Question about Minolta Maxxum 7000 35mm SLR Camera
Display Problems... I've never had any problems with the display screen before & now all of a sudden the numbers are half gone [like a broken digital clock]. I've tried changing the batteries, but nothing seems to be working. It's very difficult to read my settings. Also, when I look through the viewfinder, the light meter numbers are like that too.
  • Anonymous Dec 30, 2007
    Minolta maxxum 7000 -- looks like all my electronics are shot. Talked to the local camera dealer and he said it is not worth fixing. After looking on EBAY i tend to agee with him, they are not fetching a very high price. Was my fathers camera so i dont really have an investment in it and i am going to give it to some camera buff that might want it and buy a new digital.
    d.miller
You can also buy the camera parts on Ebay from JDCatz he is from New York and if you cant instal the part he can for a few bucks and he won't over charge or charge to much he is a minolta camera dealer. Hope I was a help Russ
Posted on Feb 04, 2009
SOURCE:
Samsung range with digital display not working properly. Clock shows half of the numbers.
Replace the display board. There will be a segment driver that has failed.
May 06, 2017 | Samsung Ovens
Toshiba Satellite A505 - Most of the time when I turn it on the screen is grey, with no text.
This sounds like a bad display on the laptop. Hook up an external monitor to the vga port on the laptop. You may need to toggle the display to output to the external monitor. This is generally accomplished by pressing the "FN" key + one of the F# keys. Look for an icon that resembles a monitor or it may say LCD. If the graphics display correctly on the external monitor, then you will need to replace the computer screen.
Dec 29, 2012 | Toshiba Computers & Internet
The 17.1' display of my toshiba satellite P105 its broken, two white lines blocked de screen, and 1 half of de screen its blocked by blacki need the part number or de model of de display for replace my...
Just a quick note, before you go replace the entire screen, make sure it's not just a wiring problem. If so, it doesn't cost as much to replace the wires connecting the screen to the laptop. LCD's are much more expensive!
As for replacing the display, this website has information on the display, along with the ability to purchase it from their site. http://www.pelltechnology.com/Toshiba/Laptop/Toshiba-Portables-Satellite-P105-Series-S6024/Toshiba-Satellite-P105-S6024-LCD-Screen-Replacement-P350475.asp
Hope this works!
Apr 11, 2011 | Toshiba Satellite A105 Notebook
I have 17" LCD viewsonic
Yes you can if you can source one however it may be more cost effective to replace the monitor.
Nov 03, 2010 | Computers & Internet
HP Pavilion DV2799ee - Display Problem
You actual Video card has gone faulty, probably from Overheating, either that or the "Coin" is twisting the board and it isn't making contact with the socket or such.. Generally by the time you see "Artifacts" the card has already been damaged, however slight.
Mar 09, 2010 | Computers & Internet
Have a vivitar 8625 and the display screen went
Maby but odds are This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Jan 01, 2010 | Vivitar VIVICAM 8625 Digital Camera
Problems with my motorola v3x
if the display on your screen is only half of it, it means that the theme installed in your fone is not for motorola v3x.
with regards to the backlight, the connector from the lcd to the board is loose.
if you can only see the white light, it means that your fone is running an application, loading or hanging up like what's happening in pc's.
i think you need to master reset your phone and put only a 256memory card. even though it is said to carry up more, just stick with the 256 memory to avoid those problems.
Oct 28, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Compaq Presario laptop
First attach laptop to an external monitor and using the FN/ F keys toggle back and forth to the external display. If the external works OK then the video display adapter is fine and the problem is the TAB welds on the LCD. Time for a new LCD.
Jul 27, 2008 | Computers & Internet
LCD screen display
not the screen but the flex ribbon that connects it to the other half of the phone is probably broken
Oct 30, 2007 | Samsung SGH-D500 Cellular Phone
Blank screen
This sounds like CCD sensor is faulty and should be replaced . Camera works fine in playback mode generally with this problem but not in capture mode ( camera has gone 'blind'). Should be repaired free of charge if the camera is as old as you say.
Aug 16, 2007 | Olympus FE-170 Digital Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
74 people viewed this question
Top Minolta Photography Experts
Ekse
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
