My tv will turn on but then will turn itself off before the picture appears on the screen how do I go about fixing this problem. It's a mitsubishi if that helps
  • Lee Jury Apr 16, 2009
    WS-55819 is the model number
  • 87 Answers
Need model number but if your a novice call a mitsubishi service center. If it has a lamp door check the lamp first, it might be broke.
Posted on Apr 16, 2009
  • Terry Riegel Apr 17, 2009
    This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. Are you a technician or set owner? if so what kind of experience do you have at repairing electronics. Let me know what the code is.
I have a Mitsubishi dlp wd-65737 that when turned on goes to a pink screen with no picture what could this be is it worth fixing
  • If your TV issues involve the appearance of your TV's picture, the remote may be your answer. Press the "Format" key on your Mitsubishi rear-projection TV's remote control if the shape of the picture seems incorrect. Press the key repeatedly to cycle through various aspect ratios until the picture looks correct. To restore all audio and video settings to their defaults, enter the TV's main menu and select "Reset" from the Picture tab. From the same tab, you can reset colors to their defaults by canceling optional image features such as PerfectColor or PerfectTint.
Aug 05, 2015 | Mitsubishi Televison & Video
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
Mitusbishi dlp tv shut off
hi when you replace the lamps, the lamp counter needs to be reset,thanks
shaun
Jun 28, 2017 | Mitsubishi WD-73737 73 in. HD-Ready TV
I have a 60 inch mitsubishi flat screen n i someone shot an bullet thru my tv n i would lik to have a quote on how much would the repairs be?
Sorry tv not repairable,the picture screen panel is broken or damages.The tv picture screen panel are 90% important to the tv and it is limited in production by the tv corporations,no where u can buy tv picture screen panel except the tvs corporations themselves.By replacing the tv picture panel,will cost the same as a new tv,by replacing the picture screen panel alone,because of it limited production and important to the tv itself.Sorry this not worth as a whole tv anymore,now tv only as salvages tv for it electronic boards for parts only now.
Feb 02, 2011 | Mitsubishi WD-57733 57" HDTV
Polaroid TLA-04011c 40 inch. LCD TV? How can u fix TV plasma screen? my friends kids hit the tv screen for with wii remote. i think they broke the tv screen from the one side. and how much it cost to fix...
Sorry this tv can't be fix acept replaced the whloe picture screen panel itself,the tvs screen panels are in of the limited production by the tvs industries,only can buy picture screen panel from the tvs themselves and it 90% important to the tv,will cost u the same as a new tv to get picture screen replaced.Sorry doesn't worth as a whole tv anymorre the tv now only worth as salvages tv for it electronic boards for spare parts for other tv,that it.
Dec 19, 2010 | Polaroid TLA-04011C 40 in. LCD TV
I had to unplug my cable/tv last night and when I turned it on this morning I could not get the menu to display the cable accept on the menu screen. I went in to turn off the home theater and the cable...
Push the menu button and enter 1370 and push enter and the tv picture will appear on the screen. If it does not push the input button until the picture appears.
Jul 28, 2009 | Televison & Video
Picture is really light in color screen is white
It sounds like you have bad solder joints in the tv. If you resolder the boards in the tv, it sounds like it will be fine. When you are slapping the tv, it is temproarly making contact again and fixing the picture..
Jan 02, 2009 | Mitsubishi VS-45607 45" Rear Projection...
No picture just sound
Your projection tubes are messed up. It's a very expensive fix, just get a working TV off craigslist with a smashed screen and reuse your screen itself (usually 100-200$) or just toss the TV and upgrade to an LCD
Apr 29, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi 6043A Loss of color
Sounds like many different problems maybe related thou. You say 6043a but you are under WD-62327. So this info is for that.1. Suspect the Light Engine part # 939P977020 also you could need.. Suspect the Signal PCB part # 930B923002 if no video keeps up
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
