Question about Sennheiser (MM50) Headset
Sennheiser MM 50 iPhone Mic & Button does not work
I purchased a set of Sennheiser MM 50's for my iPhone 3G today and I found that the microphone and answer/end call button does not work. I took them back and replaced them with another pair and the same problem occurred, so I want to know why I can't use the microphone and button with my iPhone. Thanks, Josh
  • Anonymous May 02, 2009
    just the same problem
I had just the same problem and if you're lucky, the solution is very simple: due to the open headset-plug of the iPhone I had a lot of dust inside. Just try (carefully!) to get the dirt out of the jack with a pair of tweezers or a strong vacuum cleaner. In my case it solved the problem. Good luck!
Posted on Jun 08, 2009
How do you repair a sennheiser sk100 jack socket
I assume you mean the mic plug/jack. Bent pins or broken connectors will require a new jack and/or plug installed and they are not easy to do. These 3.5 mm jack connectors require both a light touch during install and soldering. If you're a pro then start shopping for a replacement 3.5 mm mono jack but be warned. The jack may solder directly to the PC board....which reminds me. Look for broken connections from jack to PC board..a common failure point and resolder as needed.
May 01, 2014 | Sennheiser Audio Players & Recorders
Sennheiser md 42 microphone not being picked up on camcorder help please.
This would require a special cable to work. The mic is MONOAURAL with BALANCED output and the camera is STEREO input. This means a special cable is needed and you would probably have to make it yourself as I haven't seen one on the market.Pin 2 of the XLR of the mic would go to BOTH the tip and ring of the plug into the camera. Both pins 1 and 3 of the XLR at the mic would tie to the sleeve of the plug to the camera. If you tried an XLR to 1/8 adapter, no audio would be heard other than from the buillt in mic.
Mar 08, 2013 | Sennheiser MD 42 Professional Microphone
Issue more complicated than originally thought!
This isn't a solution. But after I've gotten into my microphone with the same issue using a torx screwdriver I found that I (Electrical Engineer) don't have the proper equipment to fix the issue. Roughly 100 dollars (Flat rate) and a send off to Sennheiser is your best bet.
May 22, 2012 | Sennheiser 100/500 G2 Series Wireless...
Iphone 4 does not pair sennheiser vmx 100
To Pair the Sennheiser VMX 100 headset with your iPhone or other cell phone:
At the same time as you open the mic, you also need to push down on the bottom/volume-down button on the side of the earpiece and hold this down (at the same time as opening the mic) until the light flashes red and blue alternating. (Just to clarify, it is the button that has an arrow pointing toward the Sennheiser logo). If asked for a code, enter "0000" (four zeros).
This video shows the bluetooth earpiece connecting to an iPhone 4S running iOS 5.0 (not jailbroken). This is the standard way to pair these devices, but as a disclaimer:
If anything should happen to your phone or your Bluetooth earpiece, it is not my fault.
Nov 06, 2010 | Sennheiser VMX100 Bluetooth Headset...
My school uses Sennheiser Mic's for it's PA system. Is there an adaptor that would let me connect my CD player to the PA sytem's mic jack via the CD player's 3.5 mm headphone outlet?
The CD is STEREO whereas the MIC is monaural.
One could make an adapter that merges the left and right channels before sending on the balanced XLR input. This involves using an audio transformer or direct input box for the balanced line and is not DIY unless you are elctronically skilled.
The best way to do this is to instead plug the output of the CD into the TAPE inputs that are usually available on the mixer.
One uses usually a 3.5mm stereo splitter cable with RCA plugs for most of them.
Sep 10, 2010 | Sennheiser Epack-835 Professional...
On/off button fell off Sennheiser wireless mic
This is quite common with G2's, and really annoying!
If you are lucky, 50% of the time the red button is pushed inside the mic.
You need to remove the bottom section:
- open the battery compartment
- there should be 3 star-bit screws around the outside (remove)
- pull the bottom of the mic off
If the red button is not inside, they are available as a spare part from Sennheiser dealers.
Be carefull when putting the mic back together, it needs to line up correctly with the internal guides, forcing the base back on could damage the ribbon cable. when the line-up is correct it slides on very easily.
Best of luck.
PTB
Jul 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
Gprsnotify appear on my stealth screen
Specifications
* Size: 117.2 x 55.3 x 15.9 mm* *18.25 mm at camera area
* Weight: Approx. 150 g
* Memory: Up to 48GB (32 GB on-board memory, plus 16GB expansion via
microSD memory card slot)
* Display: 3.5 inch TFT with up to 16 million colors nHD 16:9 widescreen
(640×360 pixels)
* Talk time: Up to 320 min (3G), 400 min (GSM)
* Standby time: Up to 400 hrs (3G), 430 hrs (GSM)
* Video playback: Up to 4.5 hours (offline mode)
* Music playback: Up to 37 hours (offline mode)
* Image capture: Up to 5 megapixels (2584 x 1938) JPEG/EXIF (16.7
million/24-bit color).
* WiFi and HSDPA
* DVD quality video capture and 16:9 display
The Nokia N97 32GB is made in Finland and it is the leading phone in the
Market, beating the Nokia N96 16GB and also the apple 3G 16GB..
Nokia N97 32GB is touch screen and is one of the Smartest technology.
Be one of the first to have this phone, We have sample units available for Sale..
Feel free to contact us, we are always online to give you a reply...
NOTE:
If you send us a mail today, we will reply you today.
dialaphonemobile@gmail.com
May 14, 2009 | O2 Xda Stealth Smartphone
Radio Communications Logo
1,188 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michael Vincent Cruz
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
