Question about Sony Handycam CCD-TRV608 Camcorder
Error message in LCD Display of Video Camcorder
My video camcorder does not work and is showing an LCD error message of C:31:22. I tried removing the tape, turning off the camcorder and removing the battery as well as hitting the reset button but the problem still persists.
    Champion:
  • 288 Answers
Could be a few things. heads may need to be cleaned, they could also be wet due to condinsation. the take up reel table may be weak. These can be taken apart and the spring can be strecthed slightly to increase the clutch tension. the capstan motor could have failed or something like debris could be binding it's turning ability. one of the guides may have came off it's arm. sometimes these can be snapped back into place.
Posted on Sep 16, 2007
SOURCE:
JVC camcorder shows message power not on or usb device not compatible
You device model number and other symptoms such when does the error display ? where does it display (view finder or lcd screen etc) will help
Mar 23, 2016 | JVC Video Cameras
Video Camcorder Error Message
Per SONY; To service the C:31 code, Sony recommends you do the following: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required.
Sep 15, 2007 | Sony Handycam CCD-TRV608 Camcorder
Canon charge light blinks 7 times
If your Sony camcorder displays a tape transport or mechanical error code always try resetting the camcorder. This is done by removing the battery or ac power, wait 10 seconds, reapply the battery or ac power and try again. If it still goes into error try another tape. The camcorder will not always display an exact error code. Sometimes you may see an error message such as, "Reinsert the cassette", on the LCD screen. This is the camcorders way of saying, "Take the tape out and try again." Try reloading the same tape as well as a new tape. If the camcorder is still going into error this means it is time to send it in for service or repair.
The camcorder may also sometimes display a "Reattach Power Source." This is the camcorders way of saying,"Try resetting my system,so I can try again." Many people mistaken this error and think they have a problem with the battery or ac adapter. This is not true and has nothing to do with your battery or ac adapter. Reset the camcorder by removing the battery or ac power, wait 10 second, reapply the battery or ac power. If the error reappears the unit needs to be serviced or repaired.
Jan 23, 2013 | Canon VIXIA Video Cameras
I can't watch back my recorded cassette, on my camcorder? i'm getting an error message C31 23
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Jul 24, 2011 | Sony Handycam DCR-TRV340 Digital Camcorder
Error code C:31.23
Feb 10, 2011 | Sony Handycam DCR-TRV145 Digital Camcorder
I have a sony dig 8 trv340 and am receiving an error code of c31:42 what does this mean?
In DCRTRV430 Camcorder, the C:31:42 error message is a Self diagnostic display. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camcorder. In C:31:42, the issue is with the tape and the tape mechanism.
I suggest that you remove and reinsert the tape to check if it helps. You may also try inserting new tapes in the Camcorder. Please remove the battery and/or power cable, connect, and perform operations from the beginning. You may also try resetting the Camcorder back to factory default after removing the tape.
To Reset the Camcorder, perform the steps below:
? Please open the LCD screen to locate the RESET button.
? To reset the Camcorder, press the RESET button using a sharp-pointed object.
? Please make sure that the Camcorder is turned on while pressing the reset button.
Also, try turning off the Camcorder and remove the battery pack. Then move the 'Power Switch' of the Camcorder to the ON position
for 1 minute. After about 1 minute, move the 'Power Switch' to the OFF position.
Now reinsert the battery, turn on the Camcorder and check whether it is working fine.
Thanks.
KenSolutions
FixYa
Oct 23, 2010 | Sony Video Cameras
Error C:04:00
Shamelessly copy pasted from another forum.
Jul 29, 2010 | Sony Handycam DCR-SR40 Camcorder
HDD error
I get the exact same message.
My camcorder keeps showing this message. Sometimes it works flawlessly but most of the time, this error shows up. What gives?
Jan 02, 2008 | Hitachi DZ-HS300A DVD Camcorder
Display flashing
It is telling you that the scene is too bright for the current settings - use a smaller aperture, or a lower ISO rating
Jul 17, 2017 | Samsung SC-D103 Mini DV Digital Camcorder
Sony Handycam CCD-TRV608 Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
