Question about Sewing Machines
I have a Kenmore sewing machine. when i am sewing the feeders pull the material
    Problem Solver:
  • 6 Answers
They are supposed to pull it. is fabric puckering? it could be a problem with tension. try lowering or raising until it works right.
Posted on Apr 26, 2009
Feeder not moving
knotted up thread under the material indicates that the needle thread tension is incorrect ( needs tightening)
once you have that correct the material, will feed normally
use scrap when adjusting and the correct tension is when the top and bottom threads meet at the join ( middle -center )of the materials being sewn
Aug 09, 2014 | Elna 2007 Mechanical Sewing Machine
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
The feeder on my 6690 won't pull material through
Look in your owner's manual. I'm sure your machine has a reverse feed button but don't know if you can manually disable the feed teeth. If it is so equipped, it doesn't drop the teeth. Rather, it simply causes them to go straight up and down. If the teeth truly stay below the needle plate level, they are likely out of adjustment and need to bereadjusted and raised.
Jan 08, 2013 | Husqvarna Viking 1
The feeder plate isn't working. how do I fix?
here is a link for a free manual see if it has the information in it
about the feed dogs, some machine have a lever to adjust the
feeddogs and some don't
http://www.singerco.com/uploads/download/864_white-970,972,979-x-.pdf
Dec 02, 2012 | White Sewing 979
I cant get the material feeder to come up so that the material can slide
Make sure feed dogs (teeth in needle plate beneath needle) are showing. Flip switch to UP position to "feed" fabric. Sometimes control fir this located on back of machine lower left side and " hidden" by your extension table, so remove that table and you'll find the switch! Jimmy
Apr 07, 2012 | Singer 3116 Simple
The feeder won't work right.
The machine is old and may not have been maintained. The feed dogs may be rusted.
Remove the needle plate and bobbin. Lightly mist the feed dogs with wd-40. Wipe away the excess with cotton swabs.
Mar 14, 2010 | Elna Sewing Machines
Feeder doesn't work on Brother PC 8200/8500 sewing machine
Look for a mechanical switch that engages the lower drive mechanism.
Nov 15, 2009 | Brother PC8500D
FEEDER FEET WILL NOT PULL FABRIC,REVERSE WORKSB
I'm sorry to say that it sounds like you have a broken gear that is preventing the feed dogs from moving properly. Depending on the machine, this could be a very expensive repair.
Feb 01, 2009 | Kenmore Sewing Machines
Kenmore sewing machine # 385.17626 feed dogs not advancing fabric. Appear to move up and down, but not forward to back.
I had the same problem and had recently posted my own message, with no replies. Took it to a repair person and he fixed it at no cost - it was stuck in reverse because the mechanism(s) were all gunked up. Take off the accessory box on the machine and the bottom plate. move the mechanism so they move freely and take out any gunk you see. The feeder dogs should now move back & forth in addition to up & down, feeding the material properly
Jun 21, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
