Can't find make or driver for my webcam, Hardware I.D is as follows USB\Vid_Oc45&Pid_60b0&Rev_0101&Ml_00
I can't find or identify the driver for ny Webcam. The Harware ID on WinXP is identified as USB\Vid_Oc45&Pid_60b0&Rev_0101&Ml_00. Thanks. My E-mail I.D is timothy@rangkapselari.com
    President:
  • 8,637 Answers
V v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 Be sure the camera is plugged into the USB port before running the program.
As you run the program, write down the info about the camera so you will know what you have .
Double click on this site and download the Camera Diagnostic Tool and run it to check out your camera and/or problem.
http://www.download32.com/webcam-diagnostics-d35065.html
I ran the diagnostic on my camera to give you an idea how well it works.
Give it a try.
Hope this helps. Bud
Posted on Apr 26, 2009
PnP Device ID: VID = 15D9 PID = 0A41
Device Name: ?USB Input Device
Serial Number: 5&&192F622A&&0&&1
Revision: (Information not returned)
Device Type: Standard USB device -
Chip Vendor: Agilent(???)
Chip Part-Number: A2625
Product Vendor: USB
Product Model: Input Device
Tools on Web: (N/A)
This does not work
Oct 30, 2013 | Cameras
Tip
How to Repair a USB Flash Drive
Most people who work with their computer more or less regularly are sure to have a flash drive (and even several of them). Sometimes a flash drive can become faulty, for example after a failed formatting or due to some errors.
Quite often the file system comes to be recognized as RAW, the flash drive cannot be formatted or even accesses... What can be done if that is your problem?
This manual for repairing a flash drive is intended to deal with all sorts of USB drive issues except cases of mechanical damage. The drive manufacturer does not matter, in fact, be it Kingston, Silicon Power, Transced, Data Traveler, A-Data etc. All actions to be taken are given step by step.
Getting to Know Flash Drive Parameters (Manufacturer, Controller model, Memory size)
It may seem very easy to know the flash drive parameters, especially when the manufacturer and memory size are specified on the drive case. The matter is that USB drives, even belonging to one model range and made by one manufacturer can have different controllers. Hence, a simple conclusion - in order to repair a flash drive you need to know exactly the controller model so that you can select the right fixing utility.
To determine the controller model there are special digital and letter values set by parameters of VID and PID.
  • VID - vendor ID (manufacturer identifier);
  • PID - Product ID (product identifier, i.e. identifier of a particular model);
These will be different for various controllers!
If you are not going to waste your USB drive, do not use utilities which are designed for VID/PID other than yours. Very often, a wrongly chosen utility can "kill" your flash drive.
How Do I Find VID and PID?
You can find VID and PID with the help of special utilities, but it can be done without them as well. First of all, go to Device Manager.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-5.jpg
In Device Manager, a flash drive is usually recognized as a USB Flash Disk, so you need to right-click on the device and go to its properties.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-2.jpg
In "Details" tab select "Parent" parameter to see VID/PID. In our case they are as follows: VID: 0204, PID: 6025.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0.jpg
Choosing The Necessary Utility to Repair The Drive (Low-level Formatting)
Knowing VID and PID we need to find a special utility suitable to restore our flash drive. It is better to use a search engine, Google or Yandex (a sample query: Silicon Power VID 0204 PID 6025).
Before launching such utilities we recommend disconnecting all other flash drives from USB ports (so that the utility cannot format another disk by mistake).
After treatment by such utilities (designed for low-level formatting) a problem-ridden flash drive should work properly again, recognized quickly and correctly by your PC.
Certainly, this repair manual is not the simplest one (you can't do everything by clicking one or two buttons) but it can be applied in many cases to almost all flash drive types manufacturers.
Yet before you start low-level formatting you should understand it means erasing all user information without a chance to restore it. That is, the part of the drive where data is contained will be cleaned completely. Standard Windows formatting does not do that but only applies quick formatting which is basically remarking your drive.
So if you used your flash drive to store some important data before the problems began, and now you need the data to be recovered, it is possible but only before you start low-level formatting. This operation requires special data recovery software. The best choice to suit your needs will be Hetman Partition Recovery.
on Jun 06, 2016 | Hetman Partition Recovery - Recover...
Tip
USB FLASHDISK/ Pen Drive WRITE PROTECT, CAN'T FORMAT, SIZE 0, ERROR SOLUTION
Dear Guys, If you find the problem same as the contents above. Please kindly following this step :
  1. Find VID (Id Vendor) and PID (Id Product) of your type Usb Flashdisk/ Pen Drive, Use This Software USB VIEW, see this picture to find :
2. after you already find your VID and PID, you can enter this website to find correct software to use. http://flashboot.ru/iflash.html , maybe this web use Rusian Languange but no need to worry you just fill up your VID or PID at search Box, see this picture
Good Luck, Or If you need my support, i will do.....
on Mar 22, 2010 | Computers & Internet
MY PEN DRIVE IS DETECTED BUT SHOWING THE OPTION '' PLEASE INSERT DISK IN DRIVE ''
Following this step :
1. you just need to see your ID Product (PID) and ID Vendor (VID), you can use this software to find your PID and VID, USB VIEW, for reference see this picturefd97e60.jpg
after already found the PID and VID, take only for digit behind X.
2. visit this web http://flashboot.ru/iflash.html to find correct software for your flashdisk, just filled up at box like search.
3. or after you know the VID and PID you can contact me to find correct software for your pen drive type.
Good Luck
Mar 21, 2010 | Electronics - Others
Will not print
check for the installed drivers in the control panel.try uinstalling the drivers and reinstalling them back again...try deleting the registry VID and PID keys if possible(hkey local machine/system/control set 001,2,3,4/enum/USB/VID and PID starting with 7.see if it works.....
Jun 24, 2009 | Lexmark X2600 InkJet Printer
Driver incorrect
Hello, look the device VID & PID in
Control Panel --> System --> System Properties --> Unknown Device --> Details
Es. I Found on my notebook : USB\VID_067A&PID_7561\5&1737F18D&0&2
Then Modify SER2PL.SYS with your VID & PID
Es. :
[ControlFlags]
ExcludeFromSelect = USB\VID_067A&PID_7561
[Pro]
%DeviceDesc% = ComPort, USB\VID_067A&PID_7561
Reinstall the driver
Aug 05, 2008 | ICP DAS I-7561 CR (I7561CR) Serial Adapter
Driver for rtl 8139D
maybe you got the wrong version of your driver, realtek got an A&B device driver..
Feb 15, 2008 | Computers & Internet
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
