Question about IBM Infoprint 1332 Laser Printer
Ibm infor1332 printer beeps 3 times "unsupported print cartridge"
The printer beeps 3 times then display "unsupported print cartridge" then freezes.
  • Anonymous Apr 26, 2009
    my toner is running out so i took the cartridge out shook it lightly and now it says unsupported print cartridge
  • brentnjames3 Apr 26, 2009
    i can't print to my ibm infoprint 1332
SOURCE: no print catridge
"No Print Cartridge " message is displayed on the HP LaserJet 3015, 3020, or 3030 series product's control panel, even though a cartridge is present. The same message can be triggered on the HP LaserJet 101x series products. Resolution Follow these steps:
  1. Remove all paper from the input tray.
  2. Open and close the door.
  3. Reinsert the paper into the input tray.
  4. Powercycle (turn off and back on) the printer.
The error will then go away. FW Datecode 20040330 update: Since the message on the control panel is confusing, the message has been updated from "No Print Cartridge " to now display "Check Cartridge/Check Paper Tray " message. NOTE: It is important to remember that regardless of which printer is being used, or which revision of device firmware is being used, the resolution is the same; removed all of the paper from the paper tray, restack the paper and reinsert it into the paper tray. This will position the input paper so that the engine sensor will not be tripped. Description The printer uses a physical sensor to detect whether or not a cartridge is present in the device. This sensor is mechanically linked to a second sensor that detects whether or not there is a jam in the pick-up area of the paper path. Since these two sensors are linked, when a jam occurs in the pick-up area, the engine does not know if there is an actual jam or if the cartridge is missing. The printer uses an algorithm to choose between a jam message and a missing cartridge message based on whether or not the cartridge door has been opened. If the door has not been opened recently, it is determined to be a jam. If the door has been opened recently, then the cartridge is missing. Therefore, if there is a jam in this area and the door is opened and closed without the jam being cleared, the printer believes the cartridge is missing. The error is generally seen when a jam occurs that involves multiple pages that are staggered throughout the paper path. Most of the jammed pages are cleared by opening the door, removing the paper in the path, and then closing the door. Occasionally, some pieces of paper are picked and only advanced into the paper path by approximately 1 or 1.5 inches. These mis-picked pages might not be obvious because it is hard to see that these pages are actually in the paper path since the pages have moved such a small distance. This is when the "No Print Cartridge " message is incorrectly displayed. The "No Print Cartridge " message is confusing if the pages have only advanced an inch out of the paper tray - removing the cartridge will not show the problem as the paper has not advanced far enough to be seen from the inside of the printer.
Posted on Nov 17, 2007
harvester3
  • 181 Answers
SOURCE: IBM Thinkpad T30 2367 beeps 8 times
It's your memory, or more to the point, the memory slots. take all memory out, install 1 piece in the slot closest to the back of the laptop, push down on the memory as if pushing it into the motherboard, and hold pressure while booting.
Bet that works. if not, let me know.
I've got the same machine.
Good luck
Posted on Jan 04, 2008
  • 13 Answers
SOURCE: Troubleshooting Dell 924 all in one printer(Printer reads unsupported cartridge)
Try replacing the cartridge with a new Dell ink cartridge, the refill may have gone bad.
Posted on Aug 01, 2008
Cops
  • 64 Answers
SOURCE: 32 Unsupported print cartridge
This is caused by an unsupported chip on the toner. If its a reman toner ie. Office depot/nice day then you should ring them up and et them to arrange for a new one. if they say its not possible to have a faulty one they will be trying to fob you off. just as a guide lexmark have around a 7% failure on toners so your not the only one. if it gets to the point where youd like to put the toner in a certain place of the office depot's worker then you can always find a chip online from people such as static or delacamp. and they just pull out and slide in.
need any more help just email me:
pete@wedotoners.com
Posted on Nov 26, 2008
  • 3594 Answers
SOURCE: put new ribbon cartridge in ibm wheelwriter 3 not printing now
If the ribbon is lifting up you probably have a cracked print solenoid plunger cap. They are available but a little tricky to install.
DickyO
Posted on Feb 12, 2009
Dell 725 won't print saying unsupported cartridge
Had the same issue, bought some cheap inks off the internet and the printer wouldn't accept them, bought the proper dell cartridge did a head clean and it worked ok.
Apr 15, 2013 | Dell 725 InkJet Printer
I have a lexmark 2580, I keep getting 'unsupported cartridge' message, and one of the lights on the printer is constantly blinking. I have brand new lexmark cartidges installed.
Problem Unsupported Cartridge; Error: "Unsupported cartridge"; Incompatible cartridge error; Incompatible cartridge in the printer; Cartridge not recognized Solution What you will see
When a cartridge is inserted, an Unsupported Cartridge error message is displayed on the printer operator panel.
Affected printers
This issue affects printers sold exclusively in the Dixon Store Group (DSG) in Europe and in Circuit City in the U.S. NOTE: The cartridges for these printers are sold exclusively in these stores or on their websites.
Explanation
The printers listed in the table below are compatible with a #2 cartridge (in single cartridge printers) or a combination of #2 and #3 cartridges (in two-cartridge printers). They do not support the standard color 28A 35, and Mono 29A 34 ink cartridges. If the standard color 28A 35 or Mono 29A 34 ink cartridges are used in these printers, they will fail to print and the printer will post an Unsupported Cartridge error message.
Solution
Lexmark recommends using either a #2 cartridge for single-cartridge printers or a combination of #2 and #3 cartridges in two-cartridge printers.
Cartridge compatibility chart
NOTE: These printers are sold exclusively in the Dixon Store Group (DSG) in Europe and in Circuit City in the U.S. The cartridges for these printers are sold exclusively in these stores or on their websites.
Item Printer #2 Color Cartridge #3 Mono Cartridge #31 Photo Cartridge 1 Lexmark Z738 Yes ... ... 2 Lexmark Z1380 Yes Yes Yes 3 Lexmark Z1480 Yes Yes ... 4 Lexmark X2480 Yes ... ... 5 Lexmark X2580 Yes Yes Yes 6 Lexmark X3480 Yes ... ... 7 Lexmark X3580 Yes Yes Yes 8 Lexmark X4580 Yes Yes Yes
Nov 07, 2010 | Office Equipment & Supplies
I installed a new print cartridge into my printer... after installing the new cartridge "install print cartridge" window prompt shows "unsupported cartridge" and instruct to install a correct print...
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Oct 12, 2009 | Dell 810 All-In-One InkJet Printer
IBM Infoprint1120 and Lexmark T520 toner cartridges.
You cannot use Lexmark toner cartridges in IBM models and vice-versa because the toner carts have a smartchip that identifies the toner to the printer. IBM printers expect to see IBM toners and Lexmark machines expect to see Lexmark toners. If you put the wrong cartridge in you will get '32' Unsupported print cartridge error.
Some refillers may swap the smartchip when they refill cartridges and this would be the only reason why you may have seen it done before.. IS your current toner a refilled one? It's technically possible to make an IBM printer into a Lexmark printer to accept Lexmark toners by replacing the System Board... but why would you bother doing that...just use the right toner.
May 19, 2009 | IBM Infoprint 1120 Laser Printer
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
Unsupported cartridge message
I was having this problem with a Z730. The printer was finally working again after removing and inserting ink cartridge like 40-50 times. No pun intended. After installing cartridge try turning off printer and then back on.
Aug 19, 2008 | Lexmark X2470 All-In-One InkJet Printer
Jul 31, 2008 | Dell 924 All-in-One InkJet Printer
Unsupported printer cartridge
uninstall printer, reboot and then reinstall using the lexmark printer cd or downloaded drivers.
Mar 10, 2008 | Computers & Internet
Incompatible print cartridges?
just click on them to say ok, and accept the unsupported cartridges ( if applicable ) do you get the choice.
certain printers, have an option in printer prefs, to change cartridges. check the cartridges are the same ( or compatable )
if the cartridges have a chip fitted, they need to be reset if recently filled.
hope this helps mike @ Compurepair.
Feb 20, 2008 | Lexmark X2550 All-In-One Printer
32 UNsupported Print Cartridge
This error means the incorrect toner is installed. Most toners for similar printers will fit, but they have a chip on them to make it so it only works with certain models. Please make sure this is the right toner for the model printer. If it is and you still receive the error, you should try to return it to the place you purchased it from, as it is defective.
Nov 16, 2007 | IBM Infoprint 1352 Laser Printer
IBM Infoprint 1332 Laser Printer Logo
156 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
