Question about Garden
Found this presure washer in the basement and want to know if it works the motor runs when you plug it in but does not build press. The brand is kew hobby
    President:
  • 389 Answers
This may be as simple as still having air in the system.  Connect the machine to the water supply (but not the electric) then squeeze the trigger and allow water to flow for at least 60 seconds.  During that process, hold the nozzle outlet under the surface of water in a bucket so you can see when air stops coming out.  Keep going until you're sure there's no more air in the system.  Then switch it on.  If it still does not come up to pressure you'd probably be wise to abandon it.
Posted on Apr 18, 2009
Ridge presurer washer will not build presurer
Most likely broken or suck unloader valve
Aug 11, 2014 | Ridgid Garden
Kew 1640H with display flashing A 2 fault code
Hi really hope someone can help as I couldn't find a manual for my kew alto 1640hot and cold diesel pressure washer, problem is when I turn it on from been stood over night !i press on button and I see a f then a 1 flashing on the display ,anyone know what it means or we're the fault is,
Sep 18, 2011 | Garden
ENGINE RUNS FINE WHILE HOLDING THE WAND TRIGGER BUT , WHEN I RELEASE THE TRIGGER THE ENGINE STALLS OUT
you have a faulty presure relief valve. it is building up presure and killing the engine.
Jun 16, 2011 | Devilbliss DeVILBISS Devap DVH2600...
My Hobby88 pressure washer stopped working, now I
Could be just a faulty capacitor that helps the motor to start. You will find this next to the motor if you remove the top cover.
Mar 28, 2010 | Garden
Pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Dec 31, 2009 | Karcher 1750 psi Electric Pressure Washer
Water pouring out of the pump on my kew powerwash
Hi, You can get this seal set for a 1502v from nilfisk alto or any alto dealer.
Dec 27, 2009 | Garden
Kew hobby 80-1 instructions
I have a kew hobby 70 with little use. The nozzle wont spray, it just sends a weak jet of water. how can i fix it? I have hardly used it. It has been
in a shed for years . thanks
Sep 29, 2009 | Garden
Alto Kew pressure washer stopped working!
Hi Steve, In 3 years of repairing pressure washers I've only ever seen one of these, and am having a hard time remembering much about it, except that it was really awkward to work on! Strictly speaking, many small pressure washer repairs are uneconomical, because the labour time involved costs almost as much as the machine is worth. However, a "motor won't go" problem does narrow things down a lot. To state the obvious, we're looking at an electrical problem. The challenge is to find the cause! Did the motor stop while you were using it, or did it fail to start when you got it out of storage? If you are in the UK you should first check the plug-top fuse and the full length of the flex for any damage. If you have any kind of low-voltage electrical testing device, you can test for continuity between the live and neutral pins of the plug (with the machine switched on you should have continuity). If you have no continuity (and the fuse is OK) there may be a problem with the switch on the machine. Unfortunately, unless you are a really keen DIY person, there's not much you can do by way of self-help. A repair centre may be able to help you, but beware of costs spiraling beyond the cost of a replacement machine. I hope this will be helpful - if you can give more details I'll help further if I can. Good luck!
Aug 14, 2009 | Garden
We left the frig door ajar for 6 hrs, now the frig isn't working but the freezer is... where is the reset button? Thanks!!
Hi, No reset button. Check and make sure the evaporator fan motor inside the freezer is running. While checking that, look and see if there is any frost build up on the rear panelin the freezer. Please let me know if any of these are the case so I can asist you further.
Thanks
Vic
May 23, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Garden Logo
534 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
