The monitor requires a diffent resolution ratio than my computer offers can i make it work?
    President:
  • 2,992 Answers
There's nothing you can do with the current video hardware, but you can install a new video card which would support the resolution required by the monitor. Just be sure you get one compatible with your motherboard's video card slot (AGP, PCI or PCI-E).
Posted on Apr 17, 2009
Widen the screen on Westinghouse tv
Screens are controlled by ASPECT RATIO.
Monitors can have 4:3 16:9 and 16:10 ratios.
You are doing 1 of 3 things.
  1. You have a regular monitor and the tv and are duplicating the screen.
  2. You have a regular monitor and the TV and are extending the screen.
  3. You have just the tv connected.
Your video card has to have a screen resolution that meets the tv's ratio to have the tv take the full screen.
If your configuration is 1. the tv will only match the monitor resolution, so if you change the screen resolution, you may get bars on the monitor, and the tv will go wide screen.
if your configuration is 2. the tv is controlled independently and you can select it to change its resolution to an appropriate aspect resolution. *this requires that your video card gives you the correct screen resolution for your tv. not all displays will work.
If your configuration is 3. the tv is the only resolution that is being pushed and just adjust the resolution til the screen is filled in.
To adjust the screen resolution, right click on the desktop where there isnt an icon and select either Properties (windows xp) or Screen Resolution (windows vista, 7 and 8).
if you have 2 screens press the identify button and it will put a number on each screen. click the appropriate screen and go to the resolution dropdown below. Change, apply and if it doesn't look right, revert and try a different setting. if you try them all and it won't take up the full screen, then the video card can't push the video resolution your monitor wants.
Sep 30, 2014 | Computers & Internet
I accidently hit recall on my monitor settings. I now have a smaller veiwing screen with black edges
You didn't say which OS you're using but it sounds like you've changed the aspect ratio of your video signal. Different screen resolutions have somewhat different aspect ratios. The aspect ratio indicates the ratio of the number of pixels of width to those of height. For example: my video driver offers a resolution of 1280 x 960 or 1280 x 720 which would give screen aspect ratios of 1280/960 = 1.33 :1 and 1280/720 = 1.77 : 1. The latter would produce a narrower image. You can compensate somewhat by increasing your horizontal sweep voltage with your monitor menu. A better solution would be to select a resolution that more closely matches your monitor's screen size.
Aug 10, 2011 | Dell D1028L 17" CRT Monitor
Monitor has stretched images. I use CAD programs that require equal vertical & horizontal. I am using only a VGA cable plugged into my HP Pavilion. AOC suggests DVI cable, but did not include one...
You should set your PC video resolution to the native resolution of this monitor: 1920x1080 at 60Hz . Right now you do not have it set to the correct aspect ratio for this wide sceen monitor.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 28, 2010 | AOC F22 Monitor
Width and height ratio
You need to set your PC video output resolution to the native resolution of this monitor, which is 1680X1050 @60Hz.
Right click on the desk top, the display properties will come up, click on setting tab, then you will see resolution setting choice.
Mar 28, 2010 | Acer AL2016W 20" LCD Monitor
What is the recomended resolution display setting for my Acer X193w monitor
A computer monitor is made of pixels (short for "picture element").
Monitor resolution is measured in pixels, width by height. 640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, an aspect ratio of 4:3. With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), all aspect ratios are the same.
Hope this initial information helps. Let me hear from you again for any clarifications.
Thank you for using fixya.com
Feb 23, 2010 | Acer X193W LCD Monitor
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
Distorted display/aspect HP w1907
This is a common problem with wide screen format.
The way I overcome this distortion is to open a drawing program and draw a circle, some programs require you to hold down the shift key to produce a perfect circle.
I then go to the Display Settings and adjust the screen resolution to get the best display that fills the screen and that gives me the perfect circle.
If this does not work you may need to download the latest video driver for your graphics card and then adjust the screen resolution..
Aug 22, 2009 | HP w1907 LCD Monitor
Are Dell monitors not compatible with older HP Pavilion Computer? I tried to connect my HP CPU to a Dell monitor and it will not recognize it at all.
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
Jul 18, 2009 | Dell Computers & Internet
Viewsonic monitor
Pixel Ratio is just a parameter Measured to Produce Good Quality Display with Fine details so Do not Mix up with Resolution and Pixel ratio.
Use the Resolution that best sutes the Application you use(which may change with time to time based on applications you use)
Keep a standard Resolution 1024 x768,or which ever suits your Vision.
NViiDiA is a Grafix card and Monitor features are 2 differnt thigs so.
Dont be concerned about the Parameters and get mixed up.
just find the best possible Resolution and enjoy your Monitor with best Quality, :)
Jul 17, 2008 | ViewSonic VX924 19" LCD Monitor
How to Adjust the sceen ratio from 16:9 to 4:3
Since it's a widescreen monitor, the streching is likely from using a 4:3 ratio resolution on a 16:9 ratio monitor. Try setting the operating systems display resolution to 1440x900, since that's your monitor's native resolution (LCD monitors only really have one resolution). In Windows, resolution settings are found by right-clicking on the desktop, click properties, and go to the Settings tab.
Aug 05, 2007 | Philips 190CW7CS27 Monitor
Computers & Internet Logo
David Payne
David Payne
