My Ricoh Aficio SPC 420dn keeps saying "set the toner cartridge correctly" yesterday it was yellow and today it's cyan. i have adjusted both the cartridges and don't know what the deal is. Thank you!
mimranon
  • 72 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC542 error code after
Hi dear pls take you printer to service center
Thank you
Imran
Pls rank as possible have nice day
Posted on Apr 20, 2009
  • 95 Answers
SOURCE: Ricoh Aficio SP C410DN "set toner cartridge correctly"
It sounds like the part the toner bottle slides under to lock in place is broken. you could try and fold some paper and tape it to the toner to hold it down.
Posted on Apr 23, 2009
  • 95 Answers
SOURCE: Ricoh C410DN set the toner cartridge correctly
If you look at one of the other colors you can see how the toner cart door slides under some plastic to open it. I bet the yellow one is broke. Tape a folded piece of paper to the end of the cartridge. That might hold it down so it will work.
Posted on May 29, 2009
  • 143 Answers
SOURCE: I have a ricoh aficio 200 photocopier - toner
Check inside there the top of the bottle goes. There should NOT be the white stopper from the previous bottle there.
Posted on Aug 11, 2009
  • 29 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC545 error code after
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
Posted on Aug 18, 2009
Why my printer Aficio SPC 221SF don't print magenta and yellow colours
Could be faulty toners or clean contact points on the toner and machine
Mar 22, 2016 | Ricoh Aficio SPC221SF Multifunction...
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
May 26, 2009 | Ricoh Aficio SP C410DN Laser Printer
Mar 26, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio CL7300 DT2 Laser Printer Cyan color issues
developer unit not set properly.
push the unit in tight
Mar 16, 2009 | Ricoh Aficio CL7300 DT2 Laser Printer
Color bad on ricoh aficio sp c210 sf
Hi There,
print out a page from windows paint program of cyan, magenta, and yellow. see which colors are incorrect. that will help you get closer to the problem area.
the drum also may not be screwed in all the way. remove it, and try putting it back in again.
Dec 12, 2008 | Ricoh Aficio Colour 3006 Color Copier
Add Toner
Your machine has got a toner pump on each of the colours wich transport the toner through pipes , these pipes get blocked and needs to be vacuumed out to clear the blockage .i got the service manuals if you need any further assistance
Nov 13, 2007 | Ricoh Aficio AP3800C Laser Printer
217 people viewed this question
k24674
jasbo
jasbo
