Question about Canon i850 InkJet Photo Printer
Printer wont print in color and i just replaced with all new ink cart.
  • ljp665 May 10, 2009
    I had a similar problem, I haven't attempted to print in colour for sometime, but my printer now won't print in colour. I did a nozzle check and deep head cleanig, the nozzle check did not print the colour. Replaced all the colour cartridges. The nozzle check is fine for black but streaky colours appear at B,G,L and M.
  • 385 Answers
new cartridges can be defective also.
Remove and re-insert the cartridge, double check them,
( leave printer on )
Check printer's Advanced properties are not set for black only,
switch off at mains, reboot,
Run maintainance on it, head cleaner, nozzles etc...
if the same, swap out, the color cartridge it is faulty.
Hope this helps
Regards.
Posted on Apr 16, 2009
What cause lose of new ink on aligning cartridges.
Unfortunately, the printer does not actually measure the ink in the carts, but measures how many droplets called for. The carts may actually be full, but the printer now thinks they're empty. Most likely the black ink needs to be "charged" because you've cleaned out the pipe. I don't know what to do to charge it, and you'll likely need new carts.
Sep 11, 2014 | HP Officejet Pro 8500 All-in-one -...
Problem with replacing color ink cart. #5
Is it the right Cartridge you are trying to install please check and then check if the sensors are working.
Mar 31, 2009 | Lexmark X2600 InkJet Printer
Print colors
You might want to run a cleaning page through it. This uses up more ink that a typical print job, but it will allow you to clean the heads and force ink through them.
Feb 14, 2009 | HP PSC 2110 All-In-One InkJet Printer
Prints very faintly, cant read at all. printed configuration page and got nothing but some block lines colors yellow, red, blue but no printing. Printer is new and has not been used much. was alright a...
well ushally the ink carts have exporation dates incoded in them so after those days it almost automatically turn them off.
when you buy a new computer ink carts are 25% to max 50% full but your printer would read them as full as well
try new ink carts or contact your manufactuer and tell them that your issue and chances are its a dryed out ink cart and they will ushally send you replacements for free.
Aug 03, 2008 | Office Equipment & Supplies
Printer cartridge missing
Make sure ur using the correct cartridge.....
for X2580 the cart number is 2 and 3
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts
Clean the ink nozzel using a wet paper towel.....do not whip it ..just press and hold the nozzel....do this 3 or 4 times....
then
Install the carts...
open solution center.....click maintence tab...click on "clean to fix horizontal streaks"...
-----XXXX----
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
Brother MFC-640CW Replaced Black catridge becomes empty
Compatible carts do make a lot of trouble. One point is the draining! The ink has flown into the cart assy and beyond that to the bottom of the printer. As long as you can print without problems you dont have to do anything. If the test pages wont show the correct color you have to open the printer and to clean the assy and the bottom.
Do use original ink carts though these wont drain and give correct info to printer. You can very simple refill them with dye ink. Dye ink only!!!
Oct 16, 2007 | Brother MFC-640CW All-In-One InkJet...
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Canon i850 InkJet Photo Printer Logo
112 people viewed this question
old marine
old marine
