Question about HP OfficeJet 9130 All-In-One Thermal Printer
Hp 9130 printing blue stripes on photos...
All of my ink cartridges are full, and i removed each one and shook them around and replaced them. But my printer is still printing blue stripes and off color for photos..yesterday it worked fine. Any suggestions?
  • 385 Answers
On the control panel, press MENU.
Press (up) or (down) to move to the item you want, and then press (select).
Go to maintainance.
Press - or + to select the value that you want, and then press (select) to save the setting.
If there is no - or + around the setting, the setting cannot be changed.
on the maintainance tab is,
clean heads, align, calibrate, etc..
Hope this helps
Regards.
Posted on Apr 16, 2009
I have an HP Officejet Pro L7590 All-in-One Printer (CB821A). For some reason it is no longer printing blue ink. I have put a new cartridge in and the digital indicator on the unit itself says it's full....
Hi David! I had HP Deskjet printer at my essay writers for hire company, but color cartridge failed after printed five color photos. So, you are happy man, because you have all colors without blue. It's not so bad.
Jun 07, 2017 | Office Equipment & Supplies
My HP Inkjet 6122 has suddenly started printing color photos with stripes. I don't use it very often, only when I need color photos. I have replaced both the #45 black and #78 color cartridges with genuine...
Use the HP Printer Assistant software tools to run a "head-cleaning" cycle -- the problem is not with the ink (there is plenty of it) but with the print-heads (that **** the ink, and then spray it onto the paper). Some of the jets are clogged, and so you get "white-stripes".
Aug 19, 2010 | HP DeskJet 6122 InkJet Printer
I need to remove/replace cartridge,i dont know how?
Hi!
This link guides you on how to replace the cartridge:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&product=79477
Replacing the print cartridges
  1. Turn on the power.
  2. Lift the print carriage access door on the front of the unit, just above the output tray. The print carriage will move into the middle of the access area. Figure 1: Raising the front access doorc00004385.jpg
  3. Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch and then pulling the lower section of the latch forward. Lift the latch.
  4. Grasp the sides of the ink cartridge and pull the cartridge out to remove it. Figure 2: Removing the cartridgec00004386.jpg
  5. Remove the replacement cartridge from its packaging. Touching only the black plastic, remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tapec00004387.jpg
  6. Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage as shown below. Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch). To install the optional photo cartridge (HP 58) for six-ink photo printing, remove the black print cartridge (HP 56) and insert the photo cartridge (HP 58) instead. Figure 4: Inserting the cartridgec00004388.jpg
  7. Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur. Figure 5: Latching the ink cartridges in placec00004389.jpg
  8. Close the print cartridge access door. Figure 6: Closing the access doorc00004390.jpg
  9. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Nov 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP Laserjet P1006 prints with blank white stripe down left side
Clean the Corona Wire carefully to remove any residue. As the charge on the wire is effectivley masked it cannot deposit any toner to the page and will result in a consistent white vertical stripe.
Aug 29, 2009 | HP LaserJet 1022 Printer
Color printout has shaded lines; rather than blue background, it prints blue striped background
It sounds like your blue ink may be running out.
If ink is full then try to remove an ink cartridge and putting it back, then run through the steps of printing the test page. It may be just that the pages are printing unaligned.
Aug 05, 2009 | Canon i850 InkJet Photo Printer
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
My hp officejet 9130 will not print in color.
Try runing the printer test and see if colors print. If they don't your color cartridge is cloged. You can try to set the print head(copper strip on bottom of cartridge) on a damp paper towel for a while to try and unclog the head. You should see the colors on the towel. Dry head off and try again. Hp uses water base ink and it will dry up after setting for awhile. The printer knows it has ink in the cartridge, because it will try to print, so it has to be the print head.
The print head has two lines of holes or jet for each color and if some of them are cloged, it will look striped or missing colors.
Mar 05, 2009 | HP OfficeJet 9130 All-In-One Thermal...
OfficeJet 9130 incorrectly reporting empty ink cartridge
Look to see if there is dirt or other debris inside the Magenta Ink slot. There is probably something there disrupting the ink flow. Use a flash light to see if ink is clogged. Use Acohol with Q tip to clean the area and reinsert the ink cartridge. Make sure the printer is off and the slot has dried before turning the printer back on.
Hope this helps. Helen
Dec 19, 2008 | HP Officejet 9110 All-In-One InkJet...
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
Printer problems,
i think the heads need cleaning click start ,click devices and printers, right click on the printer image, click troubleshoot and follow instructions.
May 07, 2017 | Canon BJC 8200 Photo InkJet Printer
HP OfficeJet 9130 All-In-One Thermal Printer Logo
246 people viewed this question
Seeker5211
Seeker5211
