Question about HP Computers & Internet
Keys and touchpad locked up after boot up hp dv 2000. vista home premium installed.
  • megahit2006 May 11, 2010
    Tried booting up in SAFEMODE? The problem still persists?
  • NitrusInc
    NitrusInc May 11, 2010
    Let us know if you still have the same issue in Safe-Mode:
    To boot the machine in Safe-Mode:
    While powering up continuously hit F8.
    You will get a Boot Option Menu
    Select Safe-Mode boot
    Often times drivers, or system files may be "lost" or referenced wrong, and booting into safe-mode can solve the issues, sometimes.
My hp laptop with windows vista home premium is not booting and showing to insert bootable disk, which I don't have.how i can get this
The installed Windows in your laptop has been corrupted beyond repair - you will have to reinstall it.
For that pres F11 during boot to launch the HP Recovery Manager from the recovery partition then follow the instruction. If even that fails it means that the hard disk itself has failed - the disk will have to be replaced and to reinstall Windows you will have to order a recovery cd for your exact model from HP.
Jun 21, 2011 | Microsoft Windows Vista Home Premium with...
I have the photo printer for 4 years, just installed it with original ink cartridges, the printer prints regular text just fine, but in trying to print photos, the photos come out very red with no...
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 28, 2010 | HP Photosmart 8450 InkJet Printer
Instaling windows 7 in vaio laptop have vista orginal windows how solving the problem in instaling windows 7?
if your system came with vista originally the issue would be is you would need to know what version of vista you have on your system, the version makes the difference if you have vista home premium then your windows 7 should be a win7 Home premium as well, because if you are upgrading vista using your win7 disc and your windows version are different for example you have vista Home premium and your win7 is win7 ultimate and you do an upgrade the problem will be your product key,
but if you have a retail version of win7 and you are installing it on your laptop Vaio insert the disc in the DVD-drive win7 needs a DVD reader to be able to install win7 if you have a cd-rom it wont work, then turn the laptop off power it back up keep on tapping f12 it should bring you a boot menu, select ODD or which ever is your dvd drive then press enter then enter again if it says on the screen press any key to boot to CD, this should begin win7 installation on the screen saying windows is loading files the so on ans so fort ^_^ this will over write everything in vista but in win7 it will still create a windows.old folder from vista only from the my documents folder my picture and my music and my video and desktop Items but remember application icons will not work on win7 you may need to reinstall the program again for it to work on win7 and yeah make sure that you choose custom/advance in the selection screen do no select upgrade unless you vista and win7 are the same version eg. Vista Home premium / Win7 Home premium ^_^
Jun 03, 2010 | Sony VAIO VGN-FW390JFB Notebook
I have oem vista home premium and need to format
most computer makers put the restore on a partition of the hard drive that is accessed using an F-key on bootup. You should see f-key options displayed (very quickly) on booting up and one will be "restore". For example, on an HP machine, it'll be F11 you hit on boot up to go into the restore partiton.
Feb 07, 2010 | Microsoft Windows Vista Home Premium with...
My machine is Acer Aspire M7711 preinstalled with Genuine Windows Vista Home Premium.CPU Q8300, Geforce GTX 130, 600GB Default RAID Mode, 4GB Memory. My problem is Vista Home Premium Installation...
Im assuming its a new machine and when you first booted Vista failed. When you boot up, press the F10 key. This will take you to a menu to start your Acer machine from the begining. It takes a while for the first complete boot. I hope this answers your question. If not, post back and we'll diagnose your problem again. Best of luck!
Greg
May 15, 2009 | StarTech.com StarView SV211K 2-port KVM...
HP Pavilion dv6000 OS(s)
The product key on the label on the bottom of the laptop will only work for the version of Windows that was installed on that laptop.
You can purchase an upgrade Windows Vista Ultimate and to use in conjunction with the existing Vista Home Premium.
Mar 30, 2009 | HP Computers & Internet
Windows vista home premium avtivation key
You will find this key on the packaging that your Windows CD came in. The keys are not interchangeable. Hope this helps.
Dec 27, 2008 | Microsoft Windows Vista Home Premium with...
Product key problem
If your system is usable you can download a free utility that will tell you the product key from here:
http://www.fileguru.com/SoftKey-Revealer/info If you are installing Vista and don't have a product key then you will need to buy another package. I suggest the Vista Home Premium Upgrade.
Nov 24, 2008 | Microsoft Windows Vista Home Premium with...
How to upgrade from Vista Basic to Vista Premium.
You need a Vista premium disk to upgrade to Vista premium.
Just instert the Vista premium disk and start the installation.
If installation does not start, you will need to boot from setup CD, sometimes you have to change the bios boot sequence in bios settings, to start the installation from CD.
Nov 16, 2008 | Microsoft Windows Vista Home Premium with...
Need to change my operating system from Vista Home Premium to Windows 2007 Home/Student. How do I perform this task?
when you have the installation disk ,put it inside the drive and then reboot...
set the dvd drive as primary boot device ...
it will ask to press any key to boot from dvd..
on pressing it will lead you into series of steps that will install the 2007 student on your system.
thankyou
regards,...
JC
Aug 13, 2008 | HP Computers & Internet
Computers & Internet Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
