Question about HP iPAQ RZ1710 Pocket PC
HP Ipaq rz1710
Device not used for a while and now does not switch on? Charged up battery, did a soft reset and hard reset. Device switches on now after soft reset only, boot runs, tap screen to calibrate and then it switches off...? Repeated process 10 times same result. Please advise Regards Werner
  • soluman_s Aug 11, 2008
    power went down whiile i was using it and after awhile i could not tap on the screen and i m charing it but there's no flashing light and i restart it though i press the power button for a while.pls help..
  • Anonymous Aug 13, 2008
    Will not start. Did not use for a while now not starting
    Problem Solver:
  • 5 Answers
Have u recharged it????
try to reboot it. there is a small hull in the bottom on left side, push in it with the pin u have tp your PDA. that will reboot the system
Posted on Jan 04, 2008
  • 38 Answers
I have to agree with DirtyHarry1, it sounds like the battery could be weak. On my iPAQ when the battery is done charging the charging light changes from orange to green, I'm not sure if yours will do that. I'd try leaving it charging on the cradle for about 24 hours to see if that improves the life any.
Posted on Feb 01, 2008
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
Im download app into my hp ipaq,then it hang/jam...it not running like usual..
For hanging/Jam problem, few factors can be involved, First of all you have to check, how much space is being left in phone memory after installing particular applications, To check the settings, Go to settings, Memory,
Solutions:
1. Soft Reset,
Try resetting the device while hold down the End Key for few seconds, when the phone is switched off take off battery for few minutes, then try putting the battery again, It will clear the memory used by the softwares,
CAUTION: Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.
2. Hard Reset
Hard reset will restore your Ipaq to factory default settings, Perform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.
settings.
NOTE: The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center). bilalseham_6.jpg
if you require more assistance feel free to reply to this post
Thanks for using FixYa
Regards-BA
Jan 27, 2011 | HP iPAQ 510 Voice Messenger Smartphone
Startup not happening
try replacing both batteries, not just one
this things old ' 14 years old in fact.
some have a tiny coin cell battery to inside./
why expect any battery to last that long?
HP ended support long ago (after 10 years it ends)
did you ask on HP forum first and not here, we are NO HP here.
here is real HP , this is not spam or the link its the real deal
https://h30434.www3.hp.com/
Feb 07, 2018 | HP iPAQ RZ1710 Pocket PC
Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
bob.
Jun 20, 2009 | HP iPAQ rx5935 Travel Companion Pocket PC
I let my hp ipaq rz1710 die and now it will not work
try taking the battery out for about a minute and see if that restarts it.
Apr 24, 2009 | HP iPAQ RZ1710 Pocket PC
IPAQ 6365 hard reset
I Also Had The Same Problem. Now I Fixed It. Go To Power In Settings. Click On The Advanced Tab. Uncheck The Box Which Says "Turn Off The Device If Not Used For" Box. This Will Solve The Problem. It Solved Mine. Thereafter Once, My Backlight Did Not Switch On. Fix This By Going Into Backlight Settings And Uncheck The Box Which Says "Turn Off The Backlight If Not Used For" Box. This Will Solve It. Then Soft Reset The Device To Change Settings. To Soft Reset, Find A Small Hole In The Left Hand Side Of The Device. Put Your Stylus In And PRESS ONLY ONCE. If You Keep It Pressed, Your Device Will Hard Reset. Don't Do That. Just Press ONCE.
Mar 31, 2008 | HP iPAQ h6315/h6365 Pocket PC
HP iPAQ RZ1710 Pocket PC freezes on pin entry!!
If still freeze after the resets, then try to do a Hard Reset.
With this way you will restore your device at the default condition.
Take care to remove any external memory from iPAQ before to this and also have it
full charged.
The bad of this....you will loose everything stored at the internal memory of iPAQ.
The good this...your iPAQ would be alive again ;-)
To to a Hard Reset press at the same time the reset button+calendar button+today button.
Jan 10, 2008 | HP iPAQ RZ1710 Pocket PC
Ipaq RZ 1710 won't switch on
If you've backed up your PDA, I'd strongly suggest trying a hard reset. This has happened before to one of my RZ1710 pda's. The only solution was to hard reset it. This can be done by pressing the two extreme left and right buttons (The Calander, and Home button) and the reset button on the bottom of your iPaq with the stylus.
Sep 11, 2005 | HP iPAQ RZ1710 Pocket PC
My ipaq won't open!
if you have inserted SD or other cards and devices in your IPAQ try to stay IPAQ without them.... if ypu don`t have it ---- then go to the service center....
Sep 08, 2005 | HP iPAQ RZ1710 Pocket PC
HP iPAQ RZ1710 Pocket PC Logo
382 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
