshiba105 will not reconize computer Called teck they said press Fn and F5 and this will change the view in settings to show to units instead of one. I basicly want to drag one screen to the other
    Scholar:
  • 67 Answers
To drag one screen to another, connect the secondary monitor and then right click on the desktop and click properties. click the settings tab then click the number two monitor in the picture and check the box below next to Extend my Windows desktop onto this monitor. You should now be able to drag items from your main screen onto the secondary monitor. If the computer doesn't recognize the monitor, you may need to install a driver for the specific model, which you should be able to get from the manufacturer's website.
Posted on Aug 11, 2009
How do i fix a split screen of my Toshiba c600d-t36b laptop
The quickest way to change the display output settings is to use the
display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order
(the last two options are available if an external monitor is
connected):
? Built-in display only
? Built-in display and external monitor (simultaneously)
? External monitor only
? Built-in display and TV (or other external video device)
? TV (or other external video device)
? External monitor and TV
? Built-in display and external monitor (extended mode)
? Built-in display and TV (extended mode)
? External monitor and TV (extended mode)
? Swap-Switch primary display between internal display
and external monitor when using extended desktop
Feb 12, 2015 | Toshiba Computers & Internet
I buy vga to rca and s video cable to conect toshiba laptop to tv and dont show grafic options how ican make work
There is a button to switch from laptop monitor to external monitor or can view on both monitors. There is a button with a drawing of two monitors, usually the F5 button. Press FN and F5 simultaneously to switch from laptop monitor to external monitor. Press them again to view both on laptop and external monitor. Press them again the third time to view only on your laptop monitor.
Sep 07, 2010 | Computers & Internet
I need an explanation as to the secondary function of the keys on my NB305. Mainly the top row of 'F' keys, but the remainder of the keyboard as well. What do all these little symbols on the keys mean?
F1 through F12 are called function keys because they execute programmed functions when pressed. Used in combination with the Fn key, keys marked with icons execute specific functions on the computer. The function executed by individual keys depends on the software you are using.
1. Sound Mute: Pressing Fn + ESC in a windows environment turns sound on or off. Press Fn + Enter to simulate Enter or the enhanced keyboard's numeric keypad. 2. Instant security: Press Fn + F1 to blank the screen to prevent others from accessing your data. To restore the screen and original setting, press any key or press the Touch Pad. 3. Power save mode: Pressing Fn + F2 changes the power save mode. 4. Standby: When you press Fn + F3, the computer enters Standby. 5. Hibernation: When you press Fn + F4, the computer enters Hibernation. 6. Display selection: Press Fn + F5 to change the active display device. Hold down Fn and press F5 again to change the device. 7. Internal LCD screen Brightness: Pressing Fn + F6 decreases the display brightness in decrements. 8. Internal LCD screen Brightness: Pressing Fn + F7 increases the display brightness in increments. 9. Wireless setting: If your computer has both Bluetooth and Wireless LAN functions, you can press Fn + F8 to select which type of wireless communication you want to use. 10. Touch Pad: Pressing Fn + F9 in a windows environment enables or disables the Touch Pad function. 11. Press Fn + F10 or Fn + F11 to access the integrated keypad. When activated, the keys with gray markings on the bottom edge become numeric keypad keys (Fn + F11) or cursor control keys (Fn + F10). The power on default for both settings is off. Press Fn + F12 (ScrLock) to lock the cursor on a specific line. The power on default is off. 12. TOSHIBA Zooming Utility (reduce): To reduce the icon size on the desktop or the application window, press the 1 key while holding down the Fn key. (13. TOSHIBA Zooming Utility (enlarge): To enlarge the icon size on the desktop or the application window, press the 2 key while holding down the Fn key.
Jun 15, 2010 | Toshiba 310CDT Keyboard
When I connect my aspire 5315 to the tv and boot the computer it shows the boot on the tv but suddenly stops when the computer comes up and does not show the monitor again. I press Fn f4 and nothing...
Fn + F5 is what changes external display mode on acer laptops. Press and hold Fn, then press and release F5 to change between three modes:
Laptop display only.
Both displays.
External display only.
OR....
You need to go into your display properties and extend your desktop onto the external monitor. If this doesn't solve it, let me know :)
May 17, 2010 | Acer Aspire 5315 Notebook
Monitor screen won't leave presentation mode
Try pressing fn Key + F5 or esc key or windows key.
Thanks
Mar 07, 2010 | Acer Aspire 5004WLMi Notebook
I cannot get my lap top to show on the all with my projector
Laptop will often have a function key (usually F5) for cycling between built-in display, external monitor, and both. Try pressing F5. If that doesn't work and you have a "Fn" key (usually near the left Shift key) hold down Fn and press F5.
Oct 11, 2009 | Compaq Presario Notebook
Can't get my notebook screan to show
hello,
Indentify the video output options of the computer and the input options of the projector. Most common are VGA and S-Video. use the appropriate cable to connect the two. Your projector may be able to probe its ports to see what signal it is getting.
On your computer. After you make the hardware connection and your projector is set to receive on the correct port, extend your desktop to show on a TV if S-Video, or on a monitor if VGA. To have the screen of your computer to appear on the external screen, use the FN-Fx key combinations. Examine the laptop`s function keys and look for some icon that shows a computer and a screen. Most probably it is the F5 key.
Assuming F5 to be the right key, you press Fn-F5 and an OSD will appear on your computer. You scroll from an icon to the other by pressing F5 while still pressing down the Fn key.
If that does not work, I suggest you check your computer s manual for the right key combinations.
Hope it helps.
Oct 02, 2009 | HP VP6310 Multimedia Projector
I have pressed Fn and F5 on my easynote laptop now the LCD screen has gone wierd. How do I reverse this?
fn + F5 changes output mode
its 3 way toggle switch
1. laptop screen only
2. secondary display unit only\
3. mirror on both display units
press Fn+f5 keys again to revert to normal mode
Apr 04, 2009 | Computers & Internet
How can I view my Del Laptop screen on my 50" Insignia TV?
do you have the connector.to connect both the units.
Aug 29, 2008 | Televison & Video
Acer Aspire 3680 + View Sonic Projector
does it work with external monitor ?
the key should be Fn+F5 or Fn+F6
I believe you need to hold fn and press f5 to choose the target (lcd, monitor, lcd and monitor).
Feb 26, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
