Question about Panasonic DMR-ES10 DVD Recorder
Self check for over an hour
I put a poorly formated DVD into my Pasasonic DMR-ES10 and it went into Self Check for a long time. I unplugged the machine and let it rest over night. When I plugged it back in in the morning, it went right into Self Check and stayed there for over an hour. If the problem is the bad DVD, is there a way I can manually eject it and try again? Jim from New Jersey
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
While the unit is switched off, Jim, press and hold the STOP and Channel Up buttons (BLACK SQUARE and CH/\) on the unit (NOT the remote) for 5-10 seconds and your disk should eject.
Posted on Apr 18, 2009
  • kiotokev
    kiotokev Jun 15, 2012
    solution does not work
Can't record DVD+RW and DVD+ Disks...PLUS
Firstly, you need to finalize the -R disk recorded by and in your unit before it will play back anywhere else.
Secondly, the DMR-ES10 does not support +RW, only -RW.
Finally, I have never heard of a +D. Do you mean +R? It is likely that you have a corrupt disk; change it.
Mar 11, 2009 | Panasonic DMR-ES10 DVD Recorder
Tip
DVD stuck on Panasonic DMR ES10 in eternal cycle of "self check"/"please wait"
My DMR ES10 was eternally in a "self check"/"please wait" cycle. Couldn't even turn it off normally. By pressing the "Power off" for 10 seconds it will turn off forcefully. Now, after it says "BYE" press the "CH UP" (on the recorder, NOT on the remote))+"STOP" (with the recorder turned off) for another 10 seconds. This will force the opening and we now can take the DVD off. Turn the DVD recorder ON and, if the problem is on the laser, because of dirt, etc it will work and we can now run a DVD cleaner. In this case, the machine was stuck just because the first thing it does is check the DVD inside, and because it can't and just keep trying, it will never do anything else, until we take the DVD off with it turned off.
on Oct 18, 2013 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
Mar 08, 2009 | Panasonic DMR-ES10 DVD Recorder
No user guide
hi....Download instruction manual of DMR-ES10 by clickiing this link http://service.us.panasonic.com/OPERMANPDF/DMRES10.PDF. It is PDF file and can be open / print through adobe reader . for adobe reader, go to www.adobe.com.
thank u
rate me
Feb 08, 2009 | Panasonic DMR-ES10 DVD Recorder
Dmr es10
I guess you must've hit a sequence on your remote to lock it up, try unplugging for a few hrs and turning it back on to see if it goes back to normal.
Oct 17, 2008 | Panasonic DMR-ES10 DVD Recorder
Dmr es10 dvd recorder
Check connections, cables, settings and read both the instruction manual's troubleshooting section.
Sep 16, 2008 | Panasonic DMR-ES10 DVD Recorder
Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Mar 16, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr-es10 firmware?
How do I check the firmware on a DMR-ES10
Oct 16, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES15
Just unplug it and let it sit for half an hour. Then try playing the lens cleaner disc, the problem would be fixed....
Sep 10, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10 DVD Recorder Logo
405 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
