Question about Yamaha RX-V596 Receiver
Input selector on my Yamaha RX-V596 stuck
I have had this Yamaha RX-V596 for a few years and it has worked flawlessly. Suddenly today the input selector on the front panel is stuck on "V-AUX" position and the display shows "External Decoder" Turning the input selector knob does not change the setting or the display. The knob spins but the setting still remains at V-Aux and the display shows External Decoder. So, I'm not able to listen to any of the inputs - TV, DVD player, CD player, tuner etc. Please help. Thanks Dush
  • Anonymous Mar 30, 2014
    I want to listen to the tunes on my Samsun Galaxy S2 on my stereo.
  • 1,512 Answers
Hi Dush
Sounds like the processor has locked up in the unit. Try powering it right down from the wall socket for a day to reset, and then retry operation. If that does not work, leave it disconnected for about 10 days to erase backup memory completely and then try again. Good luck. Don't forget to give me a "FixYa" rating if this works. If it doesn't, get back to me in here and we can talk more about it.
regards
Graeme
Posted on Feb 16, 2008
SOURCE:
Can't find hdmi input selection on Yamaha rxv1600
Depending on what you are connecting to your HDMI inputs, rotating the input selector on the front panel (or one of the input selector buttons on remote), to which you've assigned the component on HDMI 1 or HDMI 2 on the back panel should give you the connection. Make sure you have an HDMI component connected to it, and that you're using its HDMI out connector (eg. output of DVD to input on your Yamaha). Hope this helps.
Dec 10, 2013 | Yamaha RX-V1600 Receiver
How to connect Niles #SSVC-6 Speaker Selector to Yamaha RX-V671
Greg, It pretty basic hookup,Just hook it up to your speaker terminal on the reciever or amp.To the input of the (Speaker) Selector.
Oct 04, 2012 | Yamaha RX-V671
I have had my Rx-V596 receiver for years and just last week I started hearing a constant humming thru the speakers regardless of what input source is selected. I have checked all the cables and can not...
Most likely suspect is a breakdown of a capacitor, probably in the power supply -- one of the few modern electronic components that go bad over time. You'll probably need a Yamaha service center to get it fixed -- they'll give you an estimate before starting, but it may be a better investment to upgrade to a new receiver. It takes a skilled tech to fix this at the component level -- doubtful that replacement boards are available.
Feb 02, 2018 | Yamaha RX-V596 Receiver
Can an ipod or mp3 player be hooked to a Yamaha RX-V596, using an auxliary cord
Typically you can find an adapter / cord that contains a 3.5mm headphone plug on one end and a pair of RCA plugs on the other. These RCA plugs should be able to be plugged into any available input on a receiver that isn't a PHONO input. These cables can typically be found online at various different places. Not to promote one site over another, but I have had good luck finding random cables like these at Cableswholesale.com and allelectronics.com. Hope this solves your problem.
Thanks,
Ben
Mar 29, 2010 | Yamaha RX-V596 Receiver
Is the Yamaha RX-V596 capable of using HDMI in
Nope. Use S-Video or composite video In and digital audio in from the Cable Box, S- or composite-video out to the TV/Monitor.
OR (what I do) skip the receiver as a video middleman and take the HDMI video right to the TV; and run the Cable Box digital audio to the Receiver.
Feb 18, 2010 | Yamaha RX-V596 Receiver
Yamaha RX-V596 main rigth channel problem
The right or left (side) output channel has blown out. If it uses discrete transistors you'll have to replace two of them (one PNP and one NPN) along with several resistors that are part of the circuit (I'm guessing the static occurs on any input source).
Now , if the static happens only on certain input, then the problem should not be in your amp.
May 21, 2009 | Yamaha RX-V596 Receiver
Receiver Shuts Off Only When TV Input Is Used
I think your Receiver is going into protection mode. This happens especiaally when speaker cables are not connected properly. They are either loose or are touching each other or to the body of the receiver or the speaker ha blown.
You are lucky that it has not blown any transistor of your Receiver.
Please immidiately disconnect all your speakers cables and the cable form the mian.
Reconnect only the cable from the main and try to select the TV, it will switch on. If it switch on then you can be sure it were the speaker cables.
Now power off, main cable off, put all the speaker cables back and see if the everything all right.
If you still have a problem, let me know we can futher trouble shoot.
Best of Luck.
Please rate this solution and thanks for using FixYa!
Mar 08, 2009 | Yamaha RX-V596 Receiver
Hooked up to sony bravia 52" tv and can barely hear sound
You'll want to turn of the TV speakers in the Remote Menu and try turning up the volume level of the TV, which usually controls the level of the RCA outputs, as well
RX-V596 center and rear channels do not have any sound
Nevermind... My center channel output was set to "NONE" I've had this receiver for a few years now, probably set it that way back when I got it. Oh well, Helps to re-read the user manual...
The info is in the "SET MENU" section of the manual, Pages 35-38. Should solve the issue for "almccrum" above as well.
If you don't have your manual it can be downloaded here:
www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V596.pdf
Oct 06, 2007 | Yamaha RX-V596 Receiver
Yamaha RX-V596 Receive turns off after pressing Power
Sometimes the receivers turn off if the speakers are shorted in order to protect the AMP circuit. So try this - 1. Disconnect all cables (speakers), inputs from Tape Deck, VCR and other input devices), sub-woofers, rear speakers all. Except the AC power cord. Then turn it ON and see if it stays on. If it still has the same problem, then most probably your power circuit inside the receiver has a problem - like a shorted Capacitor or diode etc. Based on how technical you can be and what resources and time you want to spend, this is repairable. But based on the price of a receivers these days, it is not worth. Good Luck!
Aug 30, 2007 | Yamaha RX-V596 Receiver
Yamaha RX-V596 Receiver Logo
529 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
