Question about Whirlpool GEW9250 Electric Dryer
Whirlpool dryer doesn't work.
My whirlpool dryer (mod# GEW9200LW2/ser# MR3116676/type DADT-ELE-2406028-EL54) broke Tuesday morning. I had just taken out a load of dry clothes and put in a load of wet clothes. I push the button and it clicks, makes a beep, lights are on, but nothing happens. The light by "sensing" is lit. Nothing else happens. I tried using it on different cyles - same thing happens. I tried moving the drum on the inside and felt a little resistence, this was done based on what I had read on this website. I also tried the circuit braker in the basement and I tried unplugging it and plugging it back in - but I get the same result. The dryer is only about 4 years old. Any suggestions?
  • toysformen Apr 24, 2009
    I have same the problem with the DADT-ELE-2406024-EL54. The drum light and control lights are coming on. I tried resetting my circuit breakers, unplugging and replugging. I suspect that the door switch is bad. I need to know how dismantle so that I can replace the switch. What is the part number for the door switch?
JR JR
  • 116 Answers
SOURCE: Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Posted on Nov 30, 2008
  • 98 Answers
SOURCE: dryer will not start
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on Apr 01, 2009
SOURCE: whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Posted on Apr 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: MOD: REX4635EW2
Remove the back panel from the control panel to access the start switch. If there are 4 wires on the start switch,replace the start switch.
Posted on Aug 18, 2009
heatman101
  • 43501 Answers
SOURCE: i have a type DHZN-ELE-2406024-EL54 model
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
My kenmore elite he3 quit working model number DADT-ELE-2406024-EL54 do you know why?
The heating coil safety switch/fuse may have been activated if it got too hot in there. It is very common for escaped lint to finally build up where it should not be. The first thing is to learn how to remove the front of the machine and inspect for a build up of lint. Happens often over time.
Nov 05, 2014 | Kenmore Dryers
I have a type DHZN-ELE-2406024-EL54 model
heatman101
May 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
Feb 14, 2010 | Dryers
Whirlpool duet front loader dryer....sensing light won;t shut off
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
508 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
