Question about Dryers
Ge profile dryer mod# DPXR473EW0WW
Help dryer is making grinding sound. Don't know how the cover comes off. tried taking out all of the screws.
  • 1 more comment
  • dfeldhaus1 Nov 05, 2008
    Dryer is making awlful noise, sounds like it coming from the back. I have the top off and sounds like a bearing is out. Don't think it spins on a bearing though.
  • edward botto Mar 14, 2009
    How do I access the belt to change it?
  • sean3 May 03, 2009
    mechanical noise during drum revolotion. Sort of grinding but not during the entire revolution and seems to come from beneath the drum. No squeals or sqweaks. It happens primarily when loaded with clothes.
  • Dryers Master
  • 8,220 Answers
GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 27, 2009
  • 883 Answers
Dryer covers are attached with both screws and locking tabs. these tabs are designed as bent metal that creates a spring effect to mate to the next cover. either pull the cover off in an upward direction or away from the dryer in rapid motion to unlock the tabs.
Posted on Sep 16, 2007
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
I need to replace the door switch on my GE Profile Gas Dryer DPSB620GC4ww and don't know how to get behind the panel on the front of the dryer. Can you give me detailed instructions on how to do this?
unplug it,open the door and look up,you'll see two phillips screws,take them out and remove the top panel,if you want to remove the front panel just remove the two phillips screws one on each side of the panel around 4 inches down from the top.
May 20, 2011 | GE Profile DPSB620GCWW Gas Dryer
My dryer makes a horrible high pitch squeaking sound when it is in the dry cycle. It is about 11 years old. GE profile front load.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 05, 2011 | GE Dryers
I have a ge profile and when it is starting it makes a gringing noise but the belt seems ok. When I turn the setting to air dry the grinding sound stops. Could it be something with the heater/gas line...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 10, 2010 | GE Dryers
I have a GE Profile Harmony Dryer DPGT750. The machine makes a loud, almost grinding noise when the dryer is operating. It also sounds almost as though the drum is out of balance. It is more noticeable...
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 26, 2010 | GE Profile Harmony DPGT750EC Electric...
GE dryer won't start up - sounds like the drum is stuck.
unplug it,open the door and look up.you'll see two screws,take them out and remove the top panel,then look around three or four inches down from the top and removetwo more screws,one on each side,this is harder than most dryers to work on,not much room to reach under the drum to remove and reinstall the belt,there's also one more screw down on the right hand side below the drum that has to come out also, just remember how you took it apart,if you start it and hear a loud humming sound that's the motor,hope this helps you
Feb 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
My GE Harmony Dryer is making a LOUD noise during entire cycle
heatman101
yue
Jan 26, 2010 | GE Profile Harmony DPGT750EC Electric...
I have a G.E profile dryer dpgt750 cant seem to figure out how to take off the back panel, the dryer is making a loud noise sounds like possible belt problem. any ideals? THANKS MARTY
Marty, you need to remove the front cover on these and most dryers by removing lower front kick panel screws, then remove the front cover and then you access the top cover screws to remove top cover then you can access th drum belt
Nov 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
How do you remove the back plate of a GE profile Harmony. I have the screws out, the top off. Does the back plate slide up? Do the sides have to come off with the back? Or what?Please. Thanks
the back plate does not come off.
to get to the motors, belt, sensors...
remove the screws to the inner top cover(under outer cover) and the plastic strips- slide strips front or back to remove.
remove the screws to the front panel- 2 top front, 4 inside door.
as you pull the front off, unhook the light and the door switch
remove the scres to the front drum plate.
reach under drum and unhook belt-take note how it goes around motor and tensioner.
lift drum out and observe everything else.
Jul 30, 2009 | GE Profile Harmony DPGT750EC Electric...
Plastic box with wire on back of ge profile harmoney DPGt750
It's hard to tell for certain from your post, but it sounds like you broke the wire to a thermistor (part # WE04X10111). It is a little temp sensor which extends into the dryer about a inch with two same colored wires coming out of the exterior end. Easy to replace. remove cover, remove one screw holding thermistor. unplug white disconnect block. install new part. very simple, saved the $118, only cost ya the price of the part. (maybe about $35 or so) A FixYa rating would be appreciated. Thanks.
Sep 19, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
899 people viewed this question
Top Dryers Experts
Marvin
Marvin
