Want 2 use both ethernet as well as wi fi simultaneously
How to configure my PC settings so that I can use both my PC(ethernet) snd laptop(WiFi) for internet simultaneously At first I could use only the Ethernet on the PC....after changing the settings I can now use only Wi FI
  • rahulmic Apr 17, 2009
    i have done exactly the same thing but still only the wi fi works.I cannot use the net through ethernet port.......
  • 126 Answers
U can use both things 2gether.u have to configure ip at both places,on lan n also on wifi
mail me for further help ajinkyapai@gmail.com
Posted on Apr 16, 2009
  • ajinkya painginkar
    ajinkya painginkar Apr 17, 2009
    WA3002G4 (Type-IV)
    Connectivuty : 4 LAN / WLAN
    • Connect ADSL Modem to your PC through Ethernet
    • Configure TCP/IP setting of the LAN card
      • IP addres : 192.168.1.10
      • Mask :255.255.255.0
      • Default gateway : 192.168.1.1
      • Click OK.
    A new dialog box appears prompting you to input the user name and password required to access the Web-based configuration manager.
    • Use the default user name admin and password admin for first setup.
    • On the next page Click on Advanced Setup>WAN
    • Click on Edit Button of the WAN interface whose VPI/VCI is 0/35
    • In next window select Service Catagory as UBR Without PCR
    • Click on Next
    • Select PPP Over Ethernet (PPPoE) & encapsulation Mode as LLC/SNAP-BRIDGING
    • Type in your Username & Password as given by BSNL, PPPoE service name as BSNL, Authentication method as AUTO
    • Click on Next
    • Click on Enable NAT
    • Click on Next
    • Click on Save
    • In the WAN Setup window click on Save/Reboot to save all your changes
    Please note that the wireless security is most important to prevent any unauthorized access to/through your modem although LAN/USB connectivity is used
    How to configure Configure Wi-Fi security ?
    • Click on Wireless>Security
    • Select WEP Encryption as Enable
    • Select Encryption Script as 64Bit/128Bit
    • Enter 10 hexadecimal digits(0-9,A-F) for 64-bit encryption keys (Eg.a1b2c3a1b2) OR 26 hexadecimal digits for 128-bit encryption keys in the Network Key.
    • Click on Save/Apply
    Wi-Fi Configuration in PC/Laptop
    The above CPE configuration makes wi-fi secured network so no body else should be able to access Internet thorugh your connection. Hence you need to configure same WEP key in your PC/Laptop which you have entered in CPE wi-fi security configuration. For this go to the properties of Wi-Fi connection, select the tab Wireless Networks. Then select the wi-fi network name ( more than one networks may be present in your area, identify your network by SSID name which is configured in modem. Normally the CPE model name ( i.e. WA1003A) is factory default SSID setting) and click on Properties. Look for field Data Encryption and network ID, select WEP as Data Encryption and enter the network ID which you have entered in CPE configuration as Encryption Key.
    These steps may be different for different client Wi-Fi hardware/software. The screen shots of a typical example are given below.
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
My M800 won't cannot detect any wifi or network and i can't get online
try to connect via lan cable.if u get online then look for wifi switch !
Apr 09, 2015 | Computers & Internet
Lost my wi-fi on my toshiba l455
It's common that the switch that enables/disables wifi gets hit accidentally. I believe, on your model, that pressing the Function Key (Fn) and the F8 key simultaneously is the way to turn wifi on and off.
Aug 13, 2014 | Toshiba Satellite L455D-S5976 Notebook
No wifi possible
do you get an error message? Do you still see wifi networks being detected? more information please.
Jun 11, 2012 | Computers & Internet
Describe your 7" G-Netbook
There may be many reasons for this. Please check the following things one by one.
1. If you have another known good laptop then try it with your wi-fi router. See if the wi-fi router is able to connect to the internet
2. If you don't have another laptop then use an ethernet cable (RJ45) cable to connect to the wi-fi router. See if this helps.
3. While connected with the wi-fi router see if you can access the router. open any internet browser and type 192.168.0.0. you should get the router page. If you don't get then you have to configure the router first.
4. Check the internet settings of your browser. There will be "internet options" or similar in the menu of your browser. Click that. In the GUI you will get "connections" tab. Click that and select the proper wi-fi setup.
Jul 28, 2011 | Sylvania G-Netbook
Cant connect to wifi
Please tell what is your Wi-Fi LED status. what channel count you configured inside the configuration of router. Please be sure that your wi-fi signal is transmitting or the device is able to receive the wi-fi signal.And please tell what router you using as host and what device you using as receiver. Thanks for subscribing Fixya... All the best
Nov 15, 2009 | Computers & Internet
Can not detect wireless network on wifi enabled
Make sure on laptop wi fi switch is turn on.
Uninstall wi fi network adapter driver then reinstall.
Right click on my network places and click on property then right click on wi fi adapter and enable it and click on view available wi fi networks .
If you still not detect signal of router then You hav to reset router.
For thjat press RESET button for 10 seconds it is in back panel of router.Then it defaults.
then connect router to computer with ethernet cable then you can access it with below link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page.
Then set WAN settings as your isp.
GO to wireless settings and enable it .
If you want to secure enable WEP security and add wep code.
Enable DHCP.
Then save and restart router then check.
Let me know if you need further assistance.
Thanks.
Oct 28, 2009 | HP Compaq nx9020 Notebook
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Computers & Internet
Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
Dec 26, 2008 | Toshiba Satellite M45-S265 Notebook
About wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Feb 10, 2008 | Computers & Internet
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
1,390 people viewed this question
David Payne
David Payne
