Question about Samsung HLN617W 61" Rear Projection HDTV
Problems with intermittent green snow
I am having problems with intermittent green snow that changes with the picture. I still have normal colors, they just have splotches of green snow. It does seem that the frequency is getting much worse. The set is just over 3 yrs of age and had been doing this on an off for more than 1.5 yrs. Before it was always infrequent and would go away quickly. It is there on all inputs and sources. I have pics if it would help.
  • 1 more comment
  • mark_g Sep 16, 2007
    Here is the picture of the problem. I clipped a portion of the image to make the size OK
    Definitely on all inputs, and varys in severity. For instance at this moment the vertical green snow in the unused areas of the screen have disappeared. Right now it is light green snow in the image.
    Looks like samsung has seen this before, because they have a section in their faq that describes my problem.
  • Anonymous Nov 15, 2008
    Green snow only occurs in black areas on screen, so it seems. Has anyone tried a new DLP Lamp?
    Genius:
  • 1,153 Answers
Looks like green horizontal lines, this is definately some type of filter problem. Looks like in the HV or Horizontal are. It first looks like turner problems but you say it's on all inputs. Then if that's correct it's not the tuner.
Posted on Sep 16, 2007
Have Panasonic plasma mod TH-58PZ850U . Have picture but, has a lot of green. What could be the problem?
Your cable box or satellite receiver could be causing the green screen. We recommend you ensure the box's 4:3 Override has been changed to Stretch or Off and Color Space has been change to RGB.
May 06, 2014 | Panasonic Televison & Video
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
Samsung Tantus Picture Problem. Green Yellow Black Hue
it seems that your unit got loosed contact.i mean it needs resoldering.call a technician to do further troubleshooting.
May 11, 2009 | Televison & Video
Picture or Color Problems
There may be an intermittant fault on the CRT driver board, or there is an intermittant breakdown in the CRT electron-gun area. CRT problems are more common in these TV sets.
Jerry G.
Nov 18, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
Oct 22, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
HCL4715W Green Color intermittently projecting
It sounds like the common problem with this set. It is an intermittant picture tube, or there is a loose connection on the green drive board on the green picture tube. Try lightly tapping all around on the green drive board while the set is on and see if you have any change. BUT BE VERY CAREFUL! Lots of high voltage on the board. Also use a plastic or wooden device to do the tapping. If you do great, you know you need to resolder the connections on the board or clean the CRT socket on the green drive board. If there is no change, I would bet the green CRT is on its way out. But try tapping the green drive board all over as I said before, that is a very very common fault with these types of TV sets. Good Luck
Aug 16, 2007 | Samsung HCL4715W 47" Rear Projection...
Zenith 25" Color TV - Model A25A23W
Your problem is a bad connection on the CRT socket on the CRT driver board, a bad connection in the RGB driver supply from the video jungle IC or maybe even an intermittant Picture tube. the only way to tell would be to tap on the crt board while the sets playing with a non conductive insterment, and see if it changes. Now there is alot of HIGH VOLTAGE at this spot, so if you have no TV repoair experience Please stay safe and call in a pro to assist you. Good Luck Please dont forget to rate this thread.
Nov 11, 2006 | Zenith A25A23W 25" TV
Constant changes in picture colors.
It is a 20" TV set and will most likly, im afraid to tell you, cost more to fix then it is worth. The problem is a bad Picture tube, an intermittant CRT socket or the video jungle IC is intermittant. If you want to invest in an estimate, check out first if it will go towards the repair, as then maybe you can get it fixed at a good price, as long as the picture tube is not the problem Good Luck
Oct 07, 2006 | Toshiba 20AF46 20" TV
Samsung HLN617W 61" Rear Projection HDTV Logo
135 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
