Question about Whirlpool Duet GHW9150P Front Load Washer
Mildew odour from Whirlpool Duet washer.
The odour is persistent. I've tried baking soda, vinegar, tang crystals, they all work temporarily. Is there a permanent fix?
I've had this problem a couple of times over the years I've had this washer. What caused the odour in my machine was one (or more) of my kids' socks getting stuck in the machine. With the door open, gently reach in and bend the grey rubber door seal back and feel for clothes that have slipped between the drum and the rubber. If there's nothing there and it has been smelling bad for a while, then it's likely that the socks have been sucked into the drain. To clear this without paying a $150 service charge (I did that the first time and watched him fix it in 10 minutes), you'll need to remove the bottom front plate of the washer (there are only three or four Torx -or star head- screws holding it on). Once that plate is off, you'll see a white plastic knob that is the cap of the drain trap. Unscrew the cap and a couple of cups of water will leak out so shove a couple of towels under it beforehand. You should find some long-lost now-rotting socks. The last time I had to do this, I found FOUR socks in there. This also contributes to the 'suds' error message as it prevents proper drainage. I've only had this problem with kids' socks, everything else is too big to get stuck, I guess. Maybe try a laundry bag for the smaller stuff.
Posted on Apr 17, 2009
Can I put baking soda in my whirlpool front load washer to wash new sheets?
Hi Ursula B,
You can put baking soda in your washer safely with no harmful effects.
Another good use in your front loader for baking soda.put 1/2 cup of vinegar in your washer soap dispenser,and 2 or 3 tablespoons of baking soda in the fabric softner dispenser and run a hot wash to clean and refresh your washer.
May 02, 2014 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Kenmore glass cooktop discoloured
I use a straight edged razor blade on mine and it finally got clean
Nov 15, 2012 | Kenmore Frigidaire Glass Cook Top...
How can i remove fish odour from my fridge
try bicarbonate of soda, fish has got to be the worse thing to leak in a fridge. make sure you get in all the nooks and crannies lol. failing that buy a new fridge
Dec 09, 2011 | Refrigerators
How do I get the burned smell from my Whirlpool microwave. All I did was overheat a biscuit. We've tried vinegar, baking soda, Fabreeze and lots of other stuff. Can you please help us? Thank you. ST
Spray the inside with Dow Scrubbing Bubbles Bathroom cleaner, let foam, wipe clean, and rinse. Then if the odor persists, mix one part vinegar, two parts water in a bowl, set inside the Microwave and turn on for five minutes.
Jun 15, 2011 | Whirlpool MH7135XE Microwave Oven
The washer has a musty/sour smell to it...any way to clean it?
There are several things you can do. First you might try filling with hot water and dissolving 1 cup of baking soda. Let it sit for about an hour. Then complete the cycle and when done, leave the top open so tub will dry completely.
Second, you might try the same thing but use 1 cup of chlorine bleach. Let it sit for about 30 minutes and then complete the cycle. Again, leave the top open so the tub will air dry.
Finally, you can fill with hot water and use 1 cup of white vinegar. Let it sit for an hour and then follow the same procedures above.
Once you've run the cycle, you can wipe down the interior edges and under surfaces with a rag that has been moistened with the solution of vinegar or chlorine.
The baking soda neutralizes odors. The chlorine bleach will kill mold and mildew spores. The vinegar is acidic and it too will prevent the mold and mildew from growing.
Once you've freshened the washer, remember to leave the top up after you've completed all the laundry so that there is air and light entering the tub. Mold and mildew do not live well in bright, airy environments. I hope this helps. If so, please come back and comment on my suggestions!
Jun 02, 2011 | GE WJRR4170BT
Freezer smalls fishy. I've had baking soda packs in tehre, have cleaned teh whole fridge twice.
Try baking soda mixed with vinegar. If it still persist try with potassium per-magnate mild solution. Word of caution test first on little surface to see it does not affect the fridge lining.
Dec 19, 2010 | Kenmore 64802 Top Freezer Refrigerator
Mold smell comming from duet washer
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dishwash smells like rotten food even after a fresh wash
I switched back to powder (Cascade) from pre-measured gel packs and the smell went away.
Sep 03, 2010 | Electrolux 24 in. EDW5505EPS Stainless...
Whirlpool Duet GHW9150P Front Load Washer Logo
352 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
