Question about Kenmore Elite 45986 Front Load Washer
Dl code How can unlock my machine. I tried to unplug it I opened the top and check the wires everything is all in place.
    President:
  • 1,294 Answers
Press 'pause' & 'reset' together for about 5 seconds. The lock should come off. This is the child lock.
Posted on Sep 16, 2007
Washer sometimes will not work and a code comes on f dl what does this mean?
The DL code indicates a problem with the door lock. These washers need to lock the door before they fill with water. Then the door will unlock at the end of the cycle. The problem can be with the lock, the sensor that detects the lock status or the main control unit not receiving the lock message. Sometimes the wiring is the problem with the unit.
When the DL code comes on, can you pull open the door as easily as when you open the washer before starting the machine? If you can, then check if the wiring is sending the appropriate current to the lock. If the power is there, replace the lock. If the door has actually locked, then the problem is with another part of the system. Most washers will have a sheet with the wiring diagram and expected readings inside the machine near then main control board. This is accessed from the back of the machine above the wash tub.
I hope this helps.
Oct 16, 2015 | Whirlpool Washing Machines
What is an error code of DL?
F/dL error - Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
If all the connections are good replace the CCU.
Good luck.
Aug 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
It blinks dl and f
FdL code is the door lock code. The machine is unable to lock the door. The problem is in the circuit board located on the inside top of the machine. You can check for wires that may have come off (unplugged) on the board.
Nov 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code dl f, have tried turing power off, checking the door, and going to drain spin cycle--no spin---hit option button 4 times--- this only makes a clicking sound and then gives error code dl f
Hi
Thanks for using FixYa. Error “dlf” or "F dl"means a door latch failure. This means that you’ll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it’s unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code F DL
https://secured.whirlpool.com/Service/...nsf/.../Duet%20Job%20Aid.pdf
I think Duets have a propensity to have door lock failures...Why removing the surge suppressor would make a difference I have no idea.
F/dL Door Lock Error
http://elektrotanya.com/whirlpool_ghw9100l,9200l.pdf/download.html
service manual above/
Apr 10, 2010 | Whirlpool GHW9100L Front Load Washer
In the middle of washing get an error that is f/dl or f/du. the door will not open even if you unplug it and plug it back in. You have to wait quite awhile and then try and it will unlock. It does this...
F/dL  and  F/dU error means -------------- Door Lock ErrorA Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.---------- to resolve ---------
Door Lock Mechanism broken or removed from the Door globul1a.gif Check Door Lock/Switch Assembly globul1a.gif Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Apr 03, 2009 | Whirlpool GHW9250M Front Load Washer
Get DL ...F ERROR CODE
hi,
Error dl f --
Condition:
Door Lock Error-
Check/Repair:
1. Door Lock Mechanism broken or removed from the Door.
2. Check Door Lock/Switch Assembly.
3. Check the wire harness connections to the Door. Lock/Switch Assembly and Central Control Unit (CCU).
4.Door Lock/Switch Assembly Failure.
good luck....
Mar 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
DL flashes over and over
unplug machine for 2 minutes this will reset the computer if problem continues look behind bottom front cover and there is a tech sheet that will tell you what the f code is the DL code is bad door lock assembly. it could be the main control (mother board throwing you these codes) Ive seen this happen before
Dec 14, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3t DL code
My husband and I had this same problem, but after visiting this website and reading through some of th posted solutions, we were able to fix our problem. Our 3-year-old Kenmore Elite H3 would not start on any cycle. It kept flashing the error code "dL/F", which we found out means "door lock failure." Taking advice, we unplugged our machine, removed the top panel, and rechecked the wiring. It worked! We think the wiring may have become loosened over time due to the jiggling vibration of our machine. Hope this helps you!
Oct 14, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
18 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
